查看: 2285|回复: 0
ASA做时间控制上网实战配置
发表于 2008-8-21 07:21:58 | 显示全部楼层 |阅读模式
ASA做时间控制上网实战配置
上班时间不可以上网。下班和周末可以上网,配置自己看吧
sh run
: Saved
ASA Version 8.0(3)
hostname ciscoasa
enable password 9jNfZuG3TC5tCVH0 encrypted
names
interface Ethernet0/0
nameif inside
security-level 100
ip address 172.16.1.1 255.255.0.0
interface Ethernet0/1
nameif dmz1
security-level 60
ip address 192.168.100.254 255.255.255.0
interface Ethernet0/2
nameif outside
security-level 0
ip address 10.10.184.2 255.255.254.0
interface Ethernet0/3
nameif dmz2
security-level 50
ip address 192.168.101.254 255.255.255.0
interface Management0/0
shutdown
no nameif
no security-level
no ip address
passwd 9jNfZuG3TC5tCVH0 encrypted
time-range shangban
periodic weekdays 0:00 to 6:59
periodic weekdays 11:00 to 13:59
periodic weekdays 17:30 to 23:59
periodic weekend 0:00 to 23:59
ftp mode passive
clock timezone HKST 8
dns domain-lookup inside
dns domain-lookup outside
access-list outside_acl extended permit icmp any any
access-list outside_acl extended permit ip any any
access-list dmz1_in extended permit icmp any any
access-list dmz1_in extended permit ip any any
access-list dmz2_in extended permit ip any any
access-list dmz2_in extended permit icmp any any
access-list inside_nonat extended permit ip 172.16.0.0 255.255.0.0 192.168.100.0 255.255.255.0
access-list inside_nonat extended permit ip 172.16.0.0 255.255.0.0 192.168.101.0 255.255.255.0
access-list inside extended permit ip any any
access-list shangban extended permit ip host 192.168.100.150 any time-range shangban
access-list shangban extended permit ip host 192.168.101.200 any time-range shangban
access-list shangban extended permit ip host 172.16.2.200 any
access-list shangban extended permit ip host 172.16.2.201 any
access-list shangban extended permit ip host 172.16.2.202 any
access-list shangban extended permit ip host 172.16.2.203 any
access-list shangban extended permit ip host 172.16.2.204 any
access-list shangban extended permit ip host 172.16.2.205 any
access-list shangban extended permit ip host 172.16.2.206 any
access-list shangban extended permit ip host 172.16.2.207 any
access-list shangban extended permit ip host 172.16.2.208 any
access-list shangban extended permit ip host 172.16.2.209 any
access-list shangban extended permit ip host 172.16.2.210 any
access-list shangban extended permit ip host 172.16.2.211 any
access-list shangban extended permit ip host 172.16.2.212 any
access-list shangban extended permit ip host 172.16.2.213 any
access-list shangban extended permit ip host 172.16.2.214 any
access-list shangban extended permit ip host 172.16.2.215 any
access-list shangban extended permit ip host 172.16.2.216 any
access-list shangban extended permit ip host 172.16.2.217 any
access-list shangban extended permit ip host 172.16.2.218 any
access-list shangban extended permit ip host 172.16.2.219 any
access-list shangban extended permit ip host 172.16.2.220 any
access-list shangban extended permit ip host 172.16.2.221 any
access-list shangban extended permit ip host 172.16.2.222 any
access-list shangban extended permit ip host 172.16.2.223 any
access-list shangban extended permit ip host 172.16.2.224 any
access-list shangban extended permit ip host 172.16.2.225 any
access-list shangban extended permit ip host 172.16.2.226 any
access-list shangban extended permit ip host 172.16.2.227 any
access-list shangban extended permit ip host 172.16.2.228 any
access-list shangban extended permit ip host 172.16.2.229 any
access-list shangban extended permit ip host 172.16.2.230 any
access-list shangban extended permit ip host 172.16.2.231 any
access-list shangban extended permit ip host 172.16.2.232 any
access-list shangban extended permit ip host 172.16.2.233 any
access-list shangban extended permit ip host 172.16.2.234 any
access-list shangban extended permit ip host 172.16.2.235 any
access-list shangban extended permit ip host 172.16.2.236 any
access-list shangban extended permit ip host 172.16.2.237 any
access-list shangban extended permit ip host 172.16.2.238 any
access-list shangban extended permit ip host 172.16.2.239 any
access-list shangban extended permit ip 172.16.0.0 255.255.0.0 10.0.0.0 255.0.0.0
access-list shangban extended permit ip 172.16.0.0 255.255.0.0 host 61.177.7.1
pager lines 24
mtu inside 1500
mtu dmz1 1500
mtu outside 1500
mtu dmz2 1500
asdm image disk0:/asdm-603.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nonat
nat (inside) 1 172.16.0.0 255.255.0.0
alias (inside) 10.10.185.250 192.168.100.150 255.255.255.255
alias (inside) 10.10.185.252 192.168.101.200 255.255.255.255
static (dmz1,outside) 10.10.185.250 192.168.100.150 netmask 255.255.255.255
static (dmz2,outside) 10.10.185.252 192.168.101.200 netmask 255.255.255.255
access-group shangban in interface inside
access-group dmz1_in in interface dmz1
access-group outside_acl in interface outside
access-group dmz2_in in interface dmz2
route outside 0.0.0.0 0.0.0.0 10.10.184.1 1
timeout xlate 3:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 61.177.7.1
dhcpd domain ydzx
dhcpd address 172.16.1.2-172.16.2.1 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics
ntp server 172.16.0.0
!class-map inspection_default
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
prompt hostname context
Cryptochecksum:eb3a449d21220adaff801db491f1a3c3
: end
ciscoasa#
GMT+8, 2026-11-12 11:43 , Processed in 0.049102 second(s), 18 queries .
