查看: 3062|回复: 1
Appliance hardware – Updated 02/02/2012
发表于 2012-1-18 21:00:37 | 显示全部楼层 |阅读模式
Here is a short list of the hardware used in Check Point appliances. The numbers show SPU and the maximum throughput for firewall, VPN and IPS traffic according to Check Point.Check Point 2012 Appliance series
ModellSPUFWVPNIPSCPURAM
214002003507212x Intel Xeon E5645 2.40GHz (Six-Core)6
12200738152.58Intel Core i5 750 2.67GHz (QuadCore)4
48006231126Intel Core2 Quad CPU Q9400 2.66GHz4
460037491.54Pentium Dual-Core E6500 2.93GHz4
420011430.42Intel Atom D525 1.80GHz4
220011430.42Intel Atom D525 1.80GHz2
Check Point Power-1 Appliance series
11075up to 1222204122x Intel Xeon E5530 2.40GHz(QC)6
90751006163.7102x Intel Xeon E5410 2.33GHz (QC)4
507559692.47.5Intel Xeon E5410 2.33GHz (QC)2
Check Point UTM-1 Appliance series
30702984.51.14Intel Core2 Duo E6400 2.13GHz3
20701013.50.452.7Intel Celeron 440 2.00GHz2
107010130.352.2Intel Celeron M 1.5 GHz1
5701012.50.31.7Intel Celeron M 1.5 GHz1
270501.50.121Intel Celeron M 600 MHz1
130501.50.121Intel Celeron M 600 MHz1
Check Point Smart-1 Appliance series
ModellCPURAMHDD
Smart-1 5Intel Celeron M 1.50GHz2500 GB
Smart-1 50Intel Xeon E5410 2.33GHz (DualCore)42 TB
Old Appliances
Smart-1 25
  • Intel Core2 Duo T7400 2.16GHz
  • 3 GB RAM
  • 4x 500 GB SATA HDD in RAID 10
UTM-1 2050
  • Intel Pentium 4 3.4 GHz
  • 2 GB RAM
  • 80 GB ATA HDD
  • Firewall Throughput (R65): 2.4 Gbps
  • VPN Throughput: (R65) 380 Mbps
UTM-1 450
  • Intel Celeron M 1.5 GHz
  • 1 GB RAM
  • 80 GB ATA HDD
  • Firewall Throughput (R65): 400 Mbps
  • VPN Throughput: (R65) 200 Mbps
The details can be determined from the command line.
For the CPU details use cat /proc/cpuinfo, for the RAM details use cat /proc/meminfo.
 楼主| 发表于 2012-2-3 17:20:26 | 显示全部楼层
ModellCPURAMHDD
Old Appliances
Smart-1 25
  • 3 GB RAM
UTM-1 2050
  • 2 GB RAM
  • 80 GB ATA HDD
UTM-1 450
  • 1 GB RAM
  • 80 GB ATA HDD
GMT+8, 2026-11-8 02:47 , Processed in 0.033091 second(s), 18 queries .
