查看: 2381|回复: 3
号称最稳定 Linux内核2.6.24版本发布
发表于 2008-2-1 10:31:24 | 显示全部楼层 |阅读模式
作为 Linux 操作系统核心的 Kernel 最新稳定版 2.6.24 在今日得以发布。根据 Kernel Newbies 网站的描述,Linux Kernel 2.6.24 改善了 CFS、针对 x86-64、PPC、UML、ARM、MIPS 等架构添加了 Tickless 支持、新增了无线驱动程序及配置界面、引入了 Anti-fragmentation 补丁、使 MMC 层获得了 SPI/SDIO 支持、添加了 USB authorization、per-device dirty thresholds、PID 及网络命名空间、针对 TCP 流量的 LRO (Large Receive Offload) 支持、TCG (Task Control Groups)、Linux Kernel Markers、read-only bind mounts、x86-32/64 arch reunification 等特性。
此外,该版本的 Linux 内核还添加了包括显卡、SATA/IDE、网络、声卡、MTD、USB、V4L/DVB、Hwmon、I2C、蓝芽等设备在内的新驱动程序。你可以从 The Linux Kernel Archives 网站获取 Linux Kernel 2.6.24 的源代码及补丁。
下载:http://www.kernel.org/pub/linux/kernel/v2.6/patch-2.6.24.bz2
chengelog:
commit 49914084e797530d9baaf51df9eda77babc98fa8
Author: Linus Torvalds <torvalds@woody.linux-foundation.org>
Date:   Thu Jan 24 14:58:37 2008 -0800
    Linux 2.6.24
commit feed9bab7b14b77be8d796bcee95e2343fb82955
Author: Kalle Valo <kalle.valo@nokia.com>
Date:   Thu Jan 24 14:00:40 2008 -0800
    spi: omap2_mcspi PIO RX fix
    Before transmission of the last word in PIO RX_ONLY mode rx+tx mode
    is enabled:
            /* prevent last RX_ONLY read from triggering
             * more word i/o: switch to rx+tx
            if (c == 0 && tx == NULL)
                    mcspi_write_cs_reg(spi,
                                    OMAP2_MCSPI_CHCONF0, l);
    But because c is decremented after the test, c will never be zero and
    rx+tx will not be enabled. This breaks RX_ONLY mode PIO transfers.
    Fix it by decrementing c in the beginning of the various I/O loops.
    Signed-off-by: Kalle Valo <kalle.valo@nokia.com>
    Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
    Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
    Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
commit dbcc2ec60fe15448e5dfe4153f7347ac82b4da73
Date:   Thu Jan 24 13:35:10 2008 -0800
    Revert "mac80211: warn when receiving frames with unaligned data"
    This reverts commit 81100eb80add328c4d2a377326f15aa0e7236398 for the
    release, to avoid the unnecessary warning noise that is only really
    relevant to wireless driver developers.
    The warning will probably go right back in after I cut the release, but
    at least we won't unnecessarily worry users.
    Acked-by: John W. Linville <linville@tuxdriver.com>
commit 9c09a95cf431fcf5720f2e408befa24b32b8cf4d
Author: Mel Gorman <mel@csn.ul.ie>
Date:   Thu Jan 24 05:49:54 2008 -0800
    slab: partially revert list3 changes
    Partial revert the changes made by 04231b3002ac53f8a64a7bd142fde3fa4b6808c6
    to the kmem_list3 management. On a machine with a memoryless node, this
    BUG_ON was triggering
            static void *____cache_alloc_node(struct kmem_cache *cachep, gfp_t flags, int nodeid)
                    struct list_head *entry;
                    struct slab *slabp;
                    struct kmem_list3 *l3;
                    void *obj;
                    int x;
                    l3 = cachep->nodelists[nodeid];
                    BUG_ON(!l3);
    Signed-off-by: Mel Gorman <mel@csn.ul.ie>
    Cc: Pekka Enberg <penberg@cs.helsinki.fi>
    Acked-by: Christoph Lameter <clameter@sgi.com>
    Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
    Cc: Nishanth Aravamudan <nacc@us.ibm.com>
    Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
    Cc: Paul Mackerras <paulus@samba.org>
    Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
commit c5c99429fa57dcf6e05203ebe3676db1ec646793
Author: Larry Woodman <lwoodman@redhat.com>
Date:   Thu Jan 24 05:49:25 2008 -0800
    fix hugepages leak due to pagetable page sharing
    The shared page table code for hugetlb memory on x86 and x86_64
    is causing a leak.  When a user of hugepages exits using this code
    the system leaks some of the hugepages.
