查看: 2501|回复: 4
ACS5.0 console初始化配置注意
发表于 2009-4-28 06:53:14 | 显示全部楼层 |阅读模式
1.console连接ACS服务器波特率还是设置成9600。
2.ACS服务器启动过程中超级终端会出现乱码现象,不要管它。启动完成后(出现login字符)就不会乱码了。启动时间较长,请耐心等待!
3.web登录的缺省用户名和密码:
username:ACSAdmin
password:default
这个密码登录后会跳转到修改web密码的界面,强制修改密码。
4.如果忘记web密码,可使用console 命令行进行修改
ACS/admin# acs reset-password
This command resets the 'ACSAdmin' password to its original value.
Are you sure you want to continue?  (yes/no) yes
Password was reset successfully
ACS/admin# acs reset-config ?
  <cr>  Carriage return.
5.还原出厂设置:
ACS/admin# write erase
Warning: This will erase the startup configuration. Continue? (yes/no) [yes] ? y
Please enter yes or no
Warning: This will erase the startup configuration. Continue? (yes/no) [yes] ? yes
ACS/admin# reload
Continue with reboot? [y/n] y
目前cisco网站上能找到的ACS5.0相关的文档:
CLI Reference Guide for the Cisco Secure Access Control System 5.0
http://www.cisco.com/en/US/docs/ ... /ACS_CLI_guide.html
User Guide for the Cisco Secure Access Control System 5.0
http://www.cisco.com/en/US/docs/ ... ACS_user_guide.html
GMT+8, 2026-11-12 11:29 , Processed in 0.029803 second(s), 18 queries .
