查看: 2028|回复: 0
Pix with mail server access on DMZ
发表于 2007-5-4 15:49:13 | 显示全部楼层 |阅读模式
Pix with mail server access on DMZ [/td]
PIX Version 6.2(2)
!--- These commands name and set the security level
!--- for their respective interfaces.
nameif ethernet2 dmz security50
hostname SanQuentin
domain-name noplace.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
no names
!--- This statement creates an access list, named smtp, which
!--- allows SMTP traffic originating from anywhere to reach the
!--- server at 209.164.3.5. Note: There is one and only one
!--- access list allowed per interface per direction (for example, inbound
!--- on the outside interface). Because of this limitation, any additional
!--- lines needing to be placed in the access list will need to be
!--- specified here. If the server in question is not SMTP, replace
!--- the occurrences of smtp with www, dns, pop3, or
!--- whatever else may be required.
access-list smtp permit tcp any host 209.164.3.5 eq smtp
pager lines 24
logging on
logging timestamp
no logging standby
logging console debugging
logging monitor debugging
logging buffered debugging
logging trap debugging
no logging history
logging facility 23
logging queue 512
!--- These commands instruct the PIX to auto-sense the media
!--- attached to each interface.
interface ethernet0 auto
interface ethernet1 auto
interface ethernet 2 auto
mtu outside 1500
mtu inside 1500
mtu dmz 1500
!--- These commands set the IP address of the respective interfaces.
ip address inside 192.168.1.1 255.255.255.252
ip address outside 209.164.3.1 255.255.255.252
ip address dmz 172.16.128.1 255.255.255.0
no failover
arp timeout 14400
!--- These commands establish port address translation (PAT) for
!--- traffic originating on the inside of the PIX and traveling
!--- outside (beyond) the PIX.
global (outside) 1 209.164.3.129
nat (inside) 1 192.168.1.0 255.255.255.0
!--- This static creates a translation between the legal (outside) address
!--- of the server (209.164.3.5) and the RFC 1918 (inside) address (172.16.128.103).
static (dmz,outside) 209.164.3.5 172.16.128.103 netmask 255.255.255.255
!--- This static essentially prevents translation of the 192.168.1.x
!--- inside network when sending packets to the DMZ. Literally speaking,
!--- it creates a translation from 192.168.1.x to 192.168.1.x.
static (inside,dmz) 192.168.1.0 192.168.1.0 netmask 255.255.255.0
!--- This statement applies the access list created above to the
!--- interface named "outside". Because it is applied inbound, the
!--- PIX will now check all incoming packets against this list,
!--- dropping all packets not explicitly permitted.
access-group smtp in interface outside
!--- This command instructs the PIX to hand all other packets not
!--- destined for directly-connected networks to the router at
!--- 209.164.3.2 (the outside router).
route outside 0.0.0.0 0.0.0.0 209.164.3.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
terminal width 80
Cryptochecksum:d66eb04bc477f21ffbd5baa21ce0f85a
: end
!--- Alternate command:
!--- conduit permit tcp host 209.164.3.5 eq smtp any
!--- This command, in earlier PIX software versions, serves the same purpose
!--- as the access-list and access-group commands shown above.
!--- This command replaces the access-list and access-group
!--- commands presented above.
GMT+8, 2026-11-12 11:30 , Processed in 0.037947 second(s), 18 queries .
