查看: 2380|回复: 0
ospf的新特性
发表于 2007-4-24 01:01:44 | 显示全部楼层 |阅读模式
ospf中的新特性,对ios的版本要求较高:
  The OSPF ABR Type 3 LSA Filtering feature is supported for the following platforms in Cisco IOS
  Release 12.2(4)T:
  · Cisco 1400 series
  · Cisco 1600 series
  · Cisco 1600R series
  · Cisco 1720
  · Cisco 1721 (Supported in Cisco IOS Release 12.2(8)T and above.)
  · Cisco 1750
  · Cisco 1751
  · Cisco 2500 series
  · Cisco 2600 series
  · Cisco 3620
  · Cisco 3631 (Supported in Cisco IOS Release 12.2(8)T and above.)
  · Cisco 3640
  · Cisco 3745 (Supported in Cisco IOS Release 12.2(8)T and above.)
  · Cisco 3660
  · Cisco MC3810
  · Cisco 7100 series
  · Cisco 7200 series
  · Cisco 7500 series (Supported in Cisco IOS Release 12.2(4)T3 and above.)
  · Cisco uBR7200 series
  · Universal Router Module (Supported in Cisco IOS Release 12.2(8)T.)
  以下配置在abr上完成
  配置步骤:
  1,过滤进入某AREA的LSA3
  Command Purpose
  Router(config)# router ospf process-id
  Configures the router to run an OSPF process.
  Router(config-router)# area area-id filter-list prefixprefix-list-name in
  Configures the router to filter interarea routes into the specified area.
  Router(config-router)# ip prefix-list list-name [seq seq-value] deny | permit network/len [ge ge-value] [le le-value]
  Creates a prefix list with the name specified for thelist-name argument.
  2,过滤从某AREA出去的LSA3
  Router(config-router)# area area-id filter-list prefix prefix-list-name out
  Configures the router to filter interarea routes out of the specified area.
  Router(config-router)# ip prefix-list list-name [seq seq-value] deny | permit network/len [ge ge-value] [lele-value]
  Creates a prefix list with the name specified for the list-name argument.
  3检查配置
  router# show ip ospf 1
  Routing Process "ospf 1" with ID 172.16.0.1
  Supports only single TOS(TOS0) routes
  Supports opaque LSA
  It is an area border router
  SPF schedule delay 5 secs, Hold time between two SPFs 10 secs
  Minimum LSA interval 5 secs. Minimum LSA arrival 1 secs
  Number of external LSA 0. Checksum Sum 0x0
  Number of opaque AS LSA 0. Checksum Sum 0x0
  Number of DCbitless external and opaque AS LSA 0
  Number of DoNotAge external and opaque AS LSA 0
  Number of areas in this router is 2. 2 normal 0 stub 0 nssa
  External flood list length 0
  Area BACKBONE(0)
  Number of interfaces in this area is 2
  Area has no authentication
  SPF algorithm executed 6 times
  Area ranges are
  10.0.0.0/8 Passive Advertise
  Area-filter AREA_0_IN in
  Area-filter AREA_0_OUT out
  Number of LSA 5. Checksum Sum 0x29450
  4,配置举例
  Router(config)# router ospf 1
  log-adjacency-changes
  area 1 filter-list prefix AREA_1_OUT out
  area 3 filter-list prefix AREA_3_IN in
  network 10.0.0.0 0.255.255.255 area 3
  network 172.16.1.0 0.0.0.255 area 0
  network 192.168.0.0 0.255.255.255 area 1
  ip prefix-list AREA_1_OUT seq 10 permit 10.25.0.0/8 ge 16
  ip prefix-list AREA_1_OUT seq 20 permit 172.20.20.0/24
  ip prefix-list AREA_3_IN seq 10 permit 172.31.0.0/16
GMT+8, 2026-11-12 11:30 , Processed in 0.032053 second(s), 18 queries .
