查看: 3041|回复: 2
Cisco路由器流量控制实例
发表于 2008-4-26 06:33:27 | 显示全部楼层 |阅读模式
Cisco路由器流量控制实例
       网上关于Qos资料太多了,但很多不实用,讲了一大堆理论,下面是我们一子公司的路由器上的配置,供大家参考。其实,只要理解了NBAR、CBWFQ、WRED等意义,流量控制就可以随心配置。
说明:
       一家子公司使用2M专线上网,内部网段为192.168.23.0/24(普通员工)和192.168.24.0/24(总经办所在的VLAN),其中路由器IP地址为:192.168.23.1,内部cisco3560交换机IP为:192.168.23.254。现需要作流量控制,使总经办的流量比较优先,并优先传送一些声音与视频及网管流量。其它的服务如:smtp、pop3及ftp等为低优先级,并禁止bt下载等。
配置如下:
Current configuration : 3590 bytes
version 12.3
service timestamps debug datetime
service timestamps log datetime
service password-encryption
hostname xxxxxx
enable secret 5 $44adf#dfdfj090$on
clock timezone China 8
ip subnet-zero
no ip source-route
ip cef
ip name-server 192.168.23.2
ip name-server x.x.x.x
no ip bootp server
ip nbar pdlm flash:bittorrent.pdlm
class-map match-any premium_class
description For premium
match protocol http
match protocol icmp
match protocol netshow
match protocol pcanywhere
match protocol realaudio
match protocol secure-http
match access-group 111
注:以上有省略,嘿嘿!
class-map match-any normal_calss
description For normal
match protocol ftp
match protocol imap
match protocol pop3
match protocol smtp
match access-group 110
class-map match-any bt_download
description For drop
match protocol bittorrent
policy-map qos_policy_map
class premium_class
bandwidth percent 50
random-detect
random-detect exponential-weighting-constant 4
police cir 2000000 bc 10000 be 10000
conform-action transmit
exceed-action transmit
class normal_calss
bandwidth percent 25
random-detect
police cir 2000000 bc 2000 be 2000
exceed-action drop
class bt_download
drop
interface FastEthernet0/0
ip address 192.168.23.1 255.255.255.0
ip verify unicast reverse-path
ip nat inside
ip route-cache same-interface
ip route-cache policy
duplex auto
speed auto
no cdp enable
interface Serial0/0
bandwidth 2048
ip address 210.88.44.x 255.255.255.252
no ip proxy-arp
ip nat outside
rate-limit input 2000000 20000 20000 conform-action transmit exceed-action drop
service-policy output qos_policy_map
no cdp enable
ip nat inside source list 10 interface Serial0/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 210.88.44.y
ip route 192.168.24.0 255.255.255.0 192.168.23.254
no ip http server
access-list 10 remark NAT
access-list 10 permit 192.168.23.0 0.0.0.255
access-list 10 permit 192.168.24.0 0.0.0.255
access-list 110 remark normal
access-list 110 permit ip 192.168.23.0 0.0.0.255 any
access-list 111 remark premium
access-list 111 permit ip 192.168.24.0 0.0.0.255 any
no cdp run
banner motd ^cml system router !!!^C
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password 7 121A0C0411045D5D7C
login
end
注:互联网带宽为2M,故WRED中的指数加权因子为4,最小阀值为5,最大阀值为17,标记几率分母为1。
发表于 2008-12-23 16:46:16 | 显示全部楼层
GMT+8, 2026-11-12 11:30 , Processed in 0.077540 second(s), 18 queries .
