查看: 4760|回复: 6
cisco 3560 qinq 支持 ios 新 feature
发表于 2009-12-1 13:45:49 | 显示全部楼层 |阅读模式
OVERVIEW
Cisco Systems® announces Cisco IOS® Software updates for Cisco® Catalyst® 3750, 3560, 3550, & 2970 series intelligent Ethernet switches and Cisco Gigabit Ethernet Switch Module (CGESM). This product bulletin contains content and delivery information for Cisco IOS Software Release 12.2(25)SE. For more information about the Cisco IOS Software release process, see Product Bulletin 537.
The Cisco Gigabit Ethernet Switch Module (CGESM) is an integrated OEM Ethernet blade switch from Cisco built for the HP BladeSystem chassis.
QinQ, Per ASIC per VLAN policing, L2PT, and DSCP transparency are features required for Metro Ethernet applications and enterprise deployments include QinQ, Per ASIC per VLAN policing, Layer 2 Tunneling Protocol (L2TP), and differentiated services code point (DSCP) transparency. These features, currently on Cisco Catalyst 3550 Series switches, are added to Cisco Catalyst 3750 and 3560 series switches with this software release. Their behavior is identical on all three series.
Support for Bidirectional Cisco Discovery Protocol version 2 is added to Cisco Catalyst 3750, 3560, and 3550 series Power over Ethernet (PoE) capable switches. This feature enables the switch to power up Cisco's next-generation IP phones. Without this support, phones such as the Cisco IP Phone 7970G will not power up in full-power mode (requires 12W at peak) but stay in low-power mode (requires 6.3W at peak).
This release adds PoE budgeting enhancements for maximum wattage and static wattage to PoE-capable Cisco Catalyst 3750 and 3560 series switches. This power management function is applicable on a 48-port PoE platform. The new maximum wattage feature specifies the maximum wattage allowed on a port and can be used to disallow higher-powered Cisco powered devices if they are connected. If a device asks the switch for more than the maximum power, the switch shuts off power to the port and the power allocated to that port is reclaimed into the global power budget. If the device's IEEE class is greater than the allowed power, the switch does not supply power to the port. The new static wattage feature allows the switch to allocate inline power for a static port when it is configured with a "static" designation, rather then when a powered device is discovered. The port is not adjusted in response to the device or its IEEE class.
Secure Sockets Layer (SSL) support is added to all switches addressed by this product bulletin. SSL provides a secure means to use Web-based tools such as HTML-based device managers.
A new packet-based broadcast storm control feature is added to all switches addressed by this product bulletin. It allows you to limit broadcast traffic on a packets-per-second basis in addition to percentage of negotiated bandwidth.
Private VLAN (PVLAN), Dynamic Address Resolution Protocol Inspection (DAI), and IP Source Guard (IPSG) features are currently available on Cisco Catalyst 3750 and 3560 series switches running Enhanced Multilayer Image (EMI). Tested PVLAN, DAI, and IPSG interoperability is added in this Cisco IOS Software release. This advance further consolidates security on Cisco Catalyst switches by preventing security holes.
The HTTP software upgrade feature currently on Cisco Catalyst 3750, 3560, and 2970 series switches is being added to Cisco Catalyst 3550 Series switches running Standard Multilayer Image (SMI) and EMI. This feature is available on the noncrypto and crypto images.
The EtherChannel® feature is currently supported on Cisco Catalyst 3750 Series switches. For greater flexibility in configuring logical port groupings, you can now configure 48 EtherChannels across a stack of 9 switches with this release.
Additional syslog messages related to Spanning Tree Protocol are added to all switches addressed by this product bulletin, making it even easier to use and troubleshoot operations that use this protocol.
NEW FEATURES IN CISCO IOS SOFTWARE RELEASE 12.2(25)SE
The features shown in Table 1 are delivered in Cisco IOS Software Release 12.2(25)SE.
Table 1. Cisco IOS Software Release 12.2(25)SE New Features
Feature
Cisco Catalyst 3750 Series-EMI
Cisco Catalyst 3750 Series-SMI
Cisco Catalyst 3560 Series EMI
Cisco Catalyst 3560 Series SMI
Cisco Catalyst 3550 Series EMI
Cisco Catalyst 3550 Series SMI
Cisco Catalyst 2970 Series
QinQ
X
X
X
X
E
E
X
X
X
X
E
E
L2PT
X
X
X
X
E
E
DSCP transparency
X
X
X
X
E
E
X
X
X
X
X
X
X
X
X
X
SSL
X
X
X
X
X
X
X
X
Packet-based broadcast storm control
X
X
X
X
X
X
X
X
PVLAN, DAI, IPSG interoperability
X
X
E
E
E
E
X
X
E
E
802.1x with guest VLAN enhancement
X
X
X
X
X
X
X
X
48 EtherChannel connections across a stack
X
X
STP syslog messages
X
X
X
X
X
X
X
X
SMI-Standard Multilayer Image
EMI-Enhanced Multilayer Image
X-Feature is new for this platform
E-Feature exists for this platform
Table 2 lists the fixed-configuration Cisco Catalyst switches supported with this software release.
