查看: 2747|回复: 0
VM pixemu 模拟PIX 7.21成功!
发表于 2007-5-3 04:40:34 | 显示全部楼层 |阅读模式
VM pixemu 模拟PIX 7.21成功! 2007-04-16 01:14:51
 标签:VM pixemu PIX
版权声明:原创作品,允许转载,转载时请务必以超链接形式标明文章 原始出处 、作者信息和本声明。否则将追究法律责任。http://xiaofan4444.51cto.com/blog/120346/23854
[root@localhost root]# cd /
[root@localhost /]# ./pixemu -net nic,vlan=1,macaddr=00:aa:00:00:02:01 -net tap,vlan=1,script=if1up -net nic,vlan=2,macaddr=00:aa:00:00:02:02 -net tap,vlan=2,script=if2up -serial stdio -m 128 FLASH
Could not open '/dev/kqemu' - QEMU acceleration layer not activated
Values read from ini file::
serial=12345678 (305419896)
image="pix"
key=0,0,0,0
image file  read 18374703 bytes, @100000
128MB RAM
Total NICs found: 2
     i82559 Ethernet at irq 11  MAC: 00aa.0000.0201
     i82559 Ethernet at irq  9  MAC: 00aa.0000.0202
BIOS Flash=am29f400b @ 0xd8000
Initializing flashfs...
flashfs[7]: 2 files, 2 directories
flashfs[7]: 0 orphaned files, 0 orphaned directories
flashfs[7]: Total bytes: 16128000
flashfs[7]: Bytes used: 2048
flashfs[7]: Bytes available: 16125952
flashfs[7]: flashfs fsck took 4 seconds.
flashfs[7]: Initialization complete.
Running Activation Key: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
This activation key is not valid, use default settings only
                            C i s c o  S y s t e m s
Cisco PIX Security Appliance Software Version 7.2(1)
Copyright (c) 1996-2006 by Cisco Systems, Inc.
                Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
                Cisco Systems, Inc.
                170 West Tasman Drive
                San Jose, California 95134-1706
pixfirewall> en
Password:
pixfirewall#
pixfirewall# sh interface
Interface Ethernet0 "", is administratively down, line protocol is up
  Hardware is i82559, BW 100 Mbps
        Auto-Duplex(Full-duplex), Auto-Speed(100 Mbps)
        Available but not configured via nameif
        MAC address 00aa.0000.0202, MTU not set
        IP address unassigned
        0 packets input, 0 bytes, 0 no buffer
        Received 0 broadcasts, 0 runts, 0 giants
        0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
        0 L2 decode drops
        0 packets output, 0 bytes, 0 underruns
        0 output errors, 0 collisions, 0 interface resets
        0 babbles, 0 late collisions, 0 deferred
        0 lost carrier, 0 no carrier
        input queue (curr/max blocks): hardware (128/128) software (0/0)
        output queue (curr/max blocks): hardware (1/0) software (0/0)
Interface Ethernet1 "", is administratively down, line protocol is up
        MAC address 00aa.0000.0201, MTU not set
        0 L2 decode drops
pixfirewall# sh tech
pixfirewall# sh tech-support
Compiled on Wed 31-May-06 14:45 by root
System image file is "Unknown, monitor mode tftp booted image"
Config file at boot was "startup-config"
pixfirewall up 3 mins 8 secs
Hardware:   PIX-525, 128 MB RAM, CPU Pentium II 1 MHz
Flash E28F128J3 @ 0xfff00000, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
0: Ext: Ethernet0           : address is 00aa.0000.0202, irq 9
1: Ext: Ethernet1           : address is 00aa.0000.0201, irq 11
The Running Activation Key is not valid, using default settings:
Licensed features for this platform:
Maximum Physical Interfaces : 6
Maximum VLANs               : 25
Inside Hosts                : Unlimited
Failover                    : Disabled
VPN-DES                     : Disabled
VPN-3DES-AES                : Disabled
Cut-through Proxy           : Enabled
Guards                      : Enabled
URL Filtering               : Enabled
Security Contexts           : 0
GTP/GPRS                    : Disabled
VPN Peers                   : Unlimited
This platform has a Restricted (R) license.
