查看: 1983|回复: 1
ASA SSL VPN&Failover 配置亲情奉献!!!
发表于 2008-3-14 06:00:42 | 显示全部楼层 |阅读模式
: Saved
ASA Version 7.2(3)18
hostname BJ-CA-ASA-1
domain-name BJ-CA-ASA-2
enable password ECCUaJvvj6rilQTW encrypted
passwd .Pppqn8rWgaGlh3f encrypted
names
dns-guard
interface GigabitEthernet0/0
description Link-TO-PIX-DMZ
mac-address 001b.d454.e198 standby 001b.d46e.3966
nameif outside
security-level 0
ip address 192.168.224.27 255.255.255.248 standby 192.168.224.28
interface GigabitEthernet0/1
description Link-TO-Intranet
mac-address 001b.d454.e199 standby 001b.d46e.3967
nameif inside
security-level 100
ip address 192.168.224.33 255.255.255.248 standby 192.168.224.37
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
description LAN/STATE Failover Interface
interface Management0/0
nameif manage
security-level 0
boot system disk0:/asa723-18-k8.bin
ftp mode passive
clock timezone BeiJing 8
dns domain-lookup inside
dns server-group DefaultDNS
timeout 4
name-server 192.168.2.12
name-server 192.168.32.32
name-server 192.168.32.31
domain-name HD-ASA5540
same-security-traffic permit intra-interface
access-list inside_nat0_outbound extended permit ip host 191.10.4.21 host 191.100.227.192
access-list outside_cryptomap_20 extended permit ip host 191.10.4.21 host 191.100.227.192
access-list outside_cryptomap_dyn_21 extended permit ip any host 192.168.236.200
access-list VPN extended permit ip 192.168.247.0 255.255.255.0 192.168.230.0 255.255.255.0
access-list VPN extended permit ip 192.168.248.0 255.255.255.0 192.168.230.0 255.255.255.0
access-list Inbound extended permit ip any any
access-list Split_Tunnel_List remark The corporate network behind the ASA.
access-list Split_Tunnel_List standard deny 192.168.254.0 255.255.255.0
access-list Split_Tunnel_List standard deny 192.168.115.0 255.255.255.0
access-list SOHO-ACL remark The network out of the LAN.
access-list SOHO-ACL standard deny 192.168.252.0 255.255.255.0
access-list SOHO-ACL standard permit 192.168.0.0 255.240.0.0
access-list SOHO-ACL standard permit 10.0.0.0 255.0.0.0
pager lines 24
logging enable
logging timestamp
logging buffer-size 20480
logging buffered debugging
logging trap debugging
logging asdm informational
logging host inside 192.168.90.27
mtu outside 1500
mtu inside 1500
mtu manage 1500
ip local pool TESTpool 192.168.230.10-192.168.230.100
failover
failover lan unit pri
failover lan interface state GigabitEthernet0/3
failover polltime unit msec 300 holdtime 1
failover replication http
failover link state GigabitEthernet0/3
failover interface ip state 192.168.2.1 255.255.255.0 standby 192.168.2.2
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
nat (inside) 0 access-list inside_nat0_outbound
route-map 115-ospf permit 10
match ip address 15
route outside 192.168.224.1 255.255.255.255 192.168.224.25 1
route outside 0.0.0.0 0.0.0.0 192.168.224.25 1
router ospf 100
network 192.168.224.32 255.255.255.248 area 0
log-adj-changes
redistribute static subnets route-map 115-ospf
timeout xlate 3:00:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
ldap attribute-map cisco1
ldap attribute-map cisco2
aaa-server HQ.CORP.DFL protocol ldap
aaa-server HQ.CORP.DFL (inside) host 192.168.32.33
server-port 389
ldap-base-dn dc=hq,dc=corp,dc=dfl
ldap-scope subtree
ldap-naming-attribute sAMAccountName
ldap-login-password *
ldap-login-dn CN=acs_svc_test,ou=802.1x,ou=Service Accounts,dc=hq,dc=corp,dc=dfl
server-type auto-detect
ldap-attribute-map cisco1
aaa-server PVI protocol ldap
aaa-server PVI (inside) host 192.168.32.35
ldap-base-dn ou=363310,ou=363300,ou=363000,ou=360000,ou=300000,ou=000000,dc=pvi,dc=corp,dc=dfl
ldap-scope subtree
ldap-login-dn CN=sslvpntest,ou=TEST,dc=pvi,dc=corp,dc=dfl
server-type microsoft
ldap-attribute-map cisco2
aaa-server PVI-HD protocol ldap
aaa-server PVI-HD (inside) host 192.168.16.1
ldap-scope subtree
http server enable 8080
http 192.168.227.0 255.255.255.0 manage
snmp-server host inside 192.168.90.27 community xxxxxx
no snmp-server location
no snmp-server contact
snmp-server community fengshen
service resetoutside
crypto ipsec transform-set vpnset esp-des esp-md5-hmac
crypto dynamic-map dyn1 1 set transform-set SET1
crypto dynamic-map dyn1 1 set reverse-route
crypto dynamic-map vpn-map 10 set transform-set vpnset
crypto map mymap1 65535 ipsec-isakmp dynamic dyn1
crypto map vpn 10 ipsec-isakmp dynamic vpn-map
crypto map vpn interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption des
hash md5
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 7200
