查看: 2577|回复: 1
电信网通双线接入配置案例
发表于 2009-1-18 05:34:00 | 显示全部楼层 |阅读模式
最近接到一个网通电信双线接入,看了网上好多帖子,案例,基本上实现起来都有问题,只能自己研究,好赖实施成功了,贴出来共享一下!大家帮我顶一下!绝对成功,o(∩_∩)o...
Router#show run
Building configuration...!
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
hostname Router
boot-start-marker
boot-end-marker
enable password ciscocisco
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
interface Ethernet0
description wt
ip address *.*.*.* 255.255.255.0
设置网通ip地址****
ip nat outside
设置广域网口******
full-duplex
interface Ethernet1
description dx
ip address *.*.*.* 255.255.255.240
设置电信ip地址****
ip nat outside
设置广域网口******
full-duplex
interface FastEthernet0
ip address 192.168.1.254 255.255.255.0
ip nat inside
设置内网口*********
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0  *.*.*.*
将电信设置为出口默认路由********
 楼主| 发表于 2009-1-18 05:34:34 | 显示全部楼层
*********网通静态路由地址段,费了不少劲儿才收集到的*****************
ip route 58.16.0.0 255.248.0.0 *.*.*.*
ip route 58.100.0.0 255.254.0.0 *.*.*.*
ip route 58.240.0.0 255.240.0.0 *.*.*.*
ip route 60.0.0.0 255.248.0.0 *.*.*.*
ip route 60.8.0.0 255.252.0.0 *.*.*.*
ip route 60.12.0.0 255.255.0.0 *.*.*.*
ip route 60.13.0.0 255.255.192.0 *.*.*.*
ip route 60.13.128.0 255.255.128.0 *.*.*.*
ip route 60.16.0.0 255.240.0.0 *.*.*.*
ip route 60.24.0.0 255.248.0.0 *.*.*.*
ip route 60.31.0.0 255.255.0.0 *.*.*.*
ip route 60.208.0.0 255.248.0.0 *.*.*.*
ip route 60.216.0.0 255.254.0.0 *.*.*.*
ip route 60.220.0.0 255.252.0.0 *.*.*.*
ip route 61.48.0.0 255.252.0.0 *.*.*.*
ip route 61.52.0.0 255.254.0.0 *.*.*.*
ip route 61.54.0.0 255.255.0.0 *.*.*.*
ip route 61.55.0.0 255.255.0.0 *.*.*.*
ip route 61.133.0.0 255.255.128.0 *.*.*.*
ip route 61.134.64.0 255.255.192.0 *.*.*.*
ip route 61.134.128.0 255.255.128.0 *.*.*.*
ip route 61.135.0.0 255.255.0.0 *.*.*.*
ip route 61.136.0.0 255.255.0.0 *.*.*.*
ip route 61.138.0.0 255.255.128.0 *.*.*.*
ip route 61.139.128.0 255.255.192.0 *.*.*.*
ip route 61.148.0.0 255.255.0.0 *.*.*.*
ip route 61.149.0.0 255.255.0.0 *.*.*.*
ip route 61.156.0.0 255.255.0.0 *.*.*.*
ip route 61.158.0.0 255.255.0.0 *.*.*.*
ip route 61.159.0.0 255.255.192.0 *.*.*.*
ip route 61.161.0.0 255.255.192.0 *.*.*.*
ip route 61.161.128.0 255.255.128.0 *.*.*.*
ip route 61.162.0.0 255.255.0.0 *.*.*.*
ip route 61.163.0.0 255.255.0.0 *.*.*.*
ip route 61.167.0.0 255.255.0.0 *.*.*.*
ip route 61.168.0.0 255.255.0.0 *.*.*.*
ip route 61.176.0.0 255.255.0.0 *.*.*.*
ip route 61.179.0.0 255.255.0.0 *.*.*.*
ip route 61.180.128.0 255.255.128.0 *.*.*.*