    Part of /proc/meminfo just before database startup:
    HugePages_Total:  5500
    HugePages_Free:   5500
    HugePages_Rsvd:      0
    Hugepagesize:     2048 kB
    Just before shutdown:
    HugePages_Free:   4475
    HugePages_Rsvd:      0
    After shutdown:
    HugePages_Free:   4988
    HugePages_Rsvd:
    0 Hugepagesize:     2048 kB
    The problem occurs durring a fork, in copy_hugetlb_page_range().  It
    locates the dst_pte using huge_pte_alloc().  Since huge_pte_alloc() calls
    huge_pmd_share() it will share the pmd page if can, yet the main loop in
    copy_hugetlb_page_range() does a get_page() on every hugepage.  This is a
    violation of the shared hugepmd pagetable protocol and creates additional
    referenced to the hugepages causing a leak when the unmap of the VMA
    occurs.  We can skip the entire replication of the ptes when the hugepage
    pagetables are shared.  The attached patch skips copying the ptes and the
    get_page() calls if the hugetlbpage pagetable is shared.
    [akpm@linux-foundation.org: coding-style cleanups]
    Signed-off-by: Larry Woodman <lwoodman@redhat.com>
    Signed-off-by: Adam Litke <agl@us.ibm.com>
    Cc: Badari Pulavarty <pbadari@us.ibm.com>
    Cc: Ken Chen <kenchen@google.com>
    Cc: David Gibson <david@gibson.dropbear.id.au>
    Cc: William Lee Irwin III <wli@holomorphy.com>
commit c2f3dabefa73fe3307578553f456e93f0a1bca08
Author: Eric W. Biederman <ebiederm@xmission.com>
Date:   Thu Jan 24 05:52:13 2008 -0800
    sysctl: kill binary sysctl KERN_PPC_L2CR
    : Stefan Roese <sr@denx.de> said:
    > ppc: 4xx: sysctl table check failed: /kernel/l2cr .1.31 Missing strategy
    > I'm seeing this error message when booting an recent arch/ppc kernel on
    > 4xx platforms (tested on Ocotea and other 4xx platforms). Booting NFS
    > rootfs still works fine, but this message kind of makes me "nervous".
    > This is not seen on 4xx arch/powerpc platforms. Here the bootlog:
    Because the data field was never filled and a binary sysctl handler was
    never written this sysctl has never been usable through the sys_sysctl
    interface.  So just remove the binary sysctl number.  Making the kernel
    sanity checks happy.
    Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
    Reported-by: Stefan Roese <sr@denx.de>
    Cc: Josh Boyer <jwboyer@gmail.com>
    Cc: Wolfgang Denk <wd@denx.de>
commit fabe874a48de45b137f99b4ed3641e0413f465ce
Author: Arjan van de Ven <arjan@linux.intel.com>
Date:   Thu Jan 24 07:00:45 2008 +0100
    lockdep: fix kernel crash on module unload
    Michael Wu noticed in his lkml post at
        http://marc.info/?l=linux-kernel&m=119396182726091&w=2
    that certain wireless drivers ended up having their name in module
    memory, which would then crash the kernel on module unload.
    The patch he proposed was a bit clumsy in that it increased the size of
    a lockdep entry significantly; the patch below tries another approach,
    it checks, on module teardown, if the name of a class is in module space
    and then zaps the class.  This is very similar to what we already do
    with keys that are in module space.
    Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
    Signed-off-by: Ingo Molnar <mingo@elte.hu>
    Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
commit de195fd0016f9ab85f1d596dca48dade33f26d36
Author: David S. Miller <davem@davemloft.net>
Date:   Wed Jan 23 21:32:04 2008 -0800
    [SPARC64]: Partially revert "Constify function pointer tables."
    This partially reverts 872e2be7c4056496c2871bd9b0f2fae6c374fe47
    (Constify function pointer tables.)
    The solaris/socksys.c transformation wasn't valid:
    arch/sparc64/solaris/socksys.c:192: error: assignment of read-only variable ‘socksys_file_ops’
    arch/sparc64/solaris/socksys.c:195: error: assignment of read-only variable ‘socksys_file_ops’
    arch/sparc64/solaris/socksys.c:196: error: assignment of read-only variable ‘socksys_file_ops’
    Signed-off-by: David S. Miller <davem@davemloft.net>
commit ec68373c04495edbe39fb94fad963fb781e062e5
Author: Len Brown <len.brown@intel.com>
Date:   Wed Jan 23 22:41:20 2008 -0500
    Revert "ACPI: Fan: Drop force_power_state acpi_device option"
    This reverts commit 93ad7c07ad487b036add8760dabcc35666a550ef.
    http://bugzilla.kernel.org/show_bug.cgi?id=9798
    Signed-off-by: Len Brown <len.brown@intel.com>
commit d772b3b323a15588a757f5af28e51a57d0d2f622
Author: Márton Németh <nm127@freemail.hu>
Date:   Wed Jan 23 22:34:09 2008 -0500
    ACPI: EC: "DEBUG" needs to be defined earlier
    The "DEBUG" symbol needs to be defined before #including <linux/kernel.h> to
    get the pr_debug() working.