crypto isakmp nat-traversal  15
telnet 192.168.254.0 255.255.255.0 inside
telnet timeout 30
ssh timeout 5
console timeout 0
ntp server 192.168.254.1
tftp-server inside 192.168.90.48 BG-ASA-5520-1
webvpn
enable outside
url-list BookMarks "SEA" http://oa.wujin.gov 1
url-list BookMarks "EHR" http://oa.wujin.gov 2
tunnel-group-list enable
group-policy DfltGrpPolicy attributes
banner none
wins-server none
dns-server none
dhcp-network-scope none
vpn-access-hours none
vpn-simultaneous-logins 3
vpn-idle-timeout 30
vpn-session-timeout none
vpn-filter none
vpn-tunnel-protocol IPSec l2tp-ipsec webvpn
password-storage disable
ip-comp disable
re-xauth disable
group-lock none
pfs disable
ipsec-udp disable
ipsec-udp-port 10000
split-tunnel-network-list none
default-domain none
split-dns none
intercept-dhcp 255.255.255.255 disable
secure-unit-authentication disable
user-authentication disable
user-authentication-idle-timeout 30
ip-phone-bypass disable
leap-bypass disable
nem disable
backup-servers keep-client-config
msie-proxy server none
msie-proxy method no-modify
msie-proxy except-list none
msie-proxy local-bypass disable
nac disable
nac-sq-period 300
nac-reval-period 36000
nac-default-acl none
address-pools none
smartcard-removal-disconnect enable
client-firewall none
client-access-rule none
webvpn
  functions url-entry
  html-content-filter none
  homepage none
  keep-alive-ignore 4
  http-comp gzip
  filter none
  url-list value BookMarks
  customization value DfltCustomization
  port-forward none
  port-forward-name value Application Access
  sso-server none
  deny-message value Login was successful, but because certain criteria have not been met or due to some specific group policy, you do not have permission to use any of the VPN features. Contact your IT administrator for more information
  svc none
  svc keep-installer installed
  svc keepalive none
  svc rekey time none
  svc rekey method none
  svc dpd-interval client none
  svc dpd-interval gateway none
  svc compression deflate
group-policy lanyou internal
group-policy lanyou attributes
split-tunnel-policy tunnelall
group-policy zttest internal
group-policy zttest attributes
dns-server value 192.168.2.12 192.168.247.4
vpn-filter value deny-access-internet
split-tunnel-network-list value Deny-access-internet
group-policy C-WH-OA-SJGLB internal
group-policy C-WH-OA-SJGLB attributes
wins-server none
default-domain none
webvpn
group-policy PVI internal
group-policy PVI attributes
webvpn
username ZERO password uybI0kx6cyjrSF.a encrypted
username ZERO attributes
vpn-group-policy VLS
vpn-framed-ip-address 192.168.230.100 255.255.255.0
tunnel-group DefaultL2LGroup ipsec-attributes
isakmp keepalive threshold infinite
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *
isakmp keepalive threshold 10 retry 10
tunnel-group testzt type ipsec-ra
tunnel-group testzt ipsec-attributes
pre-shared-key *
class-map inspection_default
parameters
  message-length maximum 512
policy-map type inspect dns migrated_dns_map_1
parameters
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
prompt hostname context
Cryptochecksum:a20bac683f09ac91d037a243b58c8ab3
: end
 楼主| 发表于 2008-3-14 06:00:56 | 显示全部楼层
备的一侧
: Saved
hostname BJ-CA-ASA-2
names
dns-guard
nameif outside
security-level 0
nameif inside
security-level 100
shutdown
no nameif
no security-level
no ip address
nameif manage
security-level 0
ftp mode passive
timeout 4
pager lines 24
logging enable
logging timestamp
mtu outside 1500
mtu inside 1500
mtu manage 1500
failover
failover lan unit secondary
arp timeout 14400
match ip address 15
router ospf 100
log-adj-changes
server-port 389
ldap-scope subtree
ldap-scope subtree
ldap-scope subtree
encryption des
hash md5
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 7200
telnet timeout 30
ssh timeout 5
console timeout 0
webvpn
enable outside
banner none
wins-server none
dns-server none
vpn-idle-timeout 30
vpn-filter none
ip-comp disable
re-xauth disable
group-lock none
pfs disable
ipsec-udp disable
default-domain none
split-dns none
leap-bypass disable
nem disable
nac disable
nac-sq-period 300
address-pools none
webvpn
  functions url-entry
  homepage none
  keep-alive-ignore 4
  http-comp gzip
  filter none
  port-forward none
  sso-server none
  svc none
  svc keepalive none
  svc rekey time none
wins-server none
default-domain none
webvpn
webvpn
pre-shared-key *
pre-shared-key *
parameters
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
: end
GMT+8, 2026-11-12 11:53 , Processed in 0.031419 second(s), 18 queries .
