查看: 18102|回复: 11
在pix或asa如何防止内网用户乱改ip配置案例
发表于 2007-5-4 15:36:02 | 显示全部楼层 |阅读模式
防止内网用户乱该ip地址,用户只能用给定的ip,如果改ip地址,则无法访问网络资源。
例如:做了下述配置后(arp inside 10.64.64.29 000f.b0d8.a504),mac地址为000f.b0d8.a504的pc
只能使用ip10.64.64.29来访问网络资源,如果该ip则无法访问。
pix515e# sh run
: Saved
PIX Version 7.2(1)
hostname pix515e
domain-name cisco
enable password N7FecZuSHJlVZC2P encrypted
做名字解析
names
name 10.64.64.113 chengxiaojie
name 10.64.64.13 dhcp
name 10.64.64.71 liuyongjun
name 10.64.64.72 liuyongjun-ibm
name 10.64.64.39 lixiaoliang
name 10.64.64.103 lixuesong
name 10.64.64.17 lulianying
name 10.64.64.92 qizuomeng
name 10.64.64.69 wangzhili
name 10.64.64.105 xingzhonghe
name 10.64.64.45 tanjun
name 10.64.64.108 zhangyi
name 10.64.64.178 hujian
name 10.64.64.93 ibm220
name 10.64.64.62 jiling
name 10.64.64.111 yangliu
name 10.64.64.112 wangsishen
name 10.64.64.158 wangyuguo
name 10.64.64.52 lishihai
name 10.64.64.78 office-teacher
name 10.64.64.48 yangjin
name 10.64.64.104 wutao
name 10.64.64.63 zangdong
name 10.64.64.80 xiaoguangyue
name 10.64.64.14 ibm235
name 10.64.64.222 lixuesong-dell
name 10.64.64.75 maxiaopeng
name 10.64.64.215 lintao
name 10.64.64.199 machi
name 10.64.64.216 liuxuesong
name 10.64.64.246 jiachangjing
name 10.64.64.61 chufw
interface Ethernet0
nameif outside
security-level 0
ip address X.X.76.26 255.255.255.0
interface Ethernet1
nameif inside
security-level 100
ip address 10.64.64.2 255.255.240.0
interface Ethernet2
nameif dmz
security-level 80
ip address 192.168.0.1 255.255.255.0
passwd N7FecZuSHJlVZC2P encrypted
time-range worktime
periodic daily 8:00 to 17:00
ftp mode passive
clock timezone CST 8
dns domain-lookup outside
dns server-group DefaultDNS
name-server 219.150.32.132
domain-name cisco
做object-group以便在acl里被调用(注:object-group是个好东东,可以大大简化acl的配置)
object-group network www
network-object host xingzhonghe
network-object host chengxiaojie
network-object host dhcp
network-object host liuxuesong
network-object host wangzhili
network-object host liuyongjun
network-object host liuyongjun-ibm
network-object host lulianying
network-object host chufw
network-object host jiachangjing
network-object host maxiaopeng
network-object host 10.64.64.255
object-group network guest
network-object 10.64.66.112 255.255.255.240
object-group network caiwu
network-object 10.64.66.0 255.255.255.224
object-group service netmeeting tcp
port-object range 1503 1503
port-object range h323 h323
object-group network worktime
network-object host wutao
network-object host zhangyi
network-object host yangliu
network-object host wangsishen
network-object host wangyuguo
network-object host 10.64.64.169
network-object host 10.64.64.18
network-object host machi
network-object host lintao
network-object host lixuesong-dell
network-object host 10.64.64.247
network-object host 10.64.64.29
network-object host 10.64.64.30
network-object host yangjin
network-object host lishihai
network-object host 10.64.64.55
network-object host jiling
network-object host office-teacher
access-list outside_access_in extended permit icmp any any echo-reply
access-list outside_access_in extended permit tcp any any object-group netmeeting
调用上述的object-group到acl
access-list inside_access_in extended deny ip any 192.168.0.0 255.255.255.0
access-list inside_access_in extended permit ip object-group caiwu 192.168.0.0 255.255.255.0
access-list inside_access_in extended permit ip object-group www any
access-list inside_access_in extended permit ip object-group guest any inactive
access-list inside_access_in extended deny tcp any any eq 1863
access-list inside_access_in extended permit ip host lixiaoliang host 211.147.77.98
access-list inside_access_in extended permit ip host qizuomeng host 211.147.77.98
access-list inside_access_in extended permit ip object-group worktime any time-range worktime
access-list inside_access_in extended permit ip host ibm235 any time-range worktime inactive
access-list remote_splitTunnelAcl standard permit 10.64.64.0 255.255.240.0
access-list inside_nat0_outbound extended permit ip 10.64.64.0 255.255.240.0 1.1.1.0 255.255.255.0
