查看: 4396|回复: 2
IDC数据中心6509ACE模块,fwsm及msfc集成
发表于 2008-10-28 11:04:43 | 显示全部楼层 |阅读模式
首先说这绝对是原创,在6509机箱中集成fwsm 和ace及msfc有非常多的部署模式,此次项目中我们接触到路由和透明的部署模式,并且做了HA和FT,由于涉及到保密的问题,现在粘出部分配置,以供分享。。。
    total: 1014624 kB, used: 360960 kB, available: 653664 kB
last boot reason:  SUP request
configuration register:  0x1
switch kernel uptime is 0 days 0 hour 49 minute(s) 7 second(s)
switch/Admin#
switch/Admin#
switch/Admin# show run
Generating configuration....
boot system image:c6ace-t1k9-mz.3.0.0_A1_6_3a.bin
access-list 200 line 8 extended permit icmp any any
access-list 200 line 24 extended permit ip any any
rserver host S1
  ip address 192.168.1.222
  inservice
rserver host S2
  ip address 192.168.1.221
  inservice
serverfarm host farm_test
  rserver S1
    inservice
  rserver S2
    inservice
class-map match-any VIP
  2 match virtual-address 192.168.99.100 tcp eq ftp
class-map type management match-any manage
  2 match protocol http any
  3 match protocol icmp any
  4 match protocol ssh any
  5 match protocol snmp any
  6 match protocol telnet any
policy-map type management first-match behavior_manage
  class manage
    permit
policy-map type loadbalance first-match behavior_loadbalance
  class class-default
    serverfarm farm_test
policy-map multi-match app_policy
  class VIP
    loadbalance vip inservice
    loadbalance policy behavior_loadbalance
    loadbalance vip icmp-reply
    loadbalance vip advertise
interface vlan 5
  ip address 192.168.99.1 255.255.255.0
  access-group input 200
  service-policy input app_policy
  service-policy input behavior_manage
  no shutdown
interface vlan 8
  ip address 192.168.1.254 255.255.255.0
  no shutdown
ip route 0.0.0.0 0.0.0.0 192.168.99.2
username admin password 5 $1$faXJEFBj$TJR1Nx7sLPTi5BZ97v08c/  role Admin domain
default-domain
username www password 5 $1$UZIiwUk7$QMVYN1JASaycabrHkhGcS/  role Admin domain de
fault-domain
switch/Admin#
switch/Admin#
switch/Admin#
switch/Admin#
switch/Admin# show ip route
Routing Table for Context Admin (RouteId 0)
   Codes: H - host,   I - interface
          S - static,      N - nat
          A - need arp resolve,      E - ecmp
Destination         Gateway          Interface         Flags
0.0.0.0             192.168.99.2     vlan5             S
192.168.1.0/24      0.0.0.0          vlan8             IA
192.168.99.0/24     0.0.0.0          vlan5             IA
Total route entries = 3
switch/Admin#
switch/Admin#
switch/Admin#
switch/Admin#
switch/Admin#
switch/Admin# show had?
% invalid command
switch/Admin# show environment
Temperature:
inlet           temperature : 34
outlet          temperature : 37
SIBYTE          temperature : 55
HYPERION        temperature : 53
CDE0            temperature : 48
CDE1            temperature : 47
IXP0            temperature : 38
IXP1            temperature : 38
SSA             temperature : 60
switch/Admin#
switch/Admin#
switch/Admin#
switch/Admin#
switch/Admin#
switch/Admin# exit
[Connection to 127.0.0.90 closed by foreign host]
Router#sess slo 8 pro 1
The default escape character is Ctrl-^, then x.