Serial Number: 305419896
Configuration has not been modified since last system restart.
------------------ show clock ------------------
16:50:28.732 UTC Sun Apr 15 2007
------------------ show memory ------------------
Free memory:        96634456 bytes (72%)
Used memory:        37583272 bytes (28%)
Total memory:      134217728 bytes (100%)
------------------ show conn count ------------------
0 in use, 0 most used
------------------ show xlate count ------------------
------------------ show blocks ------------------
  SIZE    MAX    LOW    CNT
     4    100    100    100
    80    100    100    100
   256    100    100    100
  1550   1775   1511   1519
  2048    100    100    100
------------------ show blocks queue history detail ------------------
History buffer memory usage: 2136 bytes (default)
------------------ show interface ------------------
        0 L2 decode drops
  Control Point Interface States:
        Interface number is unassigned
        0 L2 decode drops
------------------ show cpu usage ------------------
CPU utilization for 5 seconds = 0%; 1 minute: 0%; 5 minutes: 0%
------------------ show cpu hogging process ------------------
------------------ show process ------------------
    PC       SP       STATE       Runtime    SBASE     Stack Process
Mwe 00c6559c 018d3cd0 01370380          0 01663050 15616/16384 emweb/cifs
Lwe 001071ec 01696a64 013703f0          0 01694a90 8132/8192 block_diag
Mrd 00218467 017d3ad4 01370490          0 017cfb50 16084/16384 Dispatch Unit
Mwe 00118d85 01825864 01370380          0 018238b0 7864/8192 Reload Control Thread
Mwe 0011ddd6 0182a9b4 01372328          0 01828d30 7256/8192 aaa
Lwe 00217191 01833174 0137b450          0 018311b0 7524/8192 dbgtrace
Msi 00259aac 01835264 01370380          0 018332d0 7292/8192 EoU-startup
Msi 004a63ae 018394e4 01370380          0 01837510 7968/8192 557statspoll
Mwe 0100b8ad 0185f124 01370380          0 0185d180 7848/8192 Chunk Manager
Msi 0088de2e 0186730c 01370380          0 01865358 7856/8192 PIX Garbage Collector
Lsi 00e74984 0186944c 01370380          0 01867478 7552/8192 route_process
Mwe 0087da54 01879a0c 012c9148          0 01877a48 8116/8192 IP Address Assign
Mwe 00a9ded1 0187e4bc 012d4578          0 0187c4f8 8116/8192 QoS Support Module
Mwe 008f4fc1 01880614 012ca238          0 0187e650 8116/8192 Client Update Task
Lwe 0102995e 01882ed4 01370380         16 01880f30 7908/8192 Checkheaps
Mwe 00afb9e5 018891f4 01370380          0 01887290 7428/8192 Session Manager
Mwe 00c21655 01893afc 0229ed78          0 0188ffe8 14768/16384 uauth
Mwe 00bb1925 01896084 012e9228          0 018940c0 7524/8192 Uauth_Proxy
Mwe 00c1df31 0189c3a4 012ee948          0 0189a420 7712/8192 SMTP
Mwe 00c0b551 0189e484 012ee8e8          0 0189c540 7412/8192 Logger
Mwe 00c0b87e 018a0604 01370380          0 0189e660 7492/8192 Thread Logger
Mwe 00f08fba 018b0f04 01339658          0 018aef60 7188/8192 vpnlb_thread
Msi 00b11e54 01974e5c 01370380          0 01972e88 8000/8192 emweb/cifs_timer
Msi 005a0500 018465dc 01370380          0 01844648 7476/8192 arp_timer
Mwe 005aa954 019cc3cc 01388920          0 019ca458 7960/8192 arp_forward_thread
Mwe 00c25d91 01a1f54c 012eebb8          0 01a1d598 7968/8192 tcp_fast
Mwe 00c25b5d 01a21574 012eebb8          0 01a1f5c0 7968/8192 tcp_slow
Mwe 00c3fe79 01a3237c 012efa78          0 01a303c8 8100/8192 udp_timer
Mwe 00198977 01855fd4 01370380          0 01854020 8016/8192 CTCP Timer process
Mwe 001b1fb6 0185835c 0184c7b0          0 018563e8 7728/8192 IPsec message handler