    Signed-off-by: Márton Németh <nm127@freemail.hu>
commit 86dae0154a49b67c908faffeb33ba37eddceba74
Date:   Wed Jan 23 22:33:06 2008 -0500
    ACPI: EC: add leading zeros to debug messages
    Add leading zeros to pr_debug() calls. For example if x=0x0a, the format
    "0x%2x" will result the string "0x a", the format "0x%2.2x" will result "0x0a".
commit 03d1d99c55649ca641b86d2e3489b167ede1671a
Author: Alexey Starikovskiy <astarikovskiy@suse.de>
Date:   Wed Jan 23 22:28:34 2008 -0500
    ACPI: EC: fix dmesg spam regression
    Return OBF_1 optimization workaround
    http://bugzilla.kernel.org/show_bug.cgi?id=8459
    Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de>
commit a1bd4e35e8d9df24db7d7addd74cbfcc87ec9fb3
Date:   Wed Jan 23 21:19:27 2008 -0500
    ACPI: DMI blacklist to reduce console warnings on OSI(Linux) systems.
    This DMI blacklist reduces the console messages
    on systems which have a BIOS that invokes OSI(Linux).
    As the DMI blacklist already knows about these systems,
    the request for DMI info itself is disabled.
    Further, if OSI(Linux) has already been determined
    to have no beneift, we disable the console message
    requesting acpi_osi=Linux test results.
commit 98f1db22d70b0660a27cc8818a61181b5d503671
Date:   Wed Jan 23 20:56:18 2008 -0500
    ACPI: Add ThinkPad R61, ThinkPad T61 to OSI(Linux) white-list
    acpi_osi=Linux helps sound on these systems.
commit d4b7dc499daae909e62dc260b95cd618f2970ded
Date:   Wed Jan 23 20:50:56 2008 -0500
    ACPI: make _OSI(Linux) console messages smarter
    If BIOS invokes _OSI(Linux), the kernel response
    depends on what the ACPI DMI list knows about the system,
    and that is reflectd in dmesg:
    1) System unknown to DMI:
    ACPI: BIOS _OSI(Linux) query ignored
    ACPI: DMI System Vendor: LENOVO
    ACPI: DMI Product Name: 7661W1P
    ACPI: DMI Product Version: ThinkPad T61
    ACPI: DMI Board Name: 7661W1P
    ACPI: DMI BIOS Vendor: LENOVO
    ACPI: DMI BIOS Date: 10/18/2007
    ACPI: Please send DMI info above to linux-acpi@vger.kernel.org
    ACPI: If "acpi_osi=Linux" works better, please notify linux-acpi@vger.kernel.org
    2) System known to DMI, but effect of OSI(Linux) unknown:
    ACPI: DMI detected: Lenovo ThinkPad T61
    ACPI: BIOS _OSI(Linux) query ignored via DMI
    3) System known to DMI, which disables _OSI(Linux):
    4) System known to DMI, which enable _OSI(Linux):
    ACPI: Added _OSI(Linux)
    ACPI: BIOS _OSI(Linux) query honored via DMI
    cmdline overrides take precidence over the built-in
    default and the DMI prescribed default.
    cmdline "acpi_osi=Linux" results in:
    ACPI: BIOS _OSI(Linux) query honored via cmdline
commit 7ce95ce5c6dbbc3f70933f04537860ffd9dbe17e
Date:   Wed Jan 23 20:06:41 2008 -0500
    ACPI: Delete Intel Customer Reference Board (CRB) from OSI(Linux) DMI list
    Linux does not want BIOS writers to invoke _OSI(Linux) -
    for in the field it causes more Windows incompatibility problems
    than it solves.
    So when it is seen in the BIOS for an Intel Customer Reference Board,
    Linux should ignore its effect by default, and should complain loudly.
    Otherwise, the reference BIOS will go unfixed, and the bad BIOS
    will spread to the field.
