查看: 3003|回复: 9
路由器电信、网通双线路智能切换配置指导
发表于 2009-3-3 18:55:23 | 显示全部楼层 |阅读模式
路由器电信、网通双线路智能切换配置指导
在很多地区,网吧用户同时申请了中国电信和中国网通两条宽带接入线路,如果此时双线路采用常规的“负载均衡”方式,就会发生访问网通站点走电信线路,访问电信站点走网通线路的情况,由于当前网通和电信两个运营商之间存在着互联互通速度慢的问题,造成速度瓶颈。如何实现“访问网通站点走网通线路,访问电信站点走电信线路”呢?在华为AR系列路由器上可以通过配置策略路由的方式满足以上需要。
一。配置访问控制列表,定义访问目的地址为网通的地址段
进入系统视图,创建ACL 3100:
<Quidway>system
System View: return to User View with Ctrl+Z.
[Quidway]acl num 3100
[Quidway-acl-adv-3100]
可以直接复制粘贴如下规则:
rule 0 permit ip destination 60.0.0.0 0.7.255.255
rule 1 permit ip destination 60.0.0.0 0.8.255.255
rule 2 permit ip destination 60.0.0.0 0.9.255.255
rule 3 permit ip destination 60.0.0.0 0.10.255.255
rule 4 permit ip destination 60.0.0.0 0.11.255.255
rule 5 permit ip destination 60.8.0.0 0.3.255.255
rule 6 permit ip destination 60.12.0.0 0.0.255.255
rule 7 permit ip destination 60.13.0.0 0.0.63.255
rule 8 permit ip destination 60.13.128.0 0.0.127.255
rule 9 permit ip destination 60.16.0.0 0.15.255.255
rule 10 permit ip destination 60.208.0.0 0.7.255.255
rule 11 permit ip destination 60.216.0.0 0.1.255.255
rule 12 permit ip destination 60.220.0.0 0.3.255.255
rule 13 permit ip destination 61.48.0.0 0.3.255.255
rule 14 permit ip destination 61.52.0.0 0.1.255.255
rule 15 permit ip destination 61.54.0.0 0.0.255.255
rule 16 permit ip destination 61.55.0.0 0.0.255.255
rule 17 permit ip destination 61.133.0.0 0.0.127.255
rule 18 permit ip destination 61.134.64.0 0.0.63.255
rule 19 permit ip destination 61.134.128.0 0.0.127.255
rule 20 permit ip destination 61.135.0.0 0.0.255.255
rule 21 permit ip destination 61.136.0.0 0.0.255.255
rule 22 permit ip destination 61.138.0.0 0.0.127.255
rule 23 permit ip destination 61.139.128.0 0.0.63.255
rule 24 permit ip destination 61.148.0.0 0.0.255.255
rule 25 permit ip destination 61.149.0.0 0.0.255.255
rule 26 permit ip destination 61.156.0.0 0.0.255.255
rule 27 permit ip destination 61.158.0.0 0.0.255.255
rule 28 permit ip destination 61.159.0.0 0.0.63.255
rule 29 permit ip destination 61.161.0.0 0.0.63.255
rule 30 permit ip destination 61.161.128.0 0.0.127.255
rule 31 permit ip destination 61.162.0.0 0.0.255.255
rule 32 permit ip destination 61.163.0.0 0.0.255.255
rule 33 permit ip destination 61.167.0.0 0.0.255.255
rule 34 permit ip destination 61.168.0.0 0.0.255.255
rule 35 permit ip destination 61.176.0.0 0.0.255.255
rule 36 permit ip destination 61.179.0.0 0.0.255.255
rule 37 permit ip destination 61.180.128.0 0.0.127.255
rule 38 permit ip destination 61.181.0.0 0.0.255.255
rule 39 permit ip destination 61.182.0.0 0.0.255.255
rule 40 permit ip destination 61.189.0.0 0.0.127.255
rule 41 permit ip destination 202.32.0.0 0.31.255.255
rule 42 permit ip destination 202.96.64.0 0.0.31.255
rule 43 permit ip destination 202.97.128.0 0.0.127.255
rule 44 permit ip destination 202.98.0.0 0.0.31.255
rule 45 permit ip destination 202.99.0.0 0.0.255.255
rule 46 permit ip destination 202.102.128.0 0.0.63.255
rule 47 permit ip destination 202.102.224.0 0.0.1.255
rule 48 permit ip destination 202.106.0.0 0.0.255.255
rule 49 permit ip destination 202.107.0.0 0.0.127.255
rule 50 permit ip destination 202.108.0.0 0.0.255.255
rule 51 permit ip destination 202.110.0.0 0.0.127.255
rule 52 permit ip destination 202.110.192.0 0.0.63.255
rule 53 permit ip destination 202.111.128.0 0.0.63.255
rule 54 permit ip destination 210.51.0.0 0.0.255.255
rule 55 permit ip destination 210.52.0.0 0.1.255.255
