查看: 2791|回复: 3
juniper 与CISCO 命令比较
发表于 2007-5-21 15:41:23 | 显示全部楼层 |阅读模式
lspacing: 2.2pt; mso-padding-alt: 2.25pt 2.25pt 2.25pt 2.25pt; mso-border-alt: solid windowtext .5pt; mso-border-insideh: .5pt solid windowtext; mso-border-insidev: .5pt solid windowtext" cellSpacing=3 cellPadding=0 border=1>
Cisco Command
Juniper Command
Co-Ordinating Definition
show ip interface brief
show interface terse
displays the status of interfaces configured for IP
show interface [intfc]
show interfaces [intfc] detail
displays the interface configuration, status and statistics.
show controller intfc
show interfaces intfc extensive
displays information about a physical port device
show interface | incl (proto|Desc)
show interfaces description
show ip route
show route
displays summary information about entries in the routing table
show ip bgp summary
show bgp summary
displays the status of all Border Gateway Protocol (BGP) connections
show ip bgp net mask
show route protocol bgp prefix
will show you how that route is being advertised, look for the first line
show ip bgp net mask longer-prefixes
show route range prefix
show ip bgp regexp AS-regexp
show route aspath-regexp "AS-regexp"
displays routes matching the autonomous system (AS) path regular expression
show ip bgp neighbors neigh received-routes
show route receive-protocol bgp neigh
show route source-gateway neigh protocol bgp
Shows whether a neighbor supports the route refresh capability
show ip bgp neighbor neigh advertised-routes
show route advertising-protocol bgp neigh
Shows whether a neighbor supports the route refresh capabilty
show clns neighbors
show isis adjacency
displays both ES and IS neighbors
show clns interface
show isis interface
shows specific information about each interface
show ip route isis
show isis routes
displays the current state of the the routing table
show isis topology
show isis spf
displays a list of all connected routers in all areas
show ip ospf interface
show ospf neighbor
shows neighbor ID, Priority, IP, & State if the neighbor router, dead time.
show ospf interface
shows neighbor id, pri, state, dead time, address and interface
show ip route ospf
show ospf route
display the current state of the routing table
show ip ospf database
show ospf database
display list of information related to the OSPF database for a specific communication server
show version
show version, show system uptime
display the system hardware config., software version, and name and source of configuration files and boot images
show diags
show chasis hardware
displays power-on diagnostics status
show processes cpu
show system process
displays utilization statistics
show tech-support
request support info
displays the current software image, configuration, controllers, counters, stacks, interfaces, memory and buffers
show logging
show log messages
display the state of logging to the syslog
show route-map name
show policy name
displayall route-maps configured or only the one specified
show ip prefix-list name
show policy name
display information about a prefix list or prefix list entries
show ip community-list list
configure,
show policy-options community name
display routes that are permitted by BGP community list
show environment all
show chassis  environment
displays temperature and voltage information on the console
ping dest
ping dest rapid (for cisco like output)
ping dest (for unix like output)
to check to see if a destination is alive
ping (setting source int)
ping dest bypass-routing
terminal monitor
monitor start messages
Change console terminal settings
terminal no monitor
monitor stop
terminal length 0
set cli screen-length 0
sets the length for displaying command output
发表于 2009-2-27 13:25:31 | 显示全部楼层
深圳市长城捷龙物流
深圳市长城捷龙物流有限公司是一家大型物流企业,专业提供中铁快运,在深圳是非常值得您信赖的一家物流公司,只要您有这方面的需求,我们就一定会尽最大的努力让您满意的!
GMT+8, 2026-11-12 11:19 , Processed in 0.043228 second(s), 18 queries .