    Users of this board can get the old behavior with "acpi_osi=Linux"
    As this was the only entry, delete acpi_osl_dmi_table[].
commit f40cd6fddcb1d51d8a2a67ddc81c14a3532f3cb7
Date:   Wed Jan 23 20:04:28 2008 -0500
    ACPI: on OSI(Linux), print needed DMI rather than requesting dmidecode output
commit 5a4e143271b97dcaa113761a76942c4d4bc273a2
Date:   Wed Jan 23 20:01:22 2008 -0500
    ACPI: create acpi_dmi_dump()
    A utility routine to print common entries used
    for ACPI-related DMI blacklist entries.
commit f89e3b0620a0dc19f313218f55373b9361142203
Date:   Wed Jan 23 16:36:45 2008 -0500
    DMI: create dmi_get_slot()
    This simply allows other sub-systems (such as ACPI)
    to access and print out slots in static dmi_ident[].
commit 81b4e1f6269cea345f17d3aa349ec9beb31a8cd3
Date:   Wed Jan 16 17:20:37 2008 -0500
    DMI: move dmi_available declaration to linux/dmi.h
commit 53256f59116b541f087eb9423c1578e09a1b4b2f
Author: Carlos Martín <inean@users.sf.net>
Date:   Thu Jan 24 10:34:10 2008 +1000
    drm/i915: add support for E7221 chipset
    E7221 chipset is a server version of the i915.
    Signed-off-by: Dave Airlie <airlied@linux.ie>
commit e914a36ac7158235e3f65f0b33bc001a4193e0b5
Date:   Thu Jan 24 10:34:09 2008 +1000
    agp/intel: add support for E7221 chipset
    The E7221 chipset is a 915 rebadged for the Intel server line.
commit f9c4cfe95451b7f4531d73d2a8a6651cba9760ab
Author: Jeremy Fitzhardinge <jeremy@goop.org>
Date:   Wed Jan 23 16:07:17 2008 -0800
    xen: disable vcpu_info placement for now
    There have been several reports of Xen guest domains locking up when
    using vcpu_info structure placement.  Disable it for now.
    Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com>
commit e2d435ea4084022ab88efa74214accb45b1f9e92
Author: Stuart Swales <stuart.swales@croftnuisk.co.uk>
Date:   Wed Jan 23 20:00:48 2008 +0000
    [SCSI] initio: fix module hangs on loading
    I've verified (on my Initio 9100 with a DAT drive) that the
    2.6.24-rc8-git6 initio module still hangs on loading.
    These fixes (other than the printk) are needed to get the module to load
    ok (and work correctly) with my adapter & tape drive.
    a) printk cosmetic fix
    b) cblk->sglen needs setting for later DMA I/O routines to use
    c) host->bios_addr needs setting for debug output correctness
    d) semaph & semaph_lock initialisation had got lost since 2.6.22
    e) since 2.6.22 the bios data address was truncated to 16 bits (needs 20
    when shifted left)
    Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
commit 8f7b3d156d348b6766833cd4e272d0d19b501e64
Author: Anton Salikhmetov <salikhmetov@gmail.com>
Date:   Wed Jan 23 02:21:18 2008 +0300
    Update ctime and mtime for memory-mapped files
    Update ctime and mtime for memory-mapped files at a write access on
    a present, read-only PTE, as well as at a write on a non-present PTE.
    Signed-off-by: Anton Salikhmetov <salikhmetov@gmail.com>
commit b334349eb4c8562fd60bc8a8bd5ba6b42f22b8ac
Author: Francois Romieu <romieu@fr.zoreil.com>
Date:   Sat Nov 17 21:29:47 2007 +0100
    sis190: scheduling while atomic error
    sis190_tx_timeout
    -> sis190_hw_start
       -> sis190_soft_reset
          -> msleep *splat*
    PCI transactions are correctly flushed here.
    The msleep() is probably useless.
    Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
    Cc: K.M. Liu <kmliu@sis.com.tw>
commit 7bf3f232f7c78efee8c4d14ad9af8a5a40304916
Date:   Sat Nov 17 16:56:43 2007 +0100
    sis190: mdio operation failure is not correctly detected
    i ranges from 0 to 100 in the 'for' loop a few lines above.
    Reported by davem.
commit 11913d30b9fb985b12835037281ae0483be59623
Date:   Sat Nov 17 15:55:10 2007 +0100
    sis190: remove duplicate INIT_WORK
    It is already done in sis190_init_one.
commit ebc71647309539aaf9088f4e41b9f364cce8f7eb
Date:   Tue Dec 4 22:58:41 2007 +0100
    sis190: add cmos ram access code for the SiS19x/968 chipset pair
    More work is needed to handle correctly the PHY of the new devices
    when connected to a 10Mb link but this change already helps some
    users as is.