access-list outside_cryptomap extended permit ip any 1.1.1.0 255.255.255.0
access-list caiwu_splitTunnelAcl standard permit 192.168.0.0 255.255.255.0
access-list outside_cryptomap_1 extended permit ip any 1.1.1.0 255.255.255.0
access-list dmz_nat0_outbound extended permit ip 192.168.0.0 255.255.255.0 1.1.1.0 255.255.255.0
pager lines 24
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip local pool remote 1.1.1.1-1.1.1.254 mask 255.255.255.0
ip local pool caiwu 2.2.2.1-2.2.2.254 mask 255.255.255.0
no failover
asdm image flash:/asdm.bin
no asdm history enable
把ip和mac绑定
arp inside 10.64.64.247 000b.2f04.7dd8
arp inside 10.64.64.169 0016.17f2.2eb3
arp inside lintao 000a.e6b2.c4c6
arp inside liuxuesong 00e0.4c58.b7cd
arp inside lishihai 000a.e69b.f4dc
arp inside ibm235 0009.6ba5.49c5
arp inside maxiaopeng 000c.764d.6aa8
arp inside xiaoguangyue 0011.09b4.6f25
arp inside zangdong 00e0.4cc1.2a14
arp inside wutao 0013.d47d.0c36
arp inside office-teacher 0090.9626.7da7
arp inside yangjin 00e0.4d01.6b1b
arp inside wangyuguo 00e0.4c21.471d
arp inside wangsishen 0015.c50f.92a5
arp inside yangliu 0015.f299.7f6c
arp inside jiling 00e0.4cc1.2a34
arp inside hujian 0011.252f.8613
arp inside ibm220 0002.556d.0037
arp inside jiachangjing 00e0.4d01.6b30
arp inside tanjun 0013.7222.5fe5
arp inside wangzhili 000d.6004.c197
arp inside lixiaoliang 0014.782f.b989
arp inside liuyongjun-ibm 0010.c6de.2686
arp inside lulianying 0016.3563.db1b
arp inside liuyongjun 0000.e25a.8580
arp inside lixuesong 0017.3152.8e78
arp inside chengxiaojie 0016.3564.8a6b
arp inside xingzhonghe 00e0.4c60.a8da
arp inside dhcp 0014.5e2b.77b5
arp inside zhangyi 0013.7222.4819
arp inside lixuesong-dell 0018.8ba2.d1c5
arp inside machi 000a.e6b5.0600
arp inside 10.64.64.18 0015.c510.12d4
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 10.64.64.0 255.255.240.0
nat (dmz) 0 access-list dmz_nat0_outbound
static (inside,outside) tcp interface 1503 chufw 1503 netmask 255.255.255.255
static (inside,outside) tcp interface h323 chufw h323 netmask 255.255.255.255
access-group outside_access_in in interface outside
应用acl到inside端口
route outside 0.0.0.0 0.0.0.0 X.X.76.25 1
timeout xlate 3:00:00
group-policy caiwu internal
group-policy caiwu attributes
dns-server value 219.150.32.132
vpn-tunnel-protocol IPSec
split-tunnel-network-list value caiwu_splitTunnelAcl
group-policy remote internal
group-policy remote attributes
split-tunnel-network-list value remote_splitTunnelAcl
username chufw password hs6C0g7Y0Zza/dVN encrypted privilege 15
username chufw attributes
vpn-group-policy remote
vpn-framed-ip-address 1.1.1.111 255.255.255.0
http server enable
http chufw 255.255.255.255 inside
http 219.148.242.228 255.255.255.255 outside
http 219.148.242.227 255.255.255.255 outside
http 1.1.1.111 255.255.255.255 outside
no snmp-server location
no snmp-server contact
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-SHA
crypto map outside_map 20 ipsec-isakmp dynamic outside_dyn_map
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal  20
tunnel-group remote type ipsec-ra
tunnel-group remote general-attributes
address-pool remote
default-group-policy remote
tunnel-group remote ipsec-attributes
pre-shared-key *
tunnel-group caiwu type ipsec-ra
tunnel-group caiwu general-attributes
address-pool remote
default-group-policy caiwu
tunnel-group caiwu ipsec-attributes
pre-shared-key *
telnet chufw 255.255.255.255 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
class-map inspection_default
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
ntp server 207.46.130.100 source outside
tftp-server inside chufw pix
prompt hostname context
Cryptochecksum:c02e836587f08fa6ce4699df28408774
: end
pix515e#
发表于 2007-5-7 08:53:20 | 显示全部楼层
配置包含内容比较多,很典型,收藏
发表于 2007-5-13 19:29:01 | 显示全部楼层
注意:使用ARP绑定的时候要将整个网段所有的IP都做绑定,否则达不到效果
比如:如果你只绑定了如下几个IP
那么我只要不使用这三个IP,是都可以上网的
所以应该封杀整个网段的所有IP,即使没有计算机来对应,也应该将些IP绑定到一个无效的MAC地址上,
实际上最佳的解决方案是,在策略里使用网络组进行配置,然后绑定网络组中的所有IP地址,这样会省去很多事情。
发表于 2007-5-14 00:31:10 | 显示全部楼层
回复 #3 我心飞翔 的帖子
这只是把ip和mac绑定吗?  如果ip换了还可以上网吗.不是我们熟悉的.把mac绑定了.无论你换那个ip只针对这个mac起作用吗.
