查看: 3683|回复: 1
Solaris如何设置IP
发表于 2010-4-11 17:50:49 | 显示全部楼层 |阅读模式
? ifconfig
ifconfig用于配置网卡地址,改动后立即生效,但并不保存配置,下次启动后失效。
# ifconfig -a
lo0: flags=849 mtu 8232
inet 127.0.0.1 netmask ff000000
hme0: flags=863 mtu 1500
inet 172.16.255.2 netmask ffff0000 broadcast 172.16.255.255
ether 8:0:20:ee:11:51
#ifconfig hme0 172.16.3.3 netmask 255.255.255.0
#ifconfig –a
inet 172.16.3.3 netmask ffffff00 broadcast 172.16.3.255
? /etc/hosts
想要永久更改配置,则要更改配置文件,以网卡hme0为例:
#more /etc/hostname.hme0
hostname
#more /etc/hosts
127.0.0.1 localhost
172.16.255.2 hostname loghost
#vi /etc/hosts
#more /etc/hosts
127.0.0.1 localhost
172.16.3.3 hostname loghost
#more /etc/netmasks
# The netmasks file associates Internet Protocol (IP) address
# masks with IP network numbers.
# network-number netmask
# The term network-number refers to a number obtained from the Internet Network
# Information Center. Currently this number is restricted to being a class
# A, B, or C network number. In the future we should be able to support
# arbitrary network numbers per the Classless Internet Domain Routing
# guidelines.
# Both the network-number and the netmasks are specified in
# "decimal dot" notation, e.g:
# 128.32.0.0 255.255.255.0
#vi /etc/netmasks
#more /etc/netmasks
# guidelines.
172.16.3.0 255.255.255.0
#reboot
总结一下,要修改Solaris的IP地址,需要改三个文件,分别是/etc/hosts, /etc/netmasks, /etc/inet/ipnodes。如果想修改网关的话,还需要改/etc/defaultrouter文件。
注:以上均以网卡是hme0为例。
发表于 2010-4-15 14:51:52 | 显示全部楼层
搞点原创的东西吧
GMT+8, 2026-10-18 18:44 , Processed in 0.036619 second(s), 18 queries .