    Fix for:
    http://bugzilla.kernel.org/show_bug.cgi?id=9467
    Cc: J. Gleacher <jgleacher@yahoo.com>
    Cc: Alexandre Penasso Teixeira <alexandre@keepsoftware.com>
    Cc: Arliton Rocha <arliton@gmail.com>
    Cc: Juan Jose Pablos <juanjo@apertus.es>
    Cc: Wipat Srutiprom <wipat.s@psu.ac.th>
commit f945fa7ad9c12a3356a3de7fb2143ccc2f2c3bca
Author: Herbert Xu <herbert@gondor.apana.org.au>
Date:   Tue Jan 22 22:39:26 2008 -0800
    [INET]: Fix truesize setting in ip_append_data
    As it is ip_append_data only counts page fragments to the skb that
    allocated it.  As such it means that the first skb gets hit with a
    4K charge even though it might have only used a fraction of it while
    all subsequent skb's that use the same page gets away with no charge
    at all.
    This bug was exposed by the UDP accounting patch.
    [ The wmem_alloc bumping needs to be moved with the truesize,
      noticed by Takahiro Yasui.  -DaveM ]
    Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
commit ff4b950277b6534caab2b2b956dba6ce29757551
Author: Denis V. Lunev <den@openvz.org>
Date:   Tue Jan 22 22:05:33 2008 -0800
    [NETNS]: Re-export init_net via EXPORT_SYMBOL.
    init_net is used added as a parameter to a lot of old API calls, f.e.
    ip_dev_find. These calls were exported as EXPORT_SYMBOL. So, export init_net
    as EXPORT_SYMBOL to keep networking API consistent.
    Signed-off-by: Denis V. Lunev <den@openvz.org>
commit a781cf94e6dcc09bf13e548298185d916d9ff3c8
Author: Reinette Chatre <reinette.chatre@intel.com>
Date:   Mon Jan 21 10:08:31 2008 -0800
    iwlwifi: fix possible read attempt on ucode that is not available
    This fixes a NULL pointer dereference that can occur when the
    ucode is not loaded at the time __iwl_up is called.
    The problem was reported at http://kerneloops.org/raw.php?rawid=2765&msgid=
    Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
    Signed-off-by: John W. Linville <linville@tuxdriver.com>
commit 1e34a11d55c9437775367d72ad03f9af99e78bd0
Date:   Tue Jan 22 23:44:31 2008 -0800
    [IPV4]: Add missing skb->truesize increment in ip_append_page().
    And as noted by Takahiro Yasui, we thus need to bump the
    sk->sk_wmem_alloc at this spot as well.
commit 4c93566e2a61b48ef071a8d8a8fa9904c83a668e
Date:   Mon Jan 21 23:20:58 2008 -0800
    [TULIP] DMFE: Fix SROM parsing regression.
    Changeset 16b110c3fd760620b4a787db6ed512fe531ab1b5 (dmfe warning fix)
    bothed up the offsets read from the SROM so that it doesn't read the
    same datums it used to.
    The change made transformations like turning:
            "srom + 34"
    into
            "(__le32 *)srom + 34/4"
    which doesn't work because 4 does not divide evenly
    into 34 so we're using a different pointer offset
    than in the original code.
    I've changed theses cases in dmfe_parse_srom() to
    consistently use "(type *)(srom + offset)" preserving
    the offsets from the original code.
commit acea6852f32b8805e166d885ed7e9f0c7cd10d41
Author: Dave Young <hidave.darkstar@gmail.com>
Date:   Mon Jan 21 22:35:21 2008 -0800
    [BLUETOOTH]: Move children of connection device to NULL before connection down.
    The rfcomm tty device will possibly retain even when conn is down, and
    sysfs doesn't support zombie device moving, so this patch move the tty
    device before conn device is destroyed.
    For the bug refered please see :
    http://lkml.org/lkml/2007/12/28/87
    Signed-off-by: Dave Young <hidave.darkstar@gmail.com>
commit 872e2be7c4056496c2871bd9b0f2fae6c374fe47
Author: Jan Engelhardt <jengelh@computergmbh.de>
Date:   Tue Jan 22 18:29:20 2008 -0800
    [SPARC]: Constify function pointer tables.
    Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
commit 667984d9e481e43a930a478c588dced98cb61fea
Author: Jordan Crouse <jordan.crouse@amd.com>
Date:   Tue Jan 22 23:30:16 2008 +0100
    x86: GEODE fix a race condition in the MFGPT timer tick
    When we set the MFGPT timer tick, there is a chance that we'll
    immediately assert an event.  If for some reason the IRQ routing
    for this clock has been setup for some other purpose, then we
    could end up firing an interrupt into the SMM handler or worse.
    This rearranges the timer tick init function to initalize the handler
    before we set up the MFGPT clock to make sure that even if we get
    an event, it will go to the handler.
    Furthermore, in the handler we need to make sure that we clear the
    event, even if the timer isn't running.
