查看: 3678|回复: 3
IBM steps into home media servers
发表于 2011-3-17 16:11:04 | 显示全部楼层 |阅读模式
IBM steps into home media serversCeBIT 2009 Dual Nehalem blades as well
By Charlie Demerjian in Hannover
Sat Mar 07 2009, 14:40
IBM HAS A big stand at CeBIT, and it is usually about as exciting as watching paint dry. While people talking about enterprise software for obscure verticals may excite some, we much preferred the hardware.
Dual Nehalems, single blade
IBM had two cool things to show off, blades and a home NAS server. The blades are nothing unexpected, but the company did a great packaging job. The Bladecenter HS12 is a single socket Nehalem, the HS22 is dual sockets. To pack two of those chips, 2HDs and six DIMMs per socket in a blade is quite a packaging job.
180 drive bays, enough for the average home
As you can see from the front of the IBM XIV storage server, it is a home oriented NAS with 180 bays in front. Each set of 12 is actually a quad Xeon server acting as a storage controller. Filled with 180 1TB drives, you get 80TB of storage. Yes, I did not forget the 1, you get a little under half of the storage, the rest is used for redundancy and speed.
XIV does not use RAID, it has it's own distribution algorithm that writes sectors to multiple drives simultaneously while spreading the write out across many drives. If you think about it, the RAID controller is often the bottleneck in many transactions, if you have ever noticed how a RAID5/6 array may take literally days to rebuild, you understand the problem.
Storage controllers and bandwidth are not scaling with drive capacity, so the time it takes to fill a drive grows with capacity. In the enterprise, this is deadly, and the size of SAS drives reflects this, speed is the key, not size.
To combat this, XIV scales IO as well as drive capacity, and they promise a sub-30 minute rebuild of any failed drive. That is amazing speed if you think about it, especially under full load. A lot of this speed comes from redundancy and the ability to spread out loads.
Back of the beast
To scale bandwidth like that, you need lots of I/O, and there are two rack mounted 24 port iSCSI switches in the middle of the unit, everything is fully redundant. To talk to the outside world, the switch on the right side has 24 fiber channel ports and 6 iSCSIs. It is pretty close to enough.
The software is also fairly simple, you just tell it you want a new pool, name it, section it into volumes, and attach it to an external port. It takes about 30 seconds total if you are slow, most of the tedious stuff is automated.
Volumes do not affect performance, you can make as many or as few as you want. Snapshots are automated as well, and can be manually scripted if you are into that kind of pain. You tell it what you want, and it semi-automagically happens.
In the end, just slap a wireless router on top, we would recommend an 802.11n with QoS capabilities, and you have the perfect home storage unit. You can carve off 20TB or so for every person in the house, and all stream your music without stepping on each other's toes. While it does not support DRM, it should be enough to back up many brands of small and mid-sized home media PCs. µ
Read more: http://www.theinquirer.net/inquirer/news/1051313/ibm-steps-home-media-servers#ixzz1GqHt6GF0
The Inquirer - Computer hardware news and downloads. Visit the download store today.
 楼主| 发表于 2011-3-17 16:14:05 | 显示全部楼层
下载 (71.22 KB)
2011-3-17 16:12
下载 (202.9 KB)
2011-3-17 16:12
下载 (219.66 KB)
2011-3-17 16:12
Back of the beast
发表于 2011-3-18 09:09:35 | 显示全部楼层
IBM在CeBIT有一个很大的展位,通常人们对此就像看油漆变干一样激动人心。当人们谈及企业软件纵向模糊而感到兴奋的时候,我们更偏爱硬件。
  多Nehalems单刀片
IBM有两个很酷的东西可以来炫耀,分别是刀片和家庭网络连接存储服务。刀片并没有特别之处但是公司却做了一个巨大的封装工作。刀片中心的HS12是一个单插槽的Nehalem,HS22是双插槽的。在每个刀片插槽2HDs到6 DIMMs的地方芯片被两两封装的确是一个巨大的封装工作。
180个磁盘隔间,足够普通家庭使用
当你在前面看IBM XIV存储服务器,你会看到它是一个有180个隔间的家庭导向的NAS。每组有12个实际上是一个四方的志强服务器来管理存储。填充180个1TB的磁盘,你就会得到80TB的磁盘容量。是的,我不能忘记1.你只得到了一半磁盘容量的很少部分,其他的都被用作冗余和加速。
XIV不使用RAID,它有自己的分配算法,就是写入到多个驱动器同时在多个驱动器之间写出来。当你想到这些的时候,RAID控制器已经是很多处理行为的瓶颈。如果你注意到RAID5/6
阵列要花几天的时间来建立,那么你也就明白了问题所在。
存储控制器和带宽跟硬盘性能不成缩放比例,所以填充硬盘所花的时间随着性能的提高而增加。在企业当中这是致命的,SAS磁盘的容量反应出这些,速度是关键而不是容量。
来应对这种情况,XIV缩放了IO和硬盘性能比例,提升了低于30分钟的失败磁盘的重建。如果你想到这的时候,这是多么惊人的速度啊,尤其是在满负荷的时候。大部分的速度来源于冗余和分派负载的能力。
  野兽的脊梁
来衡量带宽,你需要很多I/O,在单元的中央有两排24口iscsi交换机,所有都是全部冗余。访问外网的时候,交换机的右侧有24光线通道口和6个iSCSI,全部充足。
软件很简单,你只要说你想要一个新的池,进行定义,分配大小并连接到外部端口。如果你特别慢的话也就是需要30秒,因为大多数的操作都是自动的。
容量大小不影响性能,你可以随意定义大小。快照也是自动的,如果你厌烦快照的话,可以手动修改脚本,你命令它做什么它就会自动的完成。
最后来说下无限路由,我们推荐具有QoS特性的802.11n,那么你就有完美的家庭存储单元。每个人在家可以存储20TB甚至更多,所有的音乐除了踩到脚趾的尖叫声都将被存储,当它不支持DRM的时候,将会有足够的空间来备份许多小的、中等大小的家庭媒体。
更多信息请登录http://www.theinquirer.net/inquirer/news/1051313/ibm-steps-home-media-servers#ixzz1GqHt6GF0
电脑硬件新闻和下载请点击Visit the download store today.
 楼主| 发表于 2011-3-18 20:17:56 | 显示全部楼层
另有 XIV 企业级配置,点击了解更多。
XIV 入门级 6单元配置(72TB 物理容量,27TB 可用容量)ProductDescriptionQty
2810-A14IBM XIV Storage System1
18AAS SW order indicator1
30Base unit indicator1
100UNIX Host Attachment1
101Linux Host Attachment1
102Windows Host Attachment1
103VMware Host Attachment1
1100Interface module3
1105Data module3
3910Fiber cable (LC)8
9000Maintenance module1
9101Modem1
9800Single-phase power1
9805US/Canada/LA/AP 30A pin cord1
5639-XX1IBM XIV Storage System Software Reg/Ren 1
D6GAPer Storage Device SW MAINT6
5639-XXAIBM XIV Storage System Software V101
5005Preinstall1
5809Supply feature1
D6FWPer Storage Device with SW Maintenance6
具体个性化顶制方案请咨询 IBM 存储销售代表。
XIV 的标准保修服务
XIV 存储系统提供三年 7x24小时的硬软件标准保修服务。
GMT+8, 2026-11-29 06:53 , Processed in 0.110935 second(s), 27 queries .