ip route 61.181.0.0 255.255.0.0 *.*.*.*
ip route 61.182.0.0 255.255.0.0 *.*.*.*
ip route 61.189.0.0 255.255.128.0 *.*.*.*
ip route 124.90.0.0 255.254.0.0 *.*.*.*
ip route 124.162.0.0 255.255.0.0 *.*.*.*
ip route 202.32.0.0 255.224.0.0 *.*.*.*
ip route 202.96.64.0 255.255.224.0 *.*.*.*
ip route 202.97.128.0 255.255.128.0 *.*.*.*
ip route 202.98.0.0 255.255.224.0 *.*.*.*
ip route 202.99.0.0 255.255.0.0 *.*.*.*
ip route 202.102.128.0 255.255.192.0 *.*.*.*
ip route 202.102.224.0 255.255.254.0 *.*.*.*
ip route 202.106.0.0 255.255.0.0 *.*.*.*
ip route 202.107.0.0 255.255.128.0 *.*.*.*
ip route 202.108.0.0 255.255.0.0 *.*.*.*
ip route 202.110.0.0 255.255.128.0 *.*.*.*
ip route 202.110.192.0 255.255.192.0 *.*.*.*
ip route 202.111.128.0 255.255.192.0 *.*.*.*
ip route 203.79.0.0 255.255.0.0 *.*.*.*
ip route 203.80.0.0 255.255.0.0 *.*.*.*
ip route 203.81.0.0 255.255.224.0 *.*.*.*
ip route 203.86.32.0 255.255.224.0 *.*.*.*
ip route 203.86.64.0 255.255.224.0 *.*.*.*
ip route 203.90.0.0 255.255.128.0 *.*.*.*
ip route 203.90.128.0 255.255.192.0 *.*.*.*
ip route 203.90.192.0 255.255.224.0 *.*.*.*
ip route 203.92.0.0 255.254.0.0 *.*.*.*
ip route 210.12.0.0 255.255.128.0 *.*.*.*
ip route 210.12.192.0 255.255.192.0 *.*.*.*
ip route 210.13.0.0 255.255.255.0 *.*.*.*
ip route 210.14.160.0 255.255.224.0 *.*.*.*
ip route 210.14.192.0 255.255.192.0 *.*.*.*
ip route 210.15.0.0 255.255.128.0 *.*.*.*
ip route 210.15.128.0 255.255.192.0 *.*.*.*
ip route 210.16.128.0 255.255.192.0 *.*.*.*
ip route 210.21.0.0 255.255.0.0 *.*.*.*
ip route 210.22.0.0 255.255.0.0 *.*.*.*
ip route 210.51.0.0 255.255.0.0 *.*.*.*
ip route 210.52.0.0 255.254.0.0 *.*.*.*
ip route 210.52.128.0 255.255.128.0 *.*.*.*
ip route 210.53.0.0 255.255.0.0 *.*.*.*
ip route 210.74.64.0 255.255.192.0 *.*.*.*
ip route 210.74.128.0 255.255.192.0 *.*.*.*
ip route 210.78.0.0 255.255.224.0 *.*.*.*
ip route 210.82.0.0 255.254.0.0 *.*.*.*
ip route 211.100.0.0 255.255.0.0 *.*.*.*
ip route 211.101.0.0 255.255.192.0 *.*.*.*
ip route 211.147.0.0 255.255.0.0 *.*.*.*
ip route 211.167.96.0 255.255.224.0 *.*.*.*
ip route 218.4.0.0 255.252.0.0 *.*.*.*
ip route 218.10.0.0 255.254.0.0 *.*.*.*
ip route 218.21.128.0 255.255.128.0 *.*.*.*
ip route 218.24.0.0 255.254.0.0 *.*.*.*
ip route 218.26.0.0 255.255.0.0 *.*.*.*
ip route 218.27.0.0 255.255.0.0 *.*.*.*
ip route 218.28.0.0 255.254.0.0 *.*.*.*
ip route 218.56.0.0 255.252.0.0 *.*.*.*
ip route 218.60.0.0 255.254.0.0 *.*.*.*
ip route 218.62.0.0 255.255.128.0 *.*.*.*