    Signed-off-by: Jordan Crouse <jordan.crouse@amd.com>
    Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
    Acked-by: Ingo Molnar <mingo@elte.hu>
    Tested-by: Arnd Hannemann <hannemann@i4.informatik.rwth-aachen.de>
commit 889c94a14e38e749c8060f597ee7825ea0764229
Author: Johann Felix Soden <johfel@users.sourceforge.net>
Date:   Sun Jan 20 14:41:18 2008 +0100
    Fix file references in documentation and Kconfig
    Fix typo in arch/powerpc/boot/flatdevtree_env.h.
    There is no Documentation/networking/ixgbe.txt.
    README.cycladesZ is now in Documentation/.
    wavelan.p.h is now in drivers/net/wireless/.
    HFS.txt is now Documentation/filesystems/hfs.txt.
    OSS-files are now in sound/oss/.
    Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net>
    Acked-by: Randy Dunlap <randy.dunlap@oracle.com>
commit 00e10776ff908a767b3d36a53d330db8fdc53a56
Author: Randy Dunlap <randy.dunlap@oracle.com>
Date:   Tue Jan 22 03:31:39 2008 -0800
    rcu: fix section mismatch
    rcu_online_cpu() should be __cpuinit instead of __devinit.
    WARNING: vmlinux.o(.text+0x4b6d5): Section mismatch: reference to .init.text: (between 'rcu_cpu_notify' and 'wakeme_after_rcu')
    Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com>
    Cc: Sam Ravnborg <sam@ravnborg.org>
    Cc: Thomas Gleixner <tglx@linutronix.de>
commit 80c002ddd2e732062e4371314d40515d0b5d8415
Author: David Fries <david@fries.net>
    W1: w1_therm.c is flagging 0C etc as invalid
    The extra rom[0] check is flagging valid temperatures as invalid when
    there is already a CRC data transmission check.
    w1_therm_read_bin()
            if (rom[8] == crc && rom[0])
                    verdict = 1;
    Requiring rom[0] to be non-zero will flag as invalid temperature
    conversions when the low byte is zero, specifically the temperatures 0C,
    16C, 32C, 48C, -16C, -32C, and -48C.
    The CRC check is produced on the device for the previous 8 bytes and is
    required to ensure the data integrity in transmission.  I don't see why the
    extra check for rom[0] being non-zero is in there.  Evgeniy Polyakov didn't
    know either.  Just for a check I unplugged the sensor, executed a
    temperature conversion, and read the results.  The read was all ff's, which
    also failed the CRC, so it doesn't need to protect against a disconnected
    sensor.
    I have more extensive patches in the work, but these two trivial ones will
    do for today.  I would like to hear from people who use the ds2490 USB to
    one wire dongle.  1 if you would be willing to test the patches as I
    currently only have the one sensor on a short parisite powered wire, 2 if
    there is any cheap sources for the ds2490.
    Signed-off-by: David Fries <david@fries.net>
    Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
commit 941ed3b53086697eac7449f3ab5d2c5ab3259de2
Date:   Tue Jan 22 03:31:37 2008 -0800
    W1: w1_therm.c ds18b20 decode freezing temperatures correctly
    Correct the decoding of negative C temperatures.  The code did a binary OR
    of two bytes to make a 16 bit value, but assignd it to an integer.  This
    caused the value to not be sign extended and to loose that it was a
    negative number in the assignment.
    Before the patch (in my freezer),
            w1_slave
            ed fe 4b 46 7f ff 03 10 e4 : crc=e4 YES
            ed fe 4b 46 7f ff 03 10 e4 t=4078
    With the patch,
            e3 fe 4b 46 7f ff 0d 10 81 : crc=81 YES
            e3 fe 4b 46 7f ff 0d 10 81 t=-17
commit 87b4b6634ac112ddfe7b92aae50eb4bf7b128d1a
Author: Bjorn Helgaas <bjorn.helgaas@hp.com>
Date:   Tue Jan 22 07:21:03 2008 -0500
    hwmon: (it87) request only Environment Controller ports
    The IT8705F and related parts are Super I/O controllers that contain
    many separate devices.
    Some BIOSes describe IT8705F I/O port usage under a motherboard device
    (PNP0C02) with overlapping regions, e.g., 0x290-0x29f and 0x290-0x294.
    The it87 driver supports only the Environment Controller, which requires
    only two ISA ports, but it used to request an eight-port range.  If that
    range exceeds a range reported by the BIOS, as 0x290-0x297 would, the
    request fails, and the it87 driver cannot claim the device.
    This patch makes the it87 driver request only the two ports used for the
    Environment Controller device.