You can also type 'exit' at the remote prompt to end the session
Trying 127.0.0.81 ... Open
User Access Verification
Password:
FWSM> en
Password:
FWSM#
FWSM#
FWSM#
FWSM#
FWSM# show ver
FWSM Firewall Version 3.2(5)
Device Manager Version 5.2(3)F
Compiled on Mon 10-Mar-08 16:03 by fwsmbld
FWSM up 47 mins 44 secs
Hardware:   WS-SVC-FWM-1, 1024 MB RAM, CPU Pentium III 1000 MHz
Flash SMART ATA FLASH DISK @ 0xc321, 20MB
0: Int: Not licensed        : irq 5
1: Int: Not licensed        : irq 7
2: Int: Not licensed        : irq 11
The Running Activation Key is not set, using default settings:
Licensed features for this platform:
Maximum Interfaces          : 256
Inside Hosts                : Unlimited
Failover                    : Active/Active
VPN-DES                     : Enabled
VPN-3DES-AES                : Enabled
Cut-through Proxy           : Enabled
Guards                      : Enabled
URL Filtering               : Enabled
Security Contexts           : 2
GTP/GPRS                    : Disabled
BGP Stub                    : Disabled
VPN Peers                   : Unlimited
Serial Number: SAD122300KU
Running Activation Key: 0x00000000 0x00000000 0x00000000 0x00000000
Configuration last modified by enable_15 at 13:06:57.054 UTC Mon Feb 28 2000
FWSM#
FWSM#
FWSM#
FWSM# show run
: Saved
FWSM Version 3.2(5)
hostname FWSM
names
interface Vlan2
nameif DMZ
security-level 100
ip address 192.168.88.2 255.255.255.0
interface Vlan7
nameif outside
security-level 0
ip address 58.83.131.74 255.255.255.0
ftp mode passive
access-list 100 extended permit ip any any
access-list 100 extended permit tcp any any
access-list 100 extended permit udp any any
access-list 200 extended permit icmp any any
access-list 200 extended permit tcp any any eq ftp
pager lines 24
mtu DMZ 1500
mtu outside 1500
no failover
icmp permit any DMZ
icmp permit any outside
no asdm history enable
arp timeout 14400
nat-control
global (outside) 10 interface
nat (DMZ) 10 192.168.1.0 255.255.255.0
static (DMZ,outside) 58.83.131.100 192.168.99.100 netmask 255.255.255.255
access-group 100 in interface DMZ
access-group 200 in interface outside
route DMZ 192.168.1.0 255.255.255.0 192.168.88.1 1
route DMZ 192.168.99.0 255.255.255.0 192.168.88.1 1
route outside 0.0.0.0 0.0.0.0 58.83.131.73 1
timeout xlate 3:00:00
timeout sunrpc 0:10:00 h323 1:00:00 h225 1:00:00 mgcp 0:05:00
timeout sip-invite 0:03:00 sip-disconnect 0:02:00
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect skinny
  inspect smtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
prompt hostname context
Cryptochecksum:d41d8cd98f00b204e9800998ecf8427e
: end
FWSM#
FWSM#
FWSM# show route
S    0.0.0.0 0.0.0.0 [1/0] via 58.83.131.73, outside
C    58.83.131.0 255.255.255.0 is directly connected, outside
S    192.168.1.0 255.255.255.0 [1/0] via 192.168.88.1, DMZ
C    192.168.88.0 255.255.255.0 is directly connected, DMZ
S    192.168.99.0 255.255.255.0 [1/0] via 192.168.88.1, DMZ
FWSM#
FWSM#
FWSM#
FWSM# show access
FWSM# show access-list
access-list mode auto-commit
access-list cached ACL log flows: total 0, denied 0 (deny-flow-max 4096)
            alert-interval 300
access-list 100; 3 elements
access-list 100 line 1 extended permit ip any any (hitcnt=249) 0xa2f91e1d
access-list 100 line 2 extended permit tcp any any (hitcnt=0) 0x0878ce61
access-list 100 line 3 extended permit udp any any (hitcnt=0) 0xd52c9509
access-list 200; 2 elements
access-list 200 line 1 extended permit icmp any any (hitcnt=233) 0xa7b0be37
access-list 200 line 2 extended permit tcp any any eq ftp (hitcnt=6) 0x6ce98731
FWSM#
FWSM#
FWSM#
FWSM# show hard
FWSM# show hard
ERROR: % Invalid input detected at '^' marker.
FWSM#
FWSM# show xl
FWSM# show xlate
3 in use, 3 most used
PAT Global 58.83.131.74(1025) Local 192.168.1.222 ICMP id 512
PAT Global 58.83.131.74(1026) Local 192.168.1.222(3904)
PAT Global 58.83.131.74(1027) Local 192.168.1.222(3905)
FWSM#
Router#
Router#
Router#
Router#show ver
Router#show version
Cisco Internetwork Operating System Software
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICES_WAN-M), Version 12.2(18)SXF13, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Thu 14-Feb-08 04:33 by kellythw
Image text-base: 0x40101040, data-base: 0x42AA0F10
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICES_WAN-M), Version 12.2(18)SXF13, RELEASE SOFTWARE (fc1)
Router uptime is 49 minutes
Time since Router switched to active is 49 minutes
System returned to ROM by reload at 12:10:04 UTC Fri May 23 2008 (SP by reload)
System image file is "sup-bootdisk:s72033-ipservices_wan-mz.122-18.SXF13.bin"
cisco WS-C6509-E (R7000) processor (revision 1.4) with 458720K/65536K bytes of memory.