ip route 218.67.128.0 255.255.128.0 *.*.*.*
ip route 218.68.0.0 255.254.0.0 *.*.*.*
ip route 218.109.159.0 255.255.255.0 *.*.*.*
ip route 219.141.128.0 255.255.128.0 *.*.*.*
ip route 219.142.0.0 255.254.0.0 *.*.*.*
ip route 219.154.0.0 255.254.0.0 *.*.*.*
ip route 219.156.0.0 255.254.0.0 *.*.*.*
ip route 219.158.0.0 255.255.0.0 *.*.*.*
ip route 219.159.0.0 255.255.192.0 *.*.*.*
ip route 220.248.0.0 255.252.0.0 *.*.*.*
ip route 220.252.0.0 255.255.0.0 *.*.*.*
ip route 221.0.0.0 255.252.0.0 *.*.*.*
ip route 221.4.0.0 255.254.0.0 *.*.*.*
ip route 221.6.0.0 255.255.0.0 *.*.*.*
ip route 221.7.128.0 255.255.128.0 *.*.*.*
ip route 221.8.0.0 255.254.0.0 *.*.*.*
ip route 221.10.0.0 255.255.0.0 *.*.*.*
ip route 221.11.0.0 255.255.128.0 *.*.*.*
ip route 221.12.0.0 255.252.0.0 *.*.*.*
ip route 221.12.0.0 255.255.128.0 *.*.*.*
ip route 221.12.128.0 255.255.192.0 *.*.*.*
ip route 221.192.0.0 255.252.0.0 *.*.*.*
ip route 221.195.0.0 255.255.0.0 *.*.*.*
ip route 221.196.0.0 255.254.0.0 *.*.*.*
ip route 221.199.0.0 255.255.224.0 *.*.*.*
ip route 221.199.32.0 255.255.240.0 *.*.*.*
ip route 221.199.128.0 255.255.192.0 *.*.*.*
ip route 221.199.192.0 255.255.240.0 *.*.*.*
ip route 221.200.0.0 255.252.0.0 *.*.*.*
ip route 221.204.0.0 255.254.0.0 *.*.*.*
ip route 221.207.0.0 255.255.192.0 *.*.*.*
ip route 221.208.0.0 255.240.0.0 *.*.*.*
ip route 221.208.0.0 255.252.0.0 *.*.*.*
ip route 221.213.0.0 255.255.0.0 *.*.*.*
ip route 221.214.0.0 255.254.0.0 *.*.*.*
ip route 222.128.0.0 255.252.0.0 *.*.*.*
ip route 222.132.0.0 255.252.0.0 *.*.*.*
ip route 222.136.0.0 255.248.0.0 *.*.*.*
ip route 222.160.0.0 255.252.0.0 *.*.*.*
ip route 222.163.0.0 255.255.224.0 *.*.*.*
no ip http server
ip nat translation timeout 120
ip nat translation tcp-timeout 60
ip nat translation icmp-timeout 180
ip nat inside source route-map dx interface Ethernet1 overload   *****通过电信接口NAT转换
ip nat inside source route-map wt interface Ethernet0 overload   *****通过网通接口NAT转换
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
route-map wt permit 10  *****网通策略路由地址段匹配101*******
match ip address 101
match interface Ethernet0  ******匹配接口E0***************
set ip default next-hop *.*.*.*
route-map dx permit 10  *****电信策略路由地址段匹配102*********
match ip address 102
match interface Ethernet1   ******匹配接口E1***************
control-plane
line con 0
line aux 0
line vty 0 4
password ########
login
end
GMT+8, 2026-11-12 11:30 , Processed in 0.044357 second(s), 18 queries .