Table 2. Cisco Catalyst Switches Supported with Cisco IOS Software Release 12.2(25)SE
Cisco Catalyst 3750 Series EMI Models
Cisco Catalyst 3750 Series SMI Models
Cisco Catalyst 3560 Series EMI Models
Cisco Catalyst 3560 Series SMI Models
Cisco Catalyst 2970 Series Models
Cisco Catalyst 3550 Series EMI Models
Cisco Catalyst 3550 Series SMI Models
3750-48TS-E
3750-24TS-E
3750G-24T-E
3750G-24TS-E
3750G-12S-E
3750G-16TD
3750-48PS
3750-24PS
3750-48TS-S
3750-24TS-S
3750G-24T-S
3750G-24TS-S
3750G-12S-S
3750G-16TD
3750-48PS
3750-24PS
3560-48PS
3560-24PS
3560-48PS
3560-24PS
2970G-24T-E
2970G-24TS-E
3550-12G Switch
3550-12T Switch
3550-24-EMI Switch
3550-24 PWR Switch EMI
3550-48-EMI Switch
3550-24-FX-SMI Switch with EMI upgrade
3550-24-DC-SMI Switch with EMI upgrade
3550-24-SMI Switch
3550-24PWR-SMI
3550-48-SMI Switch
Feature enhancements made to Cisco Network Management Software with this release are highlighted in Table 3.
Table 3. New Features in Cisco Network Management Software
Feature
Description
Cisco Device Manager
Cisco Device Manager is a graphical device management tool that provides real-time views of the configuration and performance conditions for a single switch. It provides features such as Express Setup and Smartports to simplify switch management tasks. It also uses graphical, color-coded displays such as a Front Panel view of the switch, graphs, and animated indicators to simplify switch monitoring tasks.
Cisco Device Manager can be started from anywhere in your network through a Web browser such as Microsoft Internet Explorer or Netscape Navigator. Cisco Catalyst 3750, 3560, 3550, and 2970 series switches extend support for Cisco Device Manager with this software release.
 楼主| 发表于 2009-12-1 13:53:49 | 显示全部楼层
CISCO 3560 交换机IOS升级
在成功对cicso 3745 路由器的ios进行升级后,我决定cicso 3560 交换机也升级一番,这次升级路由器的升级步骤不同。我下载的新IOS是bin文件,本来想用Cisco Network Assistant程序升级的,但它要求上传的IOS是TRA格式。使用改后缀名、WINRAR压缩后改后缀名、或将文件在Linux下压缩成tar文件再上传都不可行。于是放弃这种方法,在交换机下用命令行升级。
以下是我的升级步骤:
一、设备清单
二、备份IOS
三、上传新IOS
四、更改启动设置
一、设备清单
      CICSO 3560交换机,安装了超级终端的PC,TFTP或FTP服务器,c3560-advipservicesk9-mz.122-
      25.SEE2.bin的IOS
二、备份IOS
      执行备份前先用dir、cd、pwd等命令看下flash中的目录结构。这台交换机IOS的bin文件以及html文件夹都在
      flash中c3560-ipbase-mz.122-25.SEB4目录下。
      1.  /* 将原IOS备份到IP为192.168.1.100的TFTP服务器上 */
      switch#copy flash:/c3560-ipbase-mz.122-25.SEB4/c3560-ipbase-mz.122-25.SEB4.bin
                      tftp://192.168.1.100/c3560-ipbase-mz.122-25.SEB4.bin
     2.  /* 将原IOS备份为tar文件到IP为192.168.1.100的TFTP服务器上 */
      switch#archive tar /create tftp://192.168.1.100/c3560-ipbase-mz.122-25.SEB4.tar
三、上传新IOS
          /* 将新IOS复制到flash的根目录下 */
        switch#copy tftp://192.168.1.100/c3560-advipservicesk9-mz.122-25.SEE2.bin
                        flash:/c3560-advipservicesk9-mz.122-25.SEE2.bin
四、更改启动设置
      1.  让交换机用新的IOS启动
        switch(config)#boot system flash:/c3560-advipservicesk9-mz.122-25.SEE2.bin
      2.  设置备用的IOS启动
        switch(config)#boot  boothlpr flash:/c3560-ipbase-mz.122-25.SEB4/c3560-ipbase-mz.122-25.SEB4.bin
        switch#write
        switch#reload
        重启后,交换机会使用新的IOS。用Cisco Network Assistant连接了一下,依然可用,虽然并没用复制它的html文件夹,而且用在路由协议中多了EIGRP和OSPF的选项卡。
GMT+8, 2026-11-12 11:19 , Processed in 0.049526 second(s), 18 queries .
