查看: 3187|回复: 2
CheckPoint smartportal的使用方法
发表于 2008-4-16 12:56:47 | 显示全部楼层 |阅读模式
1.在专用的服务器上部署smartportal
1.1 在smartportal安装过程中需要输入SIC,同smartcenter建立信任关系
2.1 在smartcenter上创建smartportal的对象,并且在checkpoint产品列表中选择smartportal
2.3 添加允许访问smarttportal的访问控制策略
2.4 创建管理用户,通过smartportal控制权限。
2.在smartcenter上部署smartportal
2.1 在smartcenter上安装smartportal,并选择该产品
2.2 添加访问规则允许访问到smartcenter的4433到他本身。
2.3 创建管理用户给smartportal用户分配不同权限。
3.smartportal的配置和命令
smartportal的命令
smartportalstop
smartportalstart
通过指定地址限制访问
SmartPortal and create the hosts.allow file under the SmartPortal conf directory
(in Windows: C:\program files\CheckPoint\R65\SmartPortal\portal\conf and in
Solaris, Linux and SecurePlatform: /opt/CPportal-R65/portal/conf). If the
hosts.allow file is not in the SmartPortal conf directory you should create it if it
is required.
The file format is:
ALL: ALL (to allow all IPs)
ALL: x.x.x.x (to allow specific IPs)
ALL: x.x.x.x/y.y.y.y (to allow specific networks where x.x.x.x is the IP
address and y.y.y.y is the netmask)
更改web server的端口 defult是tcp4433
发表于 2008-5-2 13:39:02 | 显示全部楼层
好贴子哦,大家不顶说不过去
好贴子哦,大家不顶说不过去
There is buy wow gold web; you can buy really cheap wow gold here.Buy professional power leveling services,Cheap WoW Gold,Cheap WoW Gold,Cheap WoW Gold,Cheap WoW Gold,
发表于 2008-5-11 17:21:18 | 显示全部楼层
上海亚步申请链接
GMT+8, 2026-11-8 03:09 , Processed in 0.033021 second(s), 18 queries .
