查看: 2989|回复: 0
策略不起作用时,启用火墙的路由转发功能(IP和SPLAT平台)
发表于 2010-10-9 10:48:15 | 显示全部楼层 |阅读模式
通常大家都知道火墙策略在执行网关是unload状态时,内部网络无法访问到外网,默认情况下IP Forwarding 是禁用的,如需让内内网访问需要如下命令:
IPSO平台:
To manually enable IP Forwarding on a system with VPN-1/FireWall-1 installed, use the command:
nokia[admin]# ipsofwd on admin
To manually disable IP Forwarding, use the command:
nokia[admin]# ipsofwd off admin
The "admin" part of both commands is simply a tag to let you know who last changed IP Forwarding. You can determine who last changed the state of IP Forwarding by using the command: 'ipsofwd list'
On a system without VPN-1/FireWall-1 installed, you can enable IP forwarding with the following command:
nokia[admin]# ipsctl -w net:ip:forwarding 1
To disableIP forwarding without VPN-1/FireWall-1 installed:
nokia[admin]# ipsctl -w net:ip:forwarding 0
SPLAT平台:
校验如果 IP Forwarding 是否被启用:
more /proc/sys/net/ipv4/ip_forward
Note:如果提示文件不存在请允许如下命令:
touch /proc/sys/net/ipv4/ip_forward
如果“more”命令I输出的不是1,则运行如下命令:
echo 1 > /proc/sys/net/ipv4/ip_forward
GMT+8, 2026-9-26 01:18 , Processed in 0.037847 second(s), 17 queries .
