查看: 5790|回复: 4
NOD32五种更新方式的对比——速度
发表于 2010-3-23 02:36:32 | 显示全部楼层 |阅读模式
未更新病毒库版本:4109(20090527)
最新病毒库版本:4963(20100321)
更新文件总大小:27.8M
##########nod32自带服务器##########
版本4.0
第一次测试
开始时间:16:43:30
结束时间:16:52:42
用时:9分12秒
Ping statistics for 172.16.0.130:
    Packets: Sent = 569, Received = 569, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 280ms, Average = 4ms
第二次测试
开始时间:16:59:10
结束时间:17:08:48
用时:9分38秒
    Packets: Sent = 563, Received = 563, Lost = 0 (0% loss),
    Minimum = 0ms, Maximum = 1431ms, Average = 17ms
第三次测试
开始时间:17:15:20
结束时间:17:26:46
用时:11分26秒
    Packets: Sent = 562, Received = 562, Lost = 0 (0% loss),
    Minimum = 0ms, Maximum = 851ms, Average = 6ms
平均更新时间:10分钟
##########iis更新服务器##########
第一次测试
开始时间:01:28:46
结束时间:01:31:15
用时:2分29秒
Ping statistics for 172.16.0.134:
    Packets: Sent = 157, Received = 157, Lost = 0 (0% loss),
    Minimum = 0ms, Maximum = 769ms, Average = 29ms
第二次测试
开始时间:01:38:50
结束时间:01:40:33
用时:1分43秒
    Packets: Sent = 124, Received = 124, Lost = 0 (0% loss),
    Minimum = 0ms, Maximum = 1117ms, Average = 47ms
第三次测试
开始时间:01:48:03
结束时间:01:49:36
用时:1分33秒
    Packets: Sent = 103, Received = 103, Lost = 0 (0% loss),
    Minimum = 0ms, Maximum = 139ms, Average = 7ms
平均更新时间:2分钟
##########apache更新服务器##########
版本apache_2.2.4-win32-x86-no_ssl.msi
第一次测试
开始时间:02:08:33
结束时间:02:10:49
用时:2分16秒
    Packets: Sent = 143, Received = 143, Lost = 0 (0% loss),
    Minimum = 0ms, Maximum = 1595ms, Average = 105ms
第二次测试
开始时间:02:13:36
结束时间:02:15:07
用时:1分31秒
    Packets: Sent = 96, Received = 96, Lost = 0 (0% loss),
    Minimum = 0ms, Maximum = 236ms, Average = 9ms
第三次测试
开始时间:02:16:27
结束时间:02:18:50
用时:2分23秒
    Packets: Sent = 91, Received = 91, Lost = 0 (0% loss),
    Minimum = 0ms, Maximum = 179ms, Average = 11ms
平时更新时间:2.1分钟
##########nginx更新服务器##########
版本nginx-0.7.65
worker_processes  1;
events {
    worker_connections  1024;
http {
    include       mime.types;
    default_type  application/octet-stream;
    sendfile        on;
    keepalive_timeout  65;
    server {
        listen       2221;
        server_name  localhost;
        location / {
            root   nod32_update;
            index  index.html index.htm;
        error_page   500 502 503 504  /50x.html;
        location = /50x.html {
            root   html;
第一次测试
开始时间:00:41:00
结束时间:00:42:33
用时:1分33秒
    Packets: Sent = 179, Received = 179, Lost = 0 (0% loss),
    Minimum = 0ms, Maximum = 395ms, Average = 12ms
第二次测试
开始时间:00:49:13
结束时间:00:51:02
用时:1分49秒
    Packets: Sent = 119, Received = 119, Lost = 0 (0% loss),
    Minimum = 0ms, Maximum = 1882ms, Average = 44ms
第三次测试
开始时间:00:57:49
结束时间:00:59:13
用时:1分24秒
    Packets: Sent = 101, Received = 101, Lost = 0 (0% loss),
    Minimum = 0ms, Maximum = 540ms, Average = 18ms
平均更新时间:1.59分钟
##########cherokee更新服务器##########
版本Cherokee-setup-0.5.4
Port 2221
DocumentRoot "C:\Program Files\Cherokee\nod32_update\"
DirectoryIndex index.html
Directory / {
   Handler common
Directory /images {
   Handler file
Extension php {
   Handler phpcgi {
     Interpreter C:\PHP\php-cgi.exe
第一次测试
开始时间:23:47:47
结束时间:23:50:50
用时:3分3秒
    Packets: Sent = 258, Received = 258, Lost = 0 (0% loss),
    Minimum = 0ms, Maximum = 843ms, Average = 20ms
第二次测试
开始时间:00:06:30
结束时间:00:09:09
用时:2分39秒
    Packets: Sent = 236, Received = 236, Lost = 0 (0% loss),
    Minimum = 0ms, Maximum = 689ms, Average = 50ms
第三次测试
开始时间:00:18:26
结束时间:00:19:43
用时:1分17秒
    Packets: Sent = 85, Received = 85, Lost = 0 (0% loss),
    Minimum = 0ms, Maximum = 471ms, Average = 32ms
平均更新时间:2.32分钟
上面的测试结果明显地表现出各平台更新速度之间的差距,虽然影响更新速度的因素包括网速和本机速度(测试中的所有时间数据包括从服务器下载病毒库包的时间以及进行更新病毒库的时间)。但相对而言,也显示出了大概的差别。
同时,为了验证更新过程中各平台对网络的影响,我在更新的过程中采用长PING服务器的方式,查看延时。发现用NOD32自带的更新服务器,
虽然速度很慢,但平均延迟较其他的还是比较低的。
发表于 2010-3-23 06:24:46 | 显示全部楼层
那就把NGINX作为博威NOD企业级用户的御用升级服务器平台
发表于 2010-3-23 08:20:45 | 显示全部楼层
GMT+8, 2026-11-12 23:24 , Processed in 0.040995 second(s), 18 queries .
