查看: 2691|回复: 2
Solaris 10默认完全安装服务集
发表于 2010-3-1 15:04:56 | 显示全部楼层 |阅读模式
# svcs -a
STATE          STIME    FMRI
legacy_run     14:38:47 lrc:/etc/rcS_d/S50sk98sol
legacy_run     14:39:03 lrc:/etc/rc2_d/S10lu
legacy_run     14:39:03 lrc:/etc/rc2_d/S20sysetup
legacy_run     14:39:03 lrc:/etc/rc2_d/S40llc2
legacy_run     14:39:03 lrc:/etc/rc2_d/S42ncakmod
legacy_run     14:39:03 lrc:/etc/rc2_d/S47pppd
legacy_run     14:39:04 lrc:/etc/rc2_d/S70uucp
legacy_run     14:39:04 lrc:/etc/rc2_d/S72autoinstall
legacy_run     14:39:04 lrc:/etc/rc2_d/S73cachefs_daemon
legacy_run     14:39:05 lrc:/etc/rc2_d/S81dodatadm_udaplt
legacy_run     14:39:05 lrc:/etc/rc2_d/S89PRESERVE
legacy_run     14:39:06 lrc:/etc/rc2_d/S94ncalogd
legacy_run     14:39:06 lrc:/etc/rc2_d/S98deallocate
legacy_run     14:39:07 lrc:/etc/rc3_d/S16boot_server
legacy_run     14:39:07 lrc:/etc/rc3_d/S50apache
legacy_run     14:39:07 lrc:/etc/rc3_d/S52imq
legacy_run     14:39:07 lrc:/etc/rc3_d/S80mipagent
legacy_run     14:39:08 lrc:/etc/rc3_d/S84appserv
legacy_run     14:39:08 lrc:/etc/rc3_d/S84patchserver
disabled       14:38:24 svc:/system/metainit:default
disabled       14:38:24 svc:/system/device/mpxio-upgrade:default
disabled       14:38:25 svc:/network/ipfilter:default
disabled       14:38:25 svc:/network/ipsec/ike:default
disabled       14:38:25 svc:/network/ipsec/manual-key:default
disabled       14:38:26 svc:/network/rpc/keyserv:default
disabled       14:38:26 svc:/network/rpc/nisplus:default
disabled       14:38:26 svc:/network/nis/server:default
disabled       14:38:26 svc:/network/dns/client:default
disabled       14:38:26 svc:/network/nis/client:default
disabled       14:38:26 svc:/network/ldap/client:default
disabled       14:38:27 svc:/network/inetd-upgrade:default
disabled       14:38:27 svc:/application/print/server:default
disabled       14:38:27 svc:/network/ntp:default
disabled       14:38:27 svc:/system/patch-finish:delete
disabled       14:38:27 svc:/system/mdmonitor:default
disabled       14:38:27 svc:/system/auditd:default
disabled       14:38:27 svc:/system/pools:default
disabled       14:38:27 svc:/system/rcap:default
disabled       14:38:28 svc:/network/rarp:default
disabled       14:38:28 svc:/network/samba:default
disabled       14:38:28 svc:/network/dhcp-server:default
disabled       14:38:28 svc:/network/nfs/server:default
disabled       14:38:28 svc:/network/winbind:default
disabled       14:38:28 svc:/network/wins:default
disabled       14:38:28 svc:/network/rpc/bootparams:default
disabled       14:38:29 svc:/application/gdm2-login:default
disabled       14:38:30 svc:/application/database/postgresql:version_82_64bit
disabled       14:38:30 svc:/application/management/webmin:default
disabled       14:38:30 svc:/application/database/postgresql_83:default_32bit
disabled       14:38:30 svc:/application/database/postgresql:version_81
disabled       14:38:30 svc:/application/database/postgresql_83:default_64bit
disabled       14:38:30 svc:/milestone/patching:default
disabled       14:38:30 svc:/system/prepatch:default
disabled       14:38:30 svc:/network/ntp4:default
disabled       14:38:31 svc:/network/http:apache2
disabled       14:38:31 svc:/network/tnd:default
disabled       14:38:31 svc:/network/apocd/udp:default
disabled       14:38:31 svc:/network/slp:default
disabled       14:38:31 svc:/network/nis/update:default
disabled       14:38:31 svc:/network/nis/passwd:default
disabled       14:38:31 svc:/network/ipmievd:default
disabled       14:38:31 svc:/network/security/kadmin:default
disabled       14:38:31 svc:/network/security/krb5kdc:default
disabled       14:38:31 svc:/network/nis/xfr:default
disabled       14:38:31 svc:/network/dns/server:default
disabled       14:38:31 svc:/network/ipv4-forwarding:default
disabled       14:38:31 svc:/network/ipv6-forwarding:default
disabled       14:38:31 svc:/network/routing/rdisc:default
disabled       14:38:31 svc:/network/routing/route:default
disabled       14:38:31 svc:/network/routing/ripng:default
disabled       14:38:31 svc:/network/routing/ripng:quagga
disabled       14:38:31 svc:/network/routing/zebra:quagga
