查看: 2377|回复: 0
让Outpost Firewall Pro与主流防毒软件“和平共处”
发表于 2007-3-27 05:50:59 | 显示全部楼层 |阅读模式
Optimising Outpost Firewall Pro to work concurrently with antivirus software.
KB ID:?000030, Added:?4-04-2004, Last updated:?2-10-2006
Applies To:
Outpost 2.0
Outpost 2.1
Outpost 2.5
Outpost 2.6
Outpost 2.7
Outpost 3.0
Outpost 3.5
Outpost 3.51
Outpost 4.0
Outpost Office 1.0
A possible reason for this is that Outpost Firewall frequently accesses its log files and the antivirus monitor checks each accessed file for viruses. This collision can lead to system slowdowns. To resolve this issue, add the Outpost Firewall installation folder to antivirus exclusions. For different antivirus software, complete the steps outline below.
Please use the following links for quick navigation:
For Avast! antivirus:
For AVG antivirus:
For Avira AntiVir PersonalEdition Classic:
For BitDefender:
For DrWeb SpiderGuard:
For G Data AntiVirusKit:
For Kaspersky Antivirus 4.0:
For Kaspersky Antivirus 5.0:
For Kaspersky Antivirus 6.0:
For McAfee VirusScan Home Edition
and McAfee VirusScan Professional Edition:
For NOD32:
For Norton Antivirus (earlier than 2005):
For Norton Antivirus 2005:
For Norton Antivirus 2006:
Avast!:
Right-click the Avast! icon in the system tray.
On the shortcut menu select Program Settings.
On the Exclusions tab click Browse.
Browse to the Outpost installation folder (C:\Program Files\Agnitum\Outpost Firewall by default) and click OK.
AVG:
Right-click the AVG icon in the system tray.
On the shortcut menu select Launch Control Center.
Click AV Resident Shield > Properties and select Excludes tab.
Click Edit Excludes and select Use excludes in AVG Resident Shield.
Click Add Path and locate the Outpost installation folder (C:\Program Files\Agnitum\Outpost Firewall by default).
Click OK 3 times.
Reboot your PC.
Right-click the Avira icon in the system tray.
On the shortcut menu select Configure AntiVir.
Checkmark "Expert mode".
Extend Guard - Scan (click on the "+" sign) and select Exceptions.
Browse to the Outpost folder (by default C:\Program Files\Agnitum\Outpost Firewall) and click Add.
Click OK to save your settings.
BitDefender:
Open BitDefender. Select Antivirus > Shield > Advanced.
Extend Exclude Path From Scan and click New Item.
DrWeb SpiderGuard:
Right-click the Spider Guard system tray icon.
On the shortcut menu select Settings.
On the Paths tab click Browse under Excluded folder and files.
Browse to the Outpost folder (C:\Program Files\Agnitum\Outpost Firewall by default) and click Add.
Restart your computer for the changes to take effect.
Right-click the G DATA AntiVirusKit icon in the system tray and select Launch AntiVirusKit.
Click Options.
On the Monitor tab, click Exceptions > New.
Select Directory and browse to Outpost installation folder (C:\Program Files\Agnitum\Outpost Firewall by default).
Save the changes by clicking OK 3 times.
Close the AntiVirusKit window.
If pages are displayed incorrectly, we recommend to switch off HTTP filtering in G Data AntiVirenKit:
Click Options.
On the Web tab, clear the Scan Web content (HTTP) check box.
Kaspersky Antivirus 4.0 does not support an exclusions list feature, but you can try to exclude all *.mdb files from being checked:
Right-click the Kaspersky Antivirus Monitor icon in the system tray.
Click Kaspersky Antivirus Monitor settings.
Click Objects.
Under Scan files of the following types select Exclude by mask.
Click New value and type *.mdb.
Click OK.
Open the Kaspersky Antivirus window.
Select the Settings tab.
Click Threats and Exclusions.
Click Add > Browse (...).