    Systems where this problem has been reported:
        Gigabyte GA-K8N Ultra 9
        Gigabyte M56S-S3
        Gigabyte GA-965G-DS3
    Kernel bug reports:
        http://bugzilla.kernel.org/show_bug.cgi?id=9514
        http://lkml.org/lkml/2007/12/4/466
    Related change:
        http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=a7839e960675b549f06209d18283d5cee2ce9261
        The patch above increases the number of PNP port resources we support.
        Prior to this patch, we ignored some port resources, which masked the
        it87 problem.
    Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
    Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
commit c61935fd0e7f087a643827b4bf5ef646963c10fa
Author: Ingo Molnar <mingo@elte.hu>
Date:   Tue Jan 22 11:24:58 2008 +0100
    sched: group scheduler, set uid share fix
    setting cpu share to 1 causes hangs, as reported in:
        http://bugzilla.kernel.org/show_bug.cgi?id=9779
    as the default share is 1024, the values of 0 and 1 can indeed
    cause problems. Limit it to 2 or higher values.
    These values can only be set by the root user - but still it
    makes sense to protect against nonsensical values.
commit 4960c9df1407c2723459c60ff13e6efe0c209c62
Author: Thomas Gleixner <tglx@linutronix.de>
Date:   Tue Jan 22 10:23:01 2008 +0100
    Revert "x86: fix NMI watchdog & 'stopped time' problem"
    This reverts commit d4d25deca49ec2527a634557bf5a6cf449f85deb.
    It tried to fix long standing bugzilla entries, but the solution was
    reported to break other systems. The reporter of
    http://bugzilla.kernel.org/show_bug.cgi?id=9791
    tracked it down to this commit and confirmed that reverting the patch
    restores the correct behaviour. It's too late in the release cycle to
    find a better solution than reverting the commit to avoid regressions.
commit 2ad913babd5d597f9d9d71d9e93dd589d55e66cd
Author: Sam Ravnborg <sam@ravnborg.org>
Date:   Mon Jan 21 17:25:37 2008 -0800
    [SPARC64]: Fix section error in sparcspkr
    With a sparc64 defconfig modified to set CONFIG_HOTPLUG=n
    the following error happened during link of vmlinux:
    local symbol 0: discarded in section `.devexit.text' from drivers/built-in.o
    local symbol 1: discarded in section `.devexit.text' from drivers/built-in.o
    (The error message above is from kbuild.git but it happens in mainline too)
    The error happens becase there is a reference from .text/.data to a
    function marked __devexit. With CONFIG_HOTPLUG=n all code marked
    __devexit are discarded and the linker complains.
    It was tracked down to sparcspkr.c which were missing __devexit_p()
    around the function pointers.
    Unfortunately modpost did not catch this since modpost do not warn
    about references from .data to .devexit from variables named *_driver.
    Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
commit a1f35ba374bc421ab33e40163be2b57995b09962
Date:   Mon Jan 21 17:22:46 2008 -0800
    [SPARC64]: Fix of section mismatch warnings.
    Fix following Section mismatch warning in sparc64:
    WARNING: arch/sparc64/kernel/built-in.o(.text+0x13dec): Section mismatch: reference to .devinit.text:pci_scan_one_pbm (between 'psycho_scan_bus' and 'psycho_pbm_init')
    WARNING: arch/sparc64/kernel/built-in.o(.text+0x14b58): Section mismatch: reference to .devinit.text:pci_scan_one_pbm (between 'sabre_scan_bus' and 'sabre_init')
    WARNING: arch/sparc64/kernel/built-in.o(.text+0x15ea4): Section mismatch: reference to .devinit.text:pci_scan_one_pbm (between 'schizo_scan_bus' and 'schizo_pbm_init')
    WARNING: arch/sparc64/kernel/built-in.o(.text+0x17780): Section mismatch: reference to .devinit.text:pci_scan_one_pbm (between 'pci_sun4v_scan_bus' and 'pci_sun4v_get_head')
    WARNING: arch/sparc64/kernel/built-in.o(.text+0x17d5c): Section mismatch: reference to .devinit.text:pci_scan_one_pbm (between 'pci_fire_scan_bus' and 'pci_fire_get_head')
    WARNING: arch/sparc64/kernel/built-in.o(.text+0x23860): Section mismatch: reference to .devinit.text:vio_dev_release (between 'vio_create_one' and 'vio_add')
    WARNING: arch/sparc64/kernel/built-in.o(.text+0x23868): Section mismatch: reference to .devinit.text:vio_dev_release (between 'vio_create_one' and 'vio_add')
    The pci_* were all missing __init annotations.
    For the vio.c case it was a function with a wrong annotation which was removed.
commit d384e35a25445bb60457b7dab8cffe178c6b7ecb
Author: Linus Nilsson <lajnold@acc.umu.se>
Date:   Sun Jan 20 17:10:01 2008 +0100
    Makefile: Change typoed 'behavour' to 'behaviour'
    Change two occurances of "behavour" to "behaviour".
