查看: 4379|回复: 3
不同的类UNIX操作系统密码破解方法介绍
发表于 2008-3-18 17:01:59 | 显示全部楼层 |阅读模式
(一)Linux 系统密码破解
1.在grub选项菜单按E进入编辑模式
2.编辑kernel那行 /init 1 (或/single)
3.按B重启
4.进入后执行下列命令
root@#passwd root (设置root的密码)
Enter new unix password:输入新的密码
root@#init 6
(二)debian linux 系统密码破解
1.在grub选项菜单'Debian GNU/Linux,...(recovery mode)',按e进入编辑模式
2.编辑kernel那行最后面的 ro single 改成 rw single init=/bin/bash,按b执行重启
3.进入后执行下列命令
root@(none)#mount -a
root@(none)#passwd root
root@(none)#reboot
(三)Freebsd 系统密码破解
1.开机进入引导菜单
2.选择每项(按4)进入单用户模式
3.进入之后输入一列命令
root@#mount -a
root@#fsck -y
root@#passwd(修改密码命令)
root@#root(要破解密码的用户名)
root@#init 6 (重启)
(四)Solaris 系统密码破解
1.在grub选项菜中选择solaris failasfe 项
2.系统提示Do you wish to have it mounted read-write on /a ?[y,n,?] 选择y
3.就进入单用户模式
4.输入下列命令
#passwd
#New passwd:输入新的密码
#Re-enter New passwd:在次输入新的密码
#init 6 (重启)
(五)NetBsd 系统密码破解
1.开机:当出现提示符号并开始倒数五秒时, 键入以下指令:
> boot -s (进入单用户模式命令)
2.在以下的提示符号中
Enter pathname of shell or RETURN for sh:
按下 Enter。
3.键入以下指令:
# mount -a
# fsck -y
4.使用 passwd 更改 root 的密码。
5.使用 exit 指令进入多人模式。
来源:Linux技术中坚站
发表于 2008-12-27 12:44:02 | 显示全部楼层
Why Pay Them When You Can Do it Yourself
Time and again I've run into entrepreneurs wedding invitations who are avidly seeking representation for publicity.wedding invitations These savvy entrepreneurs realize that exposure to the masses is a necessity for success in business but have convinced themselves that they require the services of a skilled professional -ergo a publicist, to get the job done effectively.wedding dresses Two publicity campaigns and thousands of dollars later a little light bulb goes off in their head bringing them to the realization, full lace wigs with all things considered (regarding the unsavory results of their pr campaigns), that they could've done the pr strong-arming on their own.lace wigs And you know what -- they are absolutely right!
发表于 2009-10-8 04:53:29 | 显示全部楼层
敢死队似的营销
发表于 2009-12-26 09:21:54 | 显示全部楼层
DNF天神外挂谁用过
GMT+8, 2026-10-18 17:39 , Processed in 0.036187 second(s), 18 queries .