rule 56 permit ip destination 218.4.0.0 0.3.255.255
rule 57 permit ip destination 218.10.0.0 0.1.255.255
rule 58 permit ip destination 218.21.128.0 0.0.127.255
rule 59 permit ip destination 218.24.0.0 0.1.255.255
rule 60 permit ip destination 218.26.0.0 0.0.255.255
rule 61 permit ip destination 218.27.0.0 0.0.255.255
rule 62 permit ip destination 218.28.0.0 0.1.255.255
rule 63 permit ip destination 218.56.0.0 0.3.255.255
rule 64 permit ip destination 218.60.0.0 0.1.255.255
rule 65 permit ip destination 218.62.0.0 0.0.127.255
rule 66 permit ip destination 218.67.128.0 0.0.127.255
rule 67 permit ip destination 218.68.0.0 0.1.255.255
rule 68 permit ip destination 219.141.128.0 0.0.127.255
rule 69 permit ip destination 219.142.0.0 0.1.255.255
rule 70 permit ip destination 219.154.0.0 0.1.255.255
rule 71 permit ip destination 219.156.0.0 0.1.255.255
rule 72 permit ip destination 219.158.0.0 0.0.255.255
rule 73 permit ip destination 219.159.0.0 0.0.63.255
rule 74 permit ip destination 221.0.0.0 0.3.255.255
rule 75 permit ip destination 221.4.0.0 0.1.255.255
rule 76 permit ip destination 221.6.0.0 0.0.255.255
rule 77 permit ip destination 221.7.128.0 0.0.127.255
rule 78 permit ip destination 221.8.0.0 0.1.255.255
rule 79 permit ip destination 221.10.0.0 0.0.255.255
rule 80 permit ip destination 221.11.0.0 0.0.127.255
rule 81 permit ip destination 221.12.0.0 0.3.255.255
rule 82 permit ip destination 221.12.0.0 0.0.127.255
rule 83 permit ip destination 221.12.128.0 0.0.63.255
rule 84 permit ip destination 221.192.0.0 0.3.255.255
rule 85 permit ip destination 221.196.0.0 0.1.255.255
rule 86 permit ip destination 221.199.0.0 0.0.31.255
rule 87 permit ip destination 221.199.32.0 0.0.15.255
rule 88 permit ip destination 221.199.128.0 0.0.63.255
rule 89 permit ip destination 221.199.192.0 0.0.15.255
rule 90 permit ip destination 221.200.0.0 0.3.255.255
rule 91 permit ip destination 221.204.0.0 0.1.255.255
rule 92 permit ip destination 221.207.0.0 0.0.63.255
rule 93 permit ip destination 221.208.0.0 0.15.255.255
rule 94 permit ip destination 222.128.0.0 0.3.255.255
rule 95 permit ip destination 222.132.0.0 0.3.255.255
rule 96 permit ip destination 222.136.0.0 0.7.255.255
rule 97 permit ip destination 222.160.0.0 0.3.255.255
注:以上规则已经包含大部分网通地址段,如有更新可以动态添加。
二。定义策略路由指定访问网通地址段的数据报文下一跳为网通网关
[Quidway]route-policy auto permit node 1
%New sequence of this list
[Quidway-route-policy]if-match acl 3100
[Quidway-route-policy]apply ip-address next-hop 10.1.1.2
[Quidway-route-policy]dis this
if-match acl 3100
return
注:上面配置中以地址10.1.1.2为例作为网通网关地址,应用中可根据实际需要修改。
三。在连接局域网接口下应用此策略路由
[Quidway]int e3/0
[Quidway-Ethernet3/0]dis this
interface Ethernet3/0
return
[Quidway-Ethernet3/0]ip policy route-policy auto
return
四。配置默认路由器经过电信网关
ip route-static 0.0.0.0 0.0.0.0 20.1.1.2 preference 60
注:上面配置中以地址20.1.1.2为例作为电信网关地址,应用中可根据实际需要修改。
经过如上三个配置步骤后,路由器便能自动区分网通流量和电信流量,使访问网通站点走网通线路,访问电信站点走电信线路。并且当网通线路出问题后所有流量都会自动切换到电信线路上,使用户能够不间断访问网络。
发表于 2009-5-19 20:16:53 | 显示全部楼层
新加的空白文章1
    中国第一套彻底治疗口吃病的朱氏《自我矫治口吃病光盘》科研成功出世!有效治愈率98%,好转率100%,效果相当显著,无效全额退款,十倍赔偿。标志着中国数百万口吃患者能够彻底告别口吃病有新希望!震撼心灵的独特疗法,堪称口吃史上的一大奇迹。这更是一套值得收藏的伟大巨作,20天在家就可以治疗好口吃结巴。科学/系统/权威/方便/省时/人性化。
网址:
www.kouchi0510.com      www.kouchi.vip.cn    全国免费热线:400-688-0510
中心咨询热线:0510-8825-0510  短信平台:13921173444  QQ在线:183360354
口吃口吃治疗治疗口吃口吃矫正矫正口吃治口吃结巴结巴治疗治结巴结巴矫正结巴矫治大舌头孩子口吃江苏口吃上海口吃浙江口吃安徽口吃儿童口吃怎么治疗口吃
http://www.kouchi0510.com
GMT+8, 2026-11-12 11:19 , Processed in 0.033638 second(s), 18 queries .