Processor board ID SMC120500CP
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
4 Virtual Ethernet/IEEE 802.3 interfaces
56 Gigabit Ethernet/IEEE 802.3 interfaces
1 Ten Gigabit Ethernet/IEEE 802.3 interface
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x2102
Router#
Router#
Router#
Router#sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
Vlan1                      unassigned      YES unset  administratively down down
Vlan2                      192.168.88.1    YES manual up                    up
Vlan5                      192.168.99.2    YES manual up                    up
Vlan7                      unassigned      YES manual up                    up
GigabitEthernet5/1         unassigned      YES unset  administratively down down
GigabitEthernet5/2         unassigned      YES unset  administratively down down
GigabitEthernet7/1         unassigned      YES unset  up                    up
GigabitEthernet7/2         unassigned      YES unset  administratively down down
GigabitEthernet7/3         unassigned      YES unset  administratively down down
GigabitEthernet7/4         unassigned      YES unset  administratively down down
GigabitEthernet7/5         unassigned      YES unset  administratively down down
GigabitEthernet7/6         unassigned      YES unset  administratively down down
GigabitEthernet7/7         unassigned      YES unset  administratively down down
GigabitEthernet7/8         unassigned      YES unset  administratively down down
GigabitEthernet7/9         unassigned      YES unset  administratively down down
GigabitEthernet7/10        unassigned      YES unset  administratively down down
GigabitEthernet7/11        unassigned      YES unset  administratively down down
GigabitEthernet7/12        unassigned      YES unset  administratively down down
GigabitEthernet7/13        unassigned      YES unset  administratively down down
GigabitEthernet7/14        unassigned      YES unset  administratively down down
GigabitEthernet7/15        unassigned      YES unset  administratively down down
GigabitEthernet7/16        unassigned      YES unset  administratively down down
GigabitEthernet7/17        unassigned      YES unset  administratively down down
GigabitEthernet7/18        unassigned      YES unset  administratively down down
GigabitEthernet7/19        unassigned      YES unset  administratively down down
GigabitEthernet7/20        unassigned      YES unset  administratively down down
GigabitEthernet7/21        unassigned      YES unset  administratively down down
GigabitEthernet7/22        unassigned      YES unset  administratively down down
GigabitEthernet7/23        unassigned      YES unset  administratively down down
GigabitEthernet7/24        unassigned      YES unset  administratively down down
GigabitEthernet7/25        unassigned      YES unset  administratively down down
GigabitEthernet7/26        unassigned      YES unset  administratively down down
GigabitEthernet7/27        unassigned      YES unset  administratively down down
GigabitEthernet7/28        unassigned      YES unset  administratively down down
GigabitEthernet7/29        unassigned      YES unset  administratively down down
GigabitEthernet7/30        unassigned      YES unset  administratively down down
GigabitEthernet7/31        unassigned      YES unset  administratively down down
GigabitEthernet7/32        unassigned      YES unset  administratively down down
GigabitEthernet7/33        unassigned      YES unset  administratively down down
GigabitEthernet7/34        unassigned      YES unset  administratively down down
GigabitEthernet7/35        unassigned      YES unset  administratively down down
GigabitEthernet7/36        unassigned      YES unset  administratively down down
GigabitEthernet7/37        unassigned      YES unset  administratively down down
GigabitEthernet7/38        unassigned      YES unset  administratively down down
GigabitEthernet7/39        unassigned      YES unset  administratively down down
GigabitEthernet7/40        unassigned      YES unset  administratively down down
GigabitEthernet7/41        unassigned      YES unset  administratively down down
GigabitEthernet7/42        unassigned      YES unset  administratively down down
GigabitEthernet7/43        unassigned      YES unset  administratively down down
GigabitEthernet7/44        unassigned      YES unset  administratively down down
GigabitEthernet7/45        unassigned      YES unset  administratively down down
GigabitEthernet7/46        unassigned      YES unset  administratively down down
GigabitEthernet7/47        unassigned      YES unset  up                    up
GigabitEthernet7/48        unassigned      YES unset  administratively down down
Router#
Router#
Router#
Router#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.88.2 to network 0.0.0.0
C    192.168.88.0/24 is directly connected, Vlan2
     192.168.99.0/24 is variably subnetted, 2 subnets, 2 masks
C       192.168.99.0/24 is directly connected, Vlan5
S       192.168.99.100/32 [77/0] via 192.168.99.1, Vlan5
S    192.168.1.0/24 [1/0] via 192.168.99.1
S*   0.0.0.0/0 [1/0] via 192.168.88.2
Router#
Router#
Router#sh run
Building configuration...
