查看: 3659|回复: 0
BC-H机箱中10个I/O插槽的配置规则
发表于 2011-1-31 08:04:07 | 显示全部楼层 |阅读模式
    10个I/O插槽分为三种,其中Bay 1-4为普通模块插槽,Bay 5-6为桥接模块插槽,Bay 7-10为高速模块插槽。Bay 1-2必须放置以太网的交换模块或以太直通模块.
    可以放在Bay 1-4上的模块有:
    BNT 1/10 Gb Uplink Ethernet Switch Module (fc#1590)
    Cisco 3110X Catalyst Switch (fc#3171)
    Cisco 3110G Catalyst Switch (fc#3173)
    Cisco 3012 Catalyst Switch (fc#3174)
    BNT Layer 2-7 GbE Switch Module for BladeCenter (fc#3211)
    BNT Layer 2/3 Copper Gigabit Ethernet Switch Modules for BladeCenter (fc#3212)
    Server Connectivity Module for BladeCenter (fc#3220)
    Intelligent Copper Pass-thru Module (fc#5452)
    Nortel 10 GB Uplink Ethernet Switch Module (fc#3210)(已停产)
    Nortel Networks L2/L3 Fiber Gigabit Ethernet Switch Module (#3213)(已停产)
    Cisco Systems Fiber Intelligent Gigabit Ethernet Switch Module (fc#3214)(已停产)
    Cisco Systems Intelligent Gigabit Ethernet Switch Module (fc#3215)(已停产)
    Optical Pass-thru Module (fc#3218)(已停产)
    Copper Pass-thru Module (fc#3219)(已停产)
    可以放在Bay 3-4上的模块有:
    Cisco Systems 4Gb 20-port Fibre Channel Switch Module (fc#3242)
    QLogic 4 Gb Intelligent Pass-Thru Module for IBM BladeCenter (fc#3245)
    IBM BladeCenter SAS Connectivity Module(fc#3267)
    QLogic 20-port 8 Gb SAN Switch Module (fc#3284)
    Brocade 10-port 8 Gb SAN Switch Module for IBM BladeCenter (fc#5045)
    QLogic 8 Gb Intelligent Pass-thru Module (fc#5449)
    Brocade 20-port 8 Gb SAN Switch Module for IBM BladeCenter (fc#5869)
    QLogic 4Gb 20-port Fibre Channel Switch Module (fc#3202)(已停产)
    QLogic 4Gb 10-port Fibre Channel Switch Module (fc#3203)(已停产)
    Brocade 20-port 4 Gb SAN Switch Module for IBM BladeCenter (fc#3206) (已停产)
    Brocade 10-port 4 Gb SAN Switch Module for IBM BladeCenter (fc#3207)(已停产)
    McDATA 4Gb 20-port Fibre Channel Switch Module (fc#3208)(已停产)
    McDATA 4Gb 10-port Fibre Channel Switch Module (fc#3209)(已停产)
    Cisco Systems 4Gb 10-port Fibre Channel Switch Module (fc#3241)(已停产)
    QLogic 10-port 4 Gb SAN Switch Module for IBM BladeCenter (fc#3243)(已停产)
    QLogic 20-port 4 Gb SAN Switch Module for IBM BladeCenter (fc#3244)(已停产)
    不可以在Bay 3 和Bay 4 之间混插以太网连接模块(包括铜口Pass-thru Module)和SAN连接模块,而混插光口的Pass-thru Module和以太网连接模块(或SAN连接模块)是允许的。Bay 5-6上的Bridge modules提供到Bay 7-10的连接,它们不直接与刀片连接。Bay 7-10支持高速的协议比如4X InfiniBand。
    可以放在Bay 7或 Bay 9上的模块有:
    4X InfiniBand Pass-Thru Module for IBM BladeCenter (fc#3216)
    BNT 10-port 10 Gb Ethernet Switch Module for IBM BladeCenter(fc#3248)
Voltaire 40 Gb Infiniband Switch Module for IBM BladeCenter(fc#3204)
    10 Gb Ethernet Pass-Thru Module(#5412)
    Multi-Switch Interconnect Module (fc#3239)
    1个(fc#3239)将两个高速模块插槽转换为两个普通插槽,可以放置在Bay 1-4上的模块都可以放置在转换后的普通插槽上。
    Cisco Systems 4X InfiniBand Switch (fc#3217)(已停产)
    请参考销售手册中的Description备注
    BCH 销售手册
    突出价值点:BCH支持14个刀片服务器,拥有10个I/O插槽,目前有20多种可选的交换或者直通模块,可根据客户的需求,在BCH上合理选择相应的模块。
GMT+8, 2026-10-23 05:20 , Processed in 0.034195 second(s), 17 queries .
