查看: 2624|回复: 0
FreeBSD当前版本的支持时间表
发表于 2010-1-29 15:40:25 | 显示全部楼层 |阅读模式
The current designation and estimated lifetimes of the currently supported branches are given below. The Estimated EoL (end-of-life) column gives the earliest date on which that branch is likely to be dropped. Please note that these dates may be extended into the future, but only extenuating circumstances would lead to a branch's support being dropped earlier than the date listed.
下表给出的是当前所支持版本的名称及预计生命期。Estimated EOL(预计停产)列给出的是该版本将要不受支持的最早日期。请注意这些日期在将来可能会延长,并且除非特殊情况,不会在此日期之前停止对该版本的支持。
BranchReleaseTypeRelease DateEstimated EoL
RELENG_6n/an/an/aNovember 30, 2010
RELENG_6_36.3-RELEASEExtendedJanuary 18, 2008January 31, 2010
RELENG_6_46.4-RELEASEExtendedNovember 28, 2008November 30, 2010
RELENG_7n/an/an/alast release + 2 years
RELENG_7_17.1-RELEASEExtendedJanuary 4, 2009January 31, 2011
RELENG_7_27.2-RELEASENormalMay 4, 2009May 31, 2010
RELENG_8n/an/an/alast release + 2 years
RELENG_8_08.0-RELEASENormalNovember 25, 2009November 30, 2010
GMT+8, 2026-10-18 18:42 , Processed in 0.031125 second(s), 18 queries .