Current configuration : 4231 bytes
upgrade fpd auto
version 12.2
service timestamps log uptime
service counters max age 5
hostname Router
no aaa new-model
svclc multiple-vlan-interfaces
svclc module 9 vlan-group 2
svclc vlan-group 2  5,8
firewall multiple-vlan-interfaces
firewall module 8 vlan-group 1
firewall vlan-group 1  2,7
ip subnet-zero
ipv6 mfib hardware-switching replication-mode ingress
mls ip multicast flow-stat-timer 9
no mls flow ip
no mls flow ipv6
no mls acl tcam share-global
mls cef error action freeze
redundancy
mode sso
main-cpu
  auto-sync running-config
spanning-tree mode pvst
diagnostic cns publish cisco.cns.device.diag_results
diagnostic cns subscribe cisco.cns.device.diag_commands
vlan access-log ratelimit 2000
interface GigabitEthernet5/1
no ip address
shutdown
interface GigabitEthernet5/2
no ip address
shutdown
interface GigabitEthernet7/1
switchport
switchport access vlan 7
switchport mode access
no ip address
interface GigabitEthernet7/2
no ip address
shutdown
interface GigabitEthernet7/3
no ip address
shutdown
interface GigabitEthernet7/4
no ip address
shutdown
interface GigabitEthernet7/5
no ip address
shutdown
interface GigabitEthernet7/6
no ip address
shutdown
interface GigabitEthernet7/7
no ip address
shutdown
interface GigabitEthernet7/8
no ip address
shutdown
interface GigabitEthernet7/9
no ip address
shutdown
interface GigabitEthernet7/10
no ip address
shutdown
interface GigabitEthernet7/11
no ip address
shutdown
interface GigabitEthernet7/12
no ip address
shutdown
interface GigabitEthernet7/13
no ip address
shutdown
interface GigabitEthernet7/14
no ip address
shutdown
interface GigabitEthernet7/15
no ip address
shutdown
interface GigabitEthernet7/16
no ip address
shutdown
interface GigabitEthernet7/17
no ip address
shutdown
interface GigabitEthernet7/18
no ip address
shutdown
interface GigabitEthernet7/19
no ip address
shutdown
interface GigabitEthernet7/20
no ip address
shutdown
interface GigabitEthernet7/21
no ip address
shutdown
interface GigabitEthernet7/22
no ip address
shutdown
interface GigabitEthernet7/23
no ip address
shutdown
interface GigabitEthernet7/24
no ip address
shutdown
interface GigabitEthernet7/25
no ip address
shutdown
interface GigabitEthernet7/26
no ip address
shutdown
interface GigabitEthernet7/27
no ip address
shutdown
interface GigabitEthernet7/28
no ip address
shutdown
interface GigabitEthernet7/29
no ip address
shutdown
interface GigabitEthernet7/30
no ip address
shutdown
interface GigabitEthernet7/31
no ip address
shutdown
interface GigabitEthernet7/32
no ip address
shutdown
interface GigabitEthernet7/33
no ip address
shutdown
interface GigabitEthernet7/34
no ip address
shutdown
interface GigabitEthernet7/35
no ip address
shutdown
interface GigabitEthernet7/36
no ip address
shutdown
interface GigabitEthernet7/37
no ip address
shutdown
interface GigabitEthernet7/38
no ip address
shutdown
interface GigabitEthernet7/39
no ip address
shutdown
interface GigabitEthernet7/40
no ip address
shutdown
interface GigabitEthernet7/41
no ip address
shutdown
interface GigabitEthernet7/42
no ip address
shutdown
interface GigabitEthernet7/43
no ip address
shutdown
interface GigabitEthernet7/44
no ip address
shutdown
interface GigabitEthernet7/45
no ip address
shutdown
interface GigabitEthernet7/46
no ip address
shutdown
interface GigabitEthernet7/47
switchport
switchport access vlan 8
no ip address
spanning-tree portfast
interface GigabitEthernet7/48
no ip address
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 192.168.88.1 255.255.255.0
interface Vlan5
ip address 192.168.99.2 255.255.255.0
interface Vlan7
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.88.2
ip route 192.168.1.0 255.255.255.0 192.168.99.1
no ip http server
control-plane
dial-peer cor custom
line con 0
line vty 0 4
no cns aaa enable
end
Router#$
Router#
Router#
Router#show hard
发表于 2008-10-28 16:03:38 | 显示全部楼层
 楼主| 发表于 2008-10-29 16:43:54 | 显示全部楼层
补充说明一下。。由于客户那需要保密。我只是做了个简单的示范试验。。具体更多内容,我们可以私下交流。。。
GMT+8, 2026-11-12 11:41 , Processed in 0.043251 second(s), 18 queries .