发表于 2007-5-14 00:34:06 | 显示全部楼层
回复 #3 我心飞翔 的帖子
还是除了这三个mac以外的....才可以随便改啊.  期待我心飞翔的回复
发表于 2007-5-14 08:00:58 | 显示全部楼层
不是除了这三个MAC以外,而是除了这三个IP以外,你可以使用其它的IP,继续上网
发表于 2007-5-14 23:59:10 | 显示全部楼层
可以这样来理解,在PIX上配置arp命令之后,PIX就会在相应的接口检测IP地址和MAC地址的对应关系,PIX检测的依据就是使用ARP命令建立的MAC地址和IP地址的对应表,如果对应表中不包含相应的IP地址和MAC地址的对应关系,那么将不对此IP进行检测,也就是说你可以使用未配置ARP命令的IP地址来上网的。
发表于 2007-5-15 22:14:10 | 显示全部楼层
感谢楼主
开始理解错了.不是mac地址的绑定对吧.而是通过arp实现的..mac和ip的对应..而arp检测的只是ip对吧.不会对mac进行检查.
发表于 2007-5-15 22:53:55 | 显示全部楼层
我一开始也是这样理解的,认为只要使用ARP命令把IP和MAC地址一绑,就可以限制改IP了,即使他改了IP也不应该能上网,后来,我做了几个相关的实验,才明白过来,实验是这样做的,环境如下:PIX的内口地址是192.168.1.1,内网放了两台电脑,电脑一的IP是192.168.1.100,MAC地址是AAAA.AAAA.AAAA        电脑二的IP是192.168.1.200,MAC地址是BBBB.BBBB.BBBB        然后我在PIX上用户配置命令arp inside 192.168.1.100 AAAA.AAAA.AAAA  接下来开始测试效果,使用电脑一上网,一切正常,可以上网,然后把电脑一的IP改为192.168.1.150,本以为这样这台机器就上不了网了,结果一测试,发现还可以上网,晕了,
然后在PIX上又加上了一条命令arp inside 192.168.1.150 0000.0000.0000,再进行测试,发现这时这台MAC地址为AAAA.AAAA.AAAA的机器才不能上网了,可是把机器IP改为192.168.1.123,又可以上网了,
同样测试了一下第二台机器,结果也是一样的,我用的PIX是6.3版本的,7.0版本的我没实测,估计应该也是这样,改天我测试一下,然后再告诉你结果。
经过仔细思考,才明白不是普通我们想像中的mac地址的绑定.你上网的数据包经过防火墙时,防火墙首先查看包中的IP地址,如果发现对应表中有你机器的IP,那么将检测你机器的MAC地址是不是表中所对应的MAC地址,如果不是就阻断,如果是就放行,如果对应表中没有你机器的IP,恭喜你,你解放了,愿意咋着就咋着。
发表于 2007-7-5 16:20:10 | 显示全部楼层
明白了,类似于ACL吧
但不同的是ACL末尾是隐含deny any any,不匹配的话全部拒绝,而这里是permit any any !
GMT+8, 2026-11-12 11:19 , Processed in 0.043273 second(s), 18 queries .