Locate the Outpost Firewall installation folder C:\Program Files\Agnitum\Outpost Firewall by default), click Select and save your settings.
Reboot your PC.
In order to avoid different problems with Internet access blocking, we strongly recommend that you perform the following steps:
Follow the instruction to switch off protection against network attacks at this page.
If the problem persists and Internet connections are still blocked please try to uninstall protection against network attacks or move the file KL1.SYS from the folder \WINDOWS\system32\drivers and reboot.
Note: Kaspersky Anti-Virus 5.0 (from version 5.0.227) contains system driver KL1.SYS which starts ireespective of the protection against network attacks status. The driver is responsible for network traffic filtering and in fact functions as a firewall. More than one firewall installed generally causes different problems and instability.
Please follow the recommendations at Kaspersky Labs or here:
Right-click Kaspersky AV icon in the system tray. In the shortcut menu select Settings.
Click Protection - Trusted Zone.
Click the Exclusions Masks tab - Add. Make sure the Object option is chek marked.
By the Object name click Specify.
Browse to the Outpost folder (by default C:\Program Files\Agnitum\Outpost Firewall) and check mark the option "Include subfolders".
By the Checking task click Selected.
The line should look like this:
The object will not be scanned if the following conditions are met:
Object name: C:\Program Files\Agnitum\Outpost Firewall
Checking task: any task
Save your settings by clicking OK 3 times.
Note: In order to avoid different problems with Internet access blocking, we strongly recommend that you perform the following steps:
Temporarily disable Kaspersky Antivirus 6.0 Self-Defence under Settings - Service - Protection.
Run the Registry editor (click Start - Run. In the Run field type regedit and click OK).
Find the key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\KL1
Add DWORD value "atchOB" the key. Right-click KL1 and select New - DWORD Value. In the Value name field type PatchOB.
Make sure that the value data is equal to 0x000000 (zero).
Reboot your PC.
Instead of modifiying the Registry you can download and run PatchOB.zip and reboot your PC.
McAfee VirusScan:
McAfee VirusScan Home Edition and McAfee VirusScan Professional Edition do not support an exclusions list feature, but you can increase scanning performance by switching to "rogram files and documents only" scan mode by following these steps:
Open VirusScan.
Click Options.
Select ActiveShield.
Click Advanced.
On the File Types to Scan select Program files and documents only.
NOD32:
Open NOD32 Control Center.
Click AMON.
Click Setup.
Select the Exclusion tab.
Add the Outpost folder (C:\Program Files\Agnitum\Outpost Firewall by default) and save the settings.
Click Add > Folder.
Browse to Outpost Firewall folder (C:\Program Files\Agnitum\Outpost Firewall by default).
Make sure that in Excluded objects field Folder is selected.
Click Add.
Click OK twice to save the settings.
Right-click the Norton Antivirus system tray icon.
Select Configure Norton Antivirus from the shortcut menu.
Click Autoprotect and then Click Exclusions.
Click New, type \Program Files\Agnitum\Outpost Firewall\ and select Include Subfolders.
Save the changes.
Right-click the Norton Antivirus 2005 system tray icon and click Open Norton Antivirus.
Click Options.
On the Other tab click Threat Categories - Exclusions.
Click New and browse to the Outpost folder (Crogram Files\Agnitum\Outpost Firewall by default).
Make sure that the option "Include subfolders" is selected.
Save your settings by clicking OK twice.
Right-click the Norton Antivirus system tray icon and select Open Norton Antivirus.
Click Options - Norton Antivirus.
Under System extend Auto-protect menu.
Click Exclusions
Click New and browse to Outpost filder (by default C:\Program Files\Agnitum\Outpost Firewall). Make sure the option "Include subfolders" is check marked.
Click OK to save the changes.
Close Norton Antivirus window and reboot.
If this does not resolve the problem, please follow the instructions at http://www.agnitum.com/support/k ... 1000144&lang=en
GMT+8, 2026-11-12 23:24 , Processed in 0.030910 second(s), 18 queries .
