查看: 3683|回复: 4
SmartSPLAT – very nice SSH GUI client for SPLAT
发表于 2010-9-5 11:56:37 | 显示全部楼层 |阅读模式
I’d like to share with you that today I got aware of the project SmartSPLAT.
Cagdas Ulucan, CCSE+ from Turkey, developed a nice GUI that uses a simple SSH connection to login into your SPLAT-based box and display, change and collect a lot of useful information.
The three shell windows show output of fw monitor, actual fw logging and the main commands, parameters for them can be set using the GUI.
When you click on a button (for example “debug vpn”), you can actually see what commands are issued to the shell, so here you have a learning effect.
The tool has a build-in ftp and syslog server, so produced debug files can the uploaded easily.
At the first moment you’re overwhelmed of all the tabs that address different (troubleshooting) topics, but I think the GUI will improve and Cagdas will find a way to enhance the presentation of his tool.
What is really cool is the cluster view, where you have a windows with two panes, each representing one cluster member. An easy way to send commands to both cluster members and compare the results!
Try his tool, it’s completely free and very very useful.
Send him his suggestion for improvement and make it even better.
 楼主| 发表于 2010-9-5 11:57:21 | 显示全部楼层
 楼主| 发表于 2010-9-5 12:08:45 | 显示全部楼层
SSPLAT has now built-in syslog server, you can capture syslog data to windows event viewer,
Includes Built-in FTP Server , You can easily manage your backups and debug outputs,
You can easily create backup scripts, Export routes,
Source based routing for checkpoint with graphical explanation,
Perform backup operations easily and put the backup file to the pre-defined ftp server,
Sniff your firewall with fw monitor,
Open snmp service with 3 steps and start monitoring your firewall with pre-defined SNMP OID's,
Add remove licenses , list processes ,performance values,
Problem solving road-map enables you to debug problems easily,
List the sizes of your logs and easily delete older logs and their pointer files,
Mount iso files as a CD-ROM device, mount a usb disk easily,
Create CPinfo and send to ftp
 楼主| 发表于 2010-9-5 12:09:06 | 显示全部楼层
 楼主| 发表于 2010-9-7 08:41:27 | 显示全部楼层
没人测试一下吗。晕
GMT+8, 2026-11-8 02:47 , Processed in 0.032267 second(s), 18 queries .