disabled       14:38:31 svc:/network/routing/ndp:default
disabled       14:38:31 svc:/network/routing/rip:quagga
disabled       14:38:32 svc:/network/routing/ospf:quagga
disabled       14:38:32 svc:/network/routing/ospf6:quagga
disabled       14:38:32 svc:/network/routing/bgp:quagga
disabled       14:38:32 svc:/network/routing/legacy-routing:ipv4
disabled       14:38:32 svc:/network/routing/legacy-routing:ipv6
disabled       14:38:32 svc:/system/labeld:default
disabled       14:38:32 svc:/system/consadm:default
disabled       14:38:32 svc:/system/pools/dynamic:default
disabled       14:38:32 svc:/system/sar:default
disabled       14:38:33 svc:/system/iscsitgt:default
disabled       14:38:33 svc:/system/tsol-zones:default
disabled       14:38:33 svc:/application/management/common-agent-container-1:default
disabled       14:38:56 svc:/application/x11/xvnc-inetd:default
disabled       14:38:57 svc:/network/login:eklogin
disabled       14:38:57 svc:/network/login:klogin
disabled       14:38:57 svc:/network/comsat:default
disabled       14:38:57 svc:/network/time:dgram
disabled       14:38:57 svc:/network/time:stream
disabled       14:38:58 svc:/network/echo:dgram
disabled       14:38:58 svc:/network/echo:stream
disabled       14:38:58 svc:/network/rexec:default
disabled       14:38:58 svc:/network/discard:dgram
disabled       14:38:58 svc:/network/discard:stream
disabled       14:38:58 svc:/network/chargen:dgram
disabled       14:38:58 svc:/network/chargen:stream
disabled       14:38:58 svc:/network/daytime:dgram
disabled       14:38:58 svc:/network/daytime:stream
disabled       14:38:58 svc:/network/shell:kshell
disabled       14:38:58 svc:/network/security/krb5_prop:default
disabled       14:38:58 svc:/network/uucp:default
disabled       14:38:58 svc:/network/swat:default
disabled       14:38:58 svc:/network/tname:default
disabled       14:38:59 svc:/network/rpc/wall:default
disabled       14:38:59 svc:/network/rpc/rex:default
disabled       14:39:00 svc:/network/rpc/ocfserv:default
disabled       14:39:00 svc:/network/rpc/spray:default
disabled       14:39:01 svc:/network/talk:default
online         14:38:24 svc:/system/svc/restarter:default
online         14:38:25 svc:/network/pfil:default
online         14:38:25 svc:/network/tnctl:default
online         14:38:26 svc:/network/loopback:default
online         14:38:27 svc:/system/installupdates:default
online         14:38:28 svc:/system/filesystem/root:default
online         14:38:28 svc:/milestone/name-services:default
online         14:38:29 svc:/system/scheduler:default
online         14:38:30 svc:/system/boot-archive:default
online         14:38:35 svc:/network/physical:default
online         14:38:36 svc:/system/identity:node
online         14:38:37 svc:/system/filesystem/usr:default
online         14:38:38 svc:/platform/i86pc/eeprom:default
online         14:38:38 svc:/system/keymap:default
online         14:38:42 svc:/system/device/local:default
online         14:38:42 svc:/system/filesystem/minimal:default
online         14:38:43 svc:/system/identity:domain
online         14:38:43 svc:/system/coreadm:default
online         14:38:43 svc:/system/name-service-cache:default
online         14:38:43 svc:/system/rmtmpfiles:default
online         14:38:43 svc:/system/resource-mgmt:default
online         14:38:43 svc:/system/power:default
online         14:38:43 svc:/system/sysevent:default
online         14:38:43 svc:/system/device/fc-fabric:default
online         14:38:44 svc:/milestone/devices:default
online         14:38:44 svc:/system/picl:default
online         14:38:44 svc:/system/pkgserv:default
online         14:38:44 svc:/system/cryptosvc:default
online         14:38:44 svc:/network/ipsec/ipsecalgs:default
online         14:38:45 svc:/network/ipsec/policy:default
online         14:38:45 svc:/milestone/network:default
online         14:38:45 svc:/application/print/ppd-cache-update:default
online         14:38:46 svc:/network/initial:default
online         14:38:46 svc:/network/service:default
online         14:38:47 svc:/system/manifest-import:default
online         14:38:47 svc:/network/iscsi/initiator:default