Msi 001c118c 0203e974 01370380          0 0203c9d0 7952/8192 CTM message handler
Mwe 00ea6e2b 021791dc 01370380          0 02177248 7984/8192 L2TP data daemon
Mwe 00ea746b 0217b214 01370380          0 02179270 8000/8192 L2TP mgmt daemon
Mwe 00e92c1e 021b32fc 01332de8          0 021af378 16260/16384 ppp_timer_thread
Msi 00f09a9f 021b5334 01370380          0 021b33a0 7936/8192 vpnlb_timer_thread
Mwe 00acb2f0 0222962c 01370380          0 02227678 8016/8192 ICMP event handler
Mwe 0080bd0b 0222d79c 01370380          0 022297e8 16160/16384 IP Background
Mwe 0020fe20 022768fc 0129fe58          0 02256978 126656/131072 tmatch compile thread
Mwe 009c71f5 022e9e54 01370380          0 022e5e90 16072/16384 Crypto PKI RECV
Mwe 009c7c9a 022ebf14 01370380          0 022e9fb0 7784/8192 Crypto CA
Lsi 008a2808 0231b2bc 01370380          0 023192e8 8000/8192 uauth_urlb clean
Lwe 00887cff 0236208c 01370380          0 023600e8 7088/8192 pm_timer_thread
Mwe 00514557 02365654 01370380          0 023636b0 8000/8192 IKE Timekeeper
Mwe 005066c3 0236aabc 012bb878          0 02366e28 15432/16384 IKE Daemon
Mwe 00bc2730 0236e764 012ed898          0 0236c7b0 8100/8192 RADIUS Proxy Event Daemon
Mwe 00b93536 02370754 01884088          0 0236e8d0 7184/8192 RADIUS Proxy Listener
Mwe 00bc28c7 02372994 01370380          0 023709f0 8000/8192 RADIUS Proxy Time Keeper
Mwe 00625f20 023749a4 0169f97c          0 02372b10 7492/8192 Integrity FW Task
M*  0082f8d2 0009ff0c 01370490          1 02384538 25136/32768 ci/console
Msi 008bc3ac 0238e41c 01370380          0 0238c658 6648/8192 update_cpu_usage
Msi 008bd125 023987d4 01370380          0 023968d0 7792/8192 NIC status poll
Mwe 00625f20 0239ca64 0169f9c8          0 0239ab10 7844/8192 System Ready
Mwe 00edac85 02395dd4 01338c10          0 02393e20 8100/8192 vpnfol_thread_msg
Msi 00ee06fa 01852b6c 01370380          0 01850bc8 7952/8192 vpnfol_thread_timer
Mwe 00edefaa 023aebec 01338d78          0 023acc58 8068/8192 vpnfol_thread_sync
Msi 00ee0294 023b0c34 01370380          0 023aec80 7968/8192 vpnfol_thread_unsent
-     -        -         -         99344    -         -     scheduler
-     -        -         -         99436    -         -     total elapsed
------------------ show failover ------------------
ERROR: Command requires failover license
------------------ show traffic ------------------
Aggregated Traffic on Physical Interface
Ethernet0:
        received (in 197.940 secs):
                0 packets       0 bytes
                0 pkts/sec      0 bytes/sec
        transmitted (in 197.940 secs):
                0 packets       0 bytes
      1 minute input rate 0 pkts/sec,  0 bytes/sec
      1 minute output rate 0 pkts/sec,  0 bytes/sec
      1 minute drop rate, 0 pkts/sec
      5 minute input rate 0 pkts/sec,  0 bytes/sec
      5 minute output rate 0 pkts/sec,  0 bytes/sec
      5 minute drop rate, 0 pkts/sec
Ethernet1:
        received (in 198.980 secs):
                0 packets       0 bytes
        transmitted (in 198.980 secs):
                0 packets       0 bytes
------------------ show perfmon ------------------
PERFMON STATS:    Current      Average
Xlates               0/s          0/s
Connections          0/s          0/s
TCP Conns            0/s          0/s
UDP Conns            0/s          0/s
URL Access           0/s          0/s
URL Server Req       0/s          0/s
TCP Fixup            0/s          0/s
TCP Intercept        0/s          0/s
HTTP Fixup           0/s          0/s
FTP Fixup            0/s          0/s
AAA Authen           0/s          0/s
AAA Author           0/s          0/s
