查看: 2765|回复: 1
原创(刚配置完的一个ASA5505上实现的PPPOE)
发表于 2008-10-13 22:05:21 | 显示全部楼层 |阅读模式
刚实施完的PPPOE配置,里面还有一些上网时间的限制和针对个别用户和个别协议的限制,拿出来和大家分享一下
TCL(config)#
TCL# show run
: Saved
:ASA Version 7.2(3)
!hostname TCL
domain-name default.domain.invalid
*********定义IP地址和客户端的映射,或者是对IP地址的命名********************
names
name 192.168.1.9 bgs1
name 192.168.1.27 bgs2
name 192.168.1.11 licm
name 192.168.1.7 liuxb
name 192.168.1.10 FileServer
name 192.168.1.62 changjh
*************定义内网接口********************
interface Vlan1
nameif inside
security-level 100
*************定义外网接口********************
interface Vlan2
nameif outside
security-level 0
ip address pppoe setroute
interface Ethernet0/0
************将端口0/1加入到VLAN1中******************
interface Ethernet0/1
switchport access vlan 2
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd ************** encrypted
**************客户端上网时间的限制********************************
time-range everyday
periodic daily 7:50 to 21:00
time-range weekdays
periodic weekdays 7:50 to 18:10
ftp mode passive
dns server-group DefaultDNS
*****************定义不同的策略网络主机组****************************
object-group network high1
network-object host FileServer
object-group network high2
network-object host licm
network-object host cw1
network-object host lizl
********************定义不同的策略服务组************************
object-group service tcp1 tcp
port-object range www www
port-object range 81 81
object-group service tcp_dns tcp
port-object range pop3 pop3
port-object range smtp smtp
port-object range domain domain
object-group service udp_dns udp
object-group service tcp2 tcp
port-object range https https
port-object range 445 445
port-object range 465 465
port-object range 995 995
 楼主| 发表于 2008-10-13 22:05:48 | 显示全部楼层
*************针对上面的用户和服务组(类)制定访问控制策略****************
access-list inside_access_in extended permit tcp any any object-group tcp_dns log disable
access-list inside_access_in extended permit udp any any object-group udp_dns log disable
access-list inside_access_in extended permit tcp object-group high1 any object-group tcp1 log disable
access-list inside_access_in extended permit tcp object-group high2 any object-group tcp2 log disable time-range everyday
access-list inside_access_in extended permit tcp object-group high3 any object-group tcp2 log disable time-range everyday
access-list inside_access_in extended permit ip object-group normal1 any log disable time-range everyday
access-list inside_access_in extended permit tcp object-group normal2 any object-group tcp1 log disable time-range everyday
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
asdm image disk0:/asdm-523.bin
no asdm history enable
*******************ip地址和MAC地址绑定*******************************
arp inside 192.168.1.150 000d.87c5.9876
arp inside xuerx1 0002.a59b.453b
arp inside 192.168.1.115 0013.d3de.4376
arp inside gaoyf 00c0.9f26.f0da
arp inside guopy 0009.6be3.25f4
arp inside hehx 00c0.9f26.ee16
arp timeout 14400
*************配置NAT转换*********************************
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
******************配置默认路由*******************
route outside 0.0.0.0 0.0.0.0 118.81.66.1 1
timeout xlate 3:00:00
*************配置客户端管理ASDM*******************************
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
telnet timeout 10
ssh timeout 5
console timeout 0
*******************配置PPPOE*****************************************
vpdn group adsl request dialout pppoe
vpdn group adsl localname *******
vpdn group adsl ppp authentication pap
vpdn username gslr password *********
dhcpd auto_config outside
class-map inspection_default
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
username root password ************* encrypted privilege 15
prompt hostname context
Cryptochecksum:**************f
: end
TCL#
GMT+8, 2026-11-12 11:42 , Processed in 0.044987 second(s), 18 queries .
