查看: 4762|回复: 5
ESET NOD32 Antivirus / ESET Smart Security 4.2.40简体中文版已发布(附下载地址)
发表于 2010-5-28 07:46:03 | 显示全部楼层 |阅读模式
刚刚看到的消息,简体中文版已在国际官网(http://www.eset.com)发布。
需输入病毒库更新时使用的用户名与密码才能下载,建议使用IE默认下载。
下载地址:
EAV 32-bit http://download.eset.com/download/win/eav/eav_nt32_chs.msi
EAV 64-bit http://download.eset.com/download/win/eav/eav_nt64_chs.msi
ESS 32-bit http://download.eset.com/download/win/ess/ess_nt32_chs.msi
ESS 64-bit http://download.eset.com/download/win/ess/ess_nt64_chs.msi
 楼主| 发表于 2010-5-28 07:46:48 | 显示全部楼层
版本更新:v4.2.40
- 修复了HTTP扫描器在扫描长域名时候的问题
- 修复了在计算机重启之后防火墙出现的报错问题
- 在通过远程安装ESS软件的时候可能会出现的进程中断问题被修复
-  修复了“文档保护功能”在遇到长文件名时出现的麻烦问题
- 发送个人配置文件在重新安装后不会再自动发送
- 修复了ESI Log功能在Windows NT4.0下不工作的问题
- 修复了ESI Log在Windows NT4.0下不能保存的问题
- 修复了在导入错误的配置文件后EAV出错的问题
- 修复了从ESI从V4升级到V4.2之后ESI Log丢失的问题
- 修复了不能删除扫描记录的问题
    * Fix: Issues with HTTP scanner with longer domain names ( support for length of domain name to 256 characters)
    * Fix: Issues after PC restart when firewall system integration is "only scan application protocols"
    * Fix: When ESS installed with disabled FW, dialog about trusted networks not displayed
    * Fix: Installation of ESS using Remote Desktop; after selecting firewall's "Interactive mode", the session will interrupt
    * Fix: Long file name makes trouble with logs in "document protection enabled" mode
    * Fix: Scan profile settings not retained after reinstallation
    * Fix: Open ESI log of EAV doesn't work on Microsoft Windows NT4.0
    * Fix: Not possible to save EAV's ESI log and export service script on Microsoft Windows NT4.0
    * Fix: Wrong settings imported from ESS configuration cause problems in EAV
    * Fix: All ESI logs are lost after upgrade from V4 to V4.2
    * Fix: Impossible to delete the on-demand Scan Log in ESS
    * Fix: Fixed ceasing of scan tasks when logged in as standard user
    * Fix: Minor issues with Trusted zone conversion from older to newer version
    * Fix: Unification of behavior when disabling some parts of EAV/ESS/EMS in the main settings window
    * Fix: Possible to delete log of a running on-demand scan
    * Fix: X64 Vista + win7: UAC appears when opening ESI log from ESS/EAV GUI
    * Fix: Minor Thunderbird and Outlook issues
发表于 2010-5-28 09:01:12 | 显示全部楼层
顶
GMT+8, 2026-11-12 23:25 , Processed in 0.057832 second(s), 18 queries .