    Signed-off-by: Linus Nilsson <lajnold@acc.umu.se>
commit a6dbb1ef2fc8d73578eacd02ac701f4233175c9f
Author: Andrew G. Morgan <morgan@kernel.org>
Date:   Mon Jan 21 17:18:30 2008 -0800
    Fix filesystem capability support
    In linux-2.6.24-rc1, security/commoncap.c:cap_inh_is_capped() was
    introduced. It has the exact reverse of its intended behavior. This
    led to an unintended privilege esculation involving a process'
    inheritable capability set.
    To be exposed to this bug, you need to have Filesystem Capabilities
    enabled and in use. That is:
    - CONFIG_SECURITY_FILE_CAPABILITIES must be defined for the buggy code
      to be compiled in.
    - You also need to have files on your system marked with fI bits raised.
    Signed-off-by: Andrew G. Morgan <morgan@kernel.org>
    Signed-off-by: Linus Torvalds <torvalds@akpm@linux-foundation.org>
commit a10336043b8193ec603ad54bb79cdcd26bbf94b3
Author: Stefan Schmidt <stefan@openmoko.org>
Date:   Mon Jan 21 17:18:27 2008 -0800
    s3c2410_fb: fix line length calculation
    Fix line length calculation. var->width is the size of the display in mm. We
    like to use the pixel size.
    Without this fix, dynamic (fbset) based resolution and depths changes with
    s3c2410_fb don't work at all.
    Spotted by john cass <johnpcass@yahoo.com>
    Signed-off-by: Stefan Schmidt <stefan@openmoko.org>
    Signed-off-by: Harald Welte <laforge@openmoko.org>
    Acked-by: Ben Dooks <ben-linux@fluff.org>
    Acked-by: Arnaud Patard <arnaud.patard@rtp-net.org>
    Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl>
    Cc: "Antonino A. Daplas" <adaplas@pol.net>
    Cc: Russell King <rmk@arm.linux.org.uk>
commit a56d00bbea018cfa6dc62f76db52760872efa1a7
Author: Cyrill Gorcunov <gorcunov@gmail.com>
Date:   Mon Jan 21 17:18:26 2008 -0800
    CRIS: add missed local_irq_restore call
    Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com>
    Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
    Cc: Mikael Starvik <starvik@axis.com>
commit 48ccf3dac341118992b70ca89c47728e8b1d300b
Date:   Mon Jan 21 17:18:25 2008 -0800
    timer: fix section mismatch
    The caller is __cpuinit.
    Also, this code block and its caller are inside #ifdef CONFIG_HOTPLUG_CPU
    blocks, so this code should reflect that config symbol's usage.
    WARNING: vmlinux.o(.text+0x4252f): Section mismatch: reference to .init.text: (between 'timer_cpu_notify' and 'msleep')
    Cc: Ingo Molnar <mingo@elte.hu>
commit 0ec160dd48b666ddef39d639323d0da26d0b710d
Date:   Mon Jan 21 17:18:24 2008 -0800
    hrtimer: fix section mismatch
    Fix section mismatch in hrtimer.c:
    WARNING: vmlinux.o(.text+0x50c61): Section mismatch: reference to .init.text: (between 'hrtimer_cpu_notify' and 'down_read_trylock')
    Noticed by Johannes Berg and confirmed by Sam Ravnborg.
commit a5569a565f7315fe7241cf963f2cc74e53871e11
Author: Alan Cox <alan@lxorguk.ukuu.org.uk>
    keyspan: fix oops
    If we get a data URB back from the hardware after we have put the tty to
    bed we go kaboom.  Fortunately all we need to do is process the URB without
    trying to ram its contents down the throat of an ex-tty.
    Signed-off-by: Alan Cox <alan@redhat.com>
    Cc: Greg KH <greg@kroah.com>
commit 06675e6f4fb00a63575f4b85da305c3ab19e6e5d
Author: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Date:   Sat Jan 19 01:15:52 2008 +0900
    tc35815: Use irq number for tc35815-mac platform device id
    The tc35815-mac platform device used a pci bus number and a devfn to
    identify its target device, but the pci bus number may vary if some
    bus-bridges are found.  Use irq number which is be unique for embedded
    con
发表于 2008-4-30 17:25:17 | 显示全部楼层
爱死你了
爱死你了,这么好的帖子要顶的
Chongqing news:chongqing,There is wow gold of sale; you can buy really cheap wow gold here.Buy professional power leveling services, wow powerleveling,warcraft gold,World Of Warcraft Power Leveling help !
GMT+8, 2026-11-12 08:48 , Processed in 0.044989 second(s), 18 queries .