online         14:38:47 svc:/system/patchchk:default
online         14:38:47 svc:/milestone/single-user:default
online         14:38:48 svc:/system/filesystem/local:default
online         14:38:48 svc:/network/shares/group:default
online         14:38:48 svc:/system/cron:default
online         14:38:48 svc:/network/shares/group:zfs
online         14:38:48 svc:/system/sysidtool:net
online         14:38:49 svc:/system/boot-archive-update:default
online         14:38:49 svc:/application/opengl/ogl-select:default
online         14:38:52 svc:/network/routing-setup:default
online         14:38:53 svc:/network/rpc/bind:default
online         14:38:53 svc:/application/font/fc-cache:default
online         14:38:53 svc:/network/nfs/cbd:default
online         14:38:53 svc:/network/nfs/status:default
online         14:38:53 svc:/network/nfs/mapid:default
online         14:38:53 svc:/system/sysidtool:system
online         14:38:53 svc:/network/nfs/nlockmgr:default
online         14:38:54 svc:/system/postrun:default
online         14:38:54 svc:/platform/i86pc/kdmconfig:default
online         14:38:55 svc:/milestone/sysconfig:default
online         14:38:55 svc:/system/sac:default
online         14:38:55 svc:/system/utmp:default
online         14:38:55 svc:/system/console-login:default
online         14:38:55 svc:/network/inetd:default
online         14:38:56 svc:/application/stosreg:default
online         14:38:56 svc:/application/management/wbem:default
online         14:39:01 svc:/network/rpc/gss:default
online         14:39:01 svc:/network/rpc/meta:default
online         14:39:01 svc:/application/x11/xfs:default
online         14:39:01 svc:/application/font/stfsloader:default
online         14:39:01 svc:/network/rpc/rstat:default
online         14:39:01 svc:/network/login:rlogin
online         14:39:01 svc:/network/ftp:default
online         14:39:01 svc:/network/stlisten:default
online         14:39:01 svc:/network/nfs/client:default
online         14:39:01 svc:/network/shell:default
online         14:39:01 svc:/network/nfs/rquota:default
online         14:39:01 svc:/network/security/ktkt_warn:default
online         14:39:01 svc:/network/telnet:default
online         14:39:01 svc:/network/rpc/smserver:default
online         14:39:01 svc:/network/rpc/metamh:default
online         14:39:02 svc:/network/rpc/cde-ttdbserver:tcp
online         14:39:02 svc:/system/filesystem/autofs:default
online         14:39:02 svc:/network/rpc/mdcomm:default
online         14:39:02 svc:/network/rpc/metamed:default
online         14:39:02 svc:/network/rpc/rusers:default
online         14:39:02 svc:/network/rpc/cde-calendar-manager:default
online         14:39:02 svc:/network/cde-spc:default
online         14:39:02 svc:/network/stdiscover:default
online         14:39:02 svc:/network/finger:default
online         14:39:02 svc:/network/rpc-100235_1/rpc_ticotsord:default
online         14:39:02 svc:/system/filesystem/volfs:default
online         14:39:02 svc:/network/ssh:default
online         14:39:02 svc:/system/system-log:default
online         14:39:02 svc:/system/dumpadm:default
online         14:39:03 svc:/network/smtp:sendmail
online         14:39:03 svc:/application/management/seaport:default
online         14:39:04 svc:/application/management/snmpdx:default
online         14:39:06 svc:/system/fmd:default
online         14:39:06 svc:/application/management/dmi:default
online         14:39:06 svc:/milestone/multi-user:default
online         14:39:07 svc:/application/management/sma:default
online         14:39:08 svc:/milestone/multi-user-server:default
online         14:39:09 svc:/system/zones:default
online         14:39:10 svc:/application/graphical-login/cde-login:default
online         14:39:10 svc:/application/cde-printinfo:default
online         14:39:11 svc:/system/basicreg:default
online         14:39:43 svc:/system/webconsole:console
offline        14:38:30 svc:/application/print/ipp-listener:default
offline        14:38:57 svc:/application/print/rfc1179:default
GMT+8, 2026-10-18 18:43 , Processed in 0.036652 second(s), 18 queries .