AAA Account          0/s          0/s
------------------ show counters ------------------
Protocol     Counter                     Value   Context
------------------ show mode ------------------
Security context mode: single
------------------ show history ------------------
  en
  sh interface
  sh tech-support
------------------ show firewall ------------------
Firewall mode: Router
------------------ show running-config ------------------
: Saved
PIX Version 7.2(1)
hostname pixfirewall
enable password <removed>
names
interface Ethernet0
shutdown
no nameif
no security-level
no ip address
interface Ethernet1
shutdown
no nameif
no security-level
no ip address
passwd <removed>
ftp mode passive
pager lines 24
no asdm history enable
arp timeout 14400
timeout xlate 3:00:00
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh timeout 5
console timeout 0
prompt hostname context
Cryptochecksum:00000000000000000000000000000000
: end
------------------ show startup-config errors ------------------
INFO: No configuration errors
------------------ console logs ------------------
Message #1 : Message #2 : Message #3 : Message #4 : Message #5 : Message #6 : Message #7 : Message #8 : Message #9 : Message #10 : Message #11 : Message #12 : Message #13 : Message #14 :
Total NICs found: 2
Message #15 :      Message #16 : i82559 Ethernet at irq 11Message #17 :   MAC: 00aa.0000.0201
Message #18 :      Message #19 : i82559 Ethernet at irq  9Message #20 :   MAC: 00aa.0000.0202
Message #21 : BIOS Flash=am29f400b @ 0xd8000
Message #22 :
Initializing flashfs...Message #23 :
flashfs[7]: 2 files, 2 directoriesMessage #24 :
flashfs[7]: 0 orphaned files, 0 orphaned directoriesMessage #25 :
flashfs[7]: Total bytes: 16128000Message #26 :
flashfs[7]: Bytes used: 2048Message #27 :
flashfs[7]: Bytes available: 16125952Message #28 :
flashfs[7]: flashfs fsck took 4 seconds.Message #29 :
flashfs[7]: Initialization complete.Message #30 :
Message #31 :
Message #32 : Running Message #33 : Activation Key: Message #34 : 0x00000000 Message #35 : 0x00000000 Message #36 : 0x00000000 Message #37 : 0x00000000 Message #38 : 0x00000000 Message #39 :
Message #40 :
Message #41 :   --------------------------------------------------------------------------
Message #42 :                                  .            .
Message #43 :                                  |            |
Message #44 :                                 |||          |||
Message #45 :                               .|| ||.      .|| ||.
Message #46 :                            .:||| | |||:..:||| | |||:.
Message #47 :                             C i s c o  S y s t e m s
Message #48 :   --------------------------------------------------------------------------
Message #49 :
Message #50 :
Message #51 : Copyright (c) 1996-2006 by Cisco Systems, Inc.
Message #52 :                 Restricted Rights Legend
Message #53 : Use, duplication, or disclosure by the Government is
Message #54 : subject to restrictions as set forth in subparagraph
Message #55 : (c) of the Commercial Computer Software - Restricted
Message #56 : Rights clause at FAR sec. 52.227-19 and subparagraph
Message #57 : (c) (1) (ii) of the Rights in Technical Data and Computer
Message #58 : Software clause at DFARS sec. 252.227-7013.
Message #59 :                 Cisco Systems, Inc.
Message #60 :                 170 West Tasman Drive
Message #61 :                 San Jose, California 95134-1706
pixfirewall#
出自 51CTO.COM博客
  VM pixemu 模拟PIX 7.02
GMT+8, 2026-11-12 09:00 , Processed in 0.039978 second(s), 18 queries .
