查看: 2776|回复: 8
IPSO560问题,在线等
发表于 2008-12-23 14:42:54 | 显示全部楼层 |阅读模式
新购买了一套NOKIA 560 版本是4.2的,我在初始安装后,选择了1000M口后,WEB登入不进去了
请问下,怎么将机器恢复成出厂设置,多谢了!
 楼主| 发表于 2008-12-23 15:24:06 | 显示全部楼层
自己开CASE找到了
1. Boot into single user mode
2. login as the admin user
3. admin# mount -a (mounts filesystems)
4. admin# cd /config (At the admin prompt, change to the config directory)
4. admin# rm active (Remove the file called "active")
5. admin# reboot (reboot the appliance)
发表于 2008-12-23 15:30:39 | 显示全部楼层
GMT+8, 2026-11-8 03:08 , Processed in 0.038614 second(s), 18 queries .
