查看: 2152|回复: 0
2403H-EI pvlan功能实现典型案例
发表于 2008-3-16 09:20:15 | 显示全部楼层 |阅读模式
组网描述:
PC-------------------2403H-EI---------------SECPATH100N----------------------ADSL猫----------------INTERNET
功能实现:
2403H-EI下挂的1到24口的PC实现两两隔离,都通过25口上行上公网.
2403H-EI 配置
[Quidway]qu
<Quidway>dir
Directory of flash:/
-rwxrwxrwx   1 noone    nogroup   2737939  Apr 02 2000 00:17:58   2403.app
-rwxrwxrwx   1 noone    nogroup         8  Apr 01 2000 23:55:18   snmpboots
-rwxrwxrwx   1 noone    nogroup      3674  Apr 02 2000 00:33:05   vrpcfg.txt
-rwxrwxrwx   1 noone    nogroup    445224  Apr 02 2000 00:01:14   wnm2.2.2-0003.zip   用于WEB网管,若不能WEB网管,检查此目录下是否有此文件.
3381248 bytes total (190464 bytes free)
<Quidway>dis ver
Huawei Versatile Routing Platform Software
VRP (R) Software, Version 3.10, RELEASE 0017
Copyright (c) 2000-2004 HUAWEI TECH CO., LTD.
uptime is 0 week,0 day,0 hour,58 minutes
32M    bytes SDRAM
4096K   bytes Flash Memory
Config Register points to FLASH
Hardware Version is VER.D
Bootrom Version is 109
[Subslot 0] 25 FE        Hardware Version is VER.D
<Quidway>dis cu
sysname Quidway
radius scheme system
server-type huawei
primary authentication 127.0.0.1 1645
primary accounting 127.0.0.1 1646
user-name-format without-domain
domain system
radius-scheme system
access-limit disable
state active
vlan-assignment-mode integer
idle-cut disable
self-service-url disable
messenger time disable
domain default enable system
local-server nas-ip 127.0.0.1 key huawei
local-user telnet                         交换机的telnet和web网管时的用户名和密码
password simple telnet
service-type telnet level 3
vlan range 1-511
queue-scheduler wrr 1 2 4 8
vlan 1
vlan 2
vlan 3
vlan 4
vlan 5
vlan 6
vlan 7
vlan 8
vlan 9
vlan 10
vlan 11
vlan 12
vlan 13
vlan 14
vlan 15
vlan 16
vlan 17
vlan 18
vlan 19
vlan 20
vlan 21
vlan 22
vlan 23
vlan 24
vlan 100
vlan 500
interface Vlan-interface1
ip address 192.168.1.100 255.255.255.0               交换机的管理地址
interface Aux0/0
interface Ethernet0/1
port link-type hybrid
port hybrid vlan 1 100 untagged
interface Ethernet0/2
port hybrid vlan 2 100 untagged
port hybrid pvid vlan 2
interface Ethernet0/3
port hybrid vlan 3 100 untagged
port hybrid pvid vlan 3
interface Ethernet0/4
port hybrid vlan 4 100 untagged
port hybrid pvid vlan 4
interface Ethernet0/5
port hybrid vlan 5 100 untagged
port hybrid pvid vlan 5
interface Ethernet0/6
port hybrid vlan 6 100 untagged
port hybrid pvid vlan 6
interface Ethernet0/7
port hybrid vlan 7 100 untagged
port hybrid pvid vlan 7
interface Ethernet0/8
port hybrid vlan 8 100 untagged
port hybrid pvid vlan 8
interface Ethernet0/9
port hybrid vlan 9 100 untagged
port hybrid pvid vlan 9
interface Ethernet0/10
port hybrid vlan 10 100 untagged
port hybrid pvid vlan 10
interface Ethernet0/11
port hybrid vlan 11 100 untagged
port hybrid pvid vlan 11
interface Ethernet0/12
port hybrid vlan 12 100 untagged
port hybrid pvid vlan 12
interface Ethernet0/13
port hybrid vlan 13 100 untagged
port hybrid pvid vlan 13
interface Ethernet0/14
port hybrid vlan 14 100 untagged
port hybrid pvid vlan 14
interface Ethernet0/15
port hybrid vlan 15 100 untagged
port hybrid pvid vlan 15
interface Ethernet0/16
port hybrid vlan 16 100 untagged
port hybrid pvid vlan 16
interface Ethernet0/17
port hybrid vlan 17 100 untagged
port hybrid pvid vlan 17
interface Ethernet0/18
port hybrid vlan 18 100 untagged
port hybrid pvid vlan 18
interface Ethernet0/19
port hybrid vlan 19 100 untagged
port hybrid pvid vlan 19
interface Ethernet0/20
port hybrid vlan 20 100 untagged
port hybrid pvid vlan 20
interface Ethernet0/21
port hybrid vlan 21 100 untagged
port hybrid pvid vlan 21
interface Ethernet0/22
port hybrid vlan 22 100 untagged
port hybrid pvid vlan 22
interface Ethernet0/23
port hybrid vlan 23 100 untagged
port hybrid pvid vlan 23
interface Ethernet0/24
port hybrid vlan 24 100 untagged
port hybrid pvid vlan 24
interface Ethernet0/25                         此端口用于上行,其它端口接PC,实现端口的两两隔离
port hybrid vlan 1 to 24 100 untagged
port hybrid pvid vlan 100
interface NULL0
user-interface aux 0
user-interface vty 0 4
authentication-mode scheme
return
<Quidway>
GMT+8, 2026-11-12 11:53 , Processed in 0.045224 second(s), 18 queries .
