查看: 2258|回复: 0
华为Display interface的显示信息详解
发表于 2008-2-1 05:56:30 | 显示全部楼层 |阅读模式
本次工作希望统一Ethernet接口的信息,建议如下:
[1] GigabitEthernet3/0/1 current state : DOWN
[2] IP Sending Frames Format is PKTFMT_ETHNT_2, Hardware address is 00e0-fc00-0010
[3] The Maximum Transmit Unit is 1500
[4] Media type is not sure, loopback not set
[5] Port hardware type is No Connector
[6] Unknown-speed mode, unknown-duplex mode
[7] Link speed type is autonegotiation, link duplex type is autonegotiation
[8] Flow-control is not supported
[9] The Maximum Frame Length is 1536
[10] Broadcast MAX-ratio: 100%
[11] Allow jumbo frame to pass
[12] PVID: 1
[13] Port link-type: access
[14] Tagged VLAN ID : none
[15] Untagged VLAN ID : 504
[16] Last 5 minutes input rate 229 bytes/sec, 2 packets/sec
Last 5 minutes output rate 25 bytes/sec, 0 packets/sec
[17] Input(total): 34764 packets, 14212713 bytes
1021 broadcasts, 0 multicasts, 0 pauses
[18] Input(normal): 34764 packets, 14212713 bytes
[19] Input(error): 0 input errors, 0 runts, 0 giants, 0 throttles, 0 CRC, 0 frame, 0 overruns,
0 aborts, 0 ignored, 0 parity errors
[20] Output(total): 1630514 packets, 525467915 bytes
774493 broadcasts, 822714 multicasts, 0 pauses
[21] Output(normal): 1630514 packets, 525467915 bytes
[22] Output(error): 0 output errors, 0 underruns, 0 buffer failures, 0 aborts,
0 deferred, 0 collisions, 0 late collisions, 0 lost carrier, 0 no carrier
注意:统计项中不支持的项目填写:-
即:如果产品对deferred,collisions, late collisions, lost carrier, no carrie不支持
显示结果如下:
Output: 0 output errors, 0 underruns, 0 buffer failures, 0 aborts,
- deferred, - collisions, - late collisions, - lost carrier, - no carrier
[1] 接口状态 显示硬件链路的状态
[2] 接口的输出帧封装类型和MAC地址 显示接口的删除帧封装类型和MAC地址
[3] 接口的最大传输单元 显示接口的最大传输单元
[4] 端口的连接线类型和环回状态 显示接口的连接线类型和环回状态
[5] 端口的连接器硬件类型 显示接口的连接器硬件类型
[6] 端口的实际速度和双工状态 显示端口的实际速度和双工状态
[7] 端口是否是速度、双工的自协商配置 显示端口速度、双工的自协商配置
[8] 端口流控状态 显示端口的MDI类型(不是缺省值的情况显示)
[9] 端口可以正常转发的帧长度 显示端口可以正常转发的帧长度
[10] 端口的广播抑制比 显示端口的广播抑制比
[11] 端口是否允许jumbo帧通过 显示端口是否允许jumbo帧通过
[12] 端口的PVID 显示端口的PVID
[13] 端口的链路类型 显示端口的链路类型(access,trunk,hybrid)
[14] 端口所属的tag的VLAN的列表 显示端口所属的tag的VLAN的列表
[15] 端口所属的untag的VLAN的列表 显示端口所属的untag的VLAN的列表
[16] 接口最近五分钟输出和输入速率和报文数 实现最近五分钟输出和输入速率和报文数
[17] 接口的物理层输入总值统计 显示物理层输出的报文数/字节数/广播和多播/PAUSE帧
总的统计值只包括正常、异常包和PAUSE帧
[18] 接口的物理层输入中正常帧的统计 显示物理层输出的报文数/字节数/广播和多播/PAUSE帧
正常帧的统计值包括正常数据帧和正常PAUSE帧
[19] 接口的物理层输入错误统计 输入错误数,input errors等于各种重要错误信息的总和。不同的产品可以根据具体情况增加其它参数,或减少不能实现的参数。
(1) Runts: discarded packets that are smaller than the mediums minimum packet size.
( Receive Byte Count < 64 and NOT CRC Error
or Receive Byte Count < 64 and Tag Packet and NOT CRC Error,
无论是否有vlan tag,数据段小于64字节,而且没有CRC校验错误的帧。)
(2) Giants: discarded packets that are larger than the mediums maximum packet size.
( Receive Byte Count > 1518 and NOT CRC Error
or Receive Byte Count > 1522 and Tag Packet and NOT CRC Error,
没有vlan tag,数据段大于1518字节,小于最大帧长度,而且没有CRC校验错误的帧,和有vlan tag,数据段大于1522字节,小于最大帧长度,而且没有CRC校验错误的帧。)
(3) Throttles: discarded packets that are incomplete frames.
( 交换机察觉缓存或CPU过载,关闭接口接收器的情形称为 throttle,是cisco路由器上的一个概念,我们的交换机目前不具备这个功能,一般应该显示为不支持。)
(4) CRC: discarded packets with checksum error.
( Receive Packet CRC error,帧长度在正常范围(不带tag,长度在64到1518之间,或带tag,长度在64到1522之间),而且CRC校验错,如果支持此项,则不支持奇偶校验错误项。)
(5) Frame: discarded packets with frame pad/sequence/alignment error, out of frame etc.
( 不是整数字节,而是多1~7bit,因此不对齐,或乱序或空帧,而且CRC校验错误,但是不计入CRC错误。)
(6) Overrun: the receiver hardware is unable to hand received data to a hardware buffer because the input rate exceeds the receivers ability to handle the data.
( 由于接口输入速率超过接受方处理能力,导致丢包,由于我们的交换机一般是线速转发,这项一般应该为0,只有部分交换机对上传CPU或三层线速转发的帧有接口带宽限制,或是通过ACL实现的带宽限制,因此被丢弃的帧,计入此项。)
(7) Aborts: Input abnormal frames that are discarded.
( 除其他错误之外,产品认为有必要统计的错误,例如前导码异常的帧,计入此项。)
(8) Ignored: packets that are discarded because the interface hardware does not have enough internal buffers.
( Packet ignored,由于接口内部buffer满,丢弃的帧,与由于主系统缓存空间缺乏,导致的丢弃帧不同。线速转发的帧,在多接口满带宽输入,单接口输出等情况下,由于输出接口的带宽不足,数据帧将内部缓存占满,导致从接口输入的帧在进入内部缓存之前被丢弃,以及进入内部缓存的帧超时无法输出,计入此项,上传到CPU的帧,由于CPU处理能力限制,toCPU的缓存满,导致被丢弃,也计入此项。)
(9) Parity: Frames with parity error.
( Receive Packet parity error,如果支持此项,则不支持 CRC 错误项。)
[20] 接口的物理层输出总值统计 显示物理层输入的报文数/字节数/广播和多播/PAUSE帧
总的统计值只包括正常帧、异常帧和PAUSE帧。
Pauses: Flow control pauses including Xon and Xoff.
[21] 接口的物理层输出正常帧统计 显示物理层输入的报文数/字节数/广播和多播/PAUSE帧
总的统计值只包括正常数据帧和正常PAUSE帧。
[22] 接口的物理层输出错误统计 输入丢弃数/输入错误数,output errors等于各种重要错误信息的总和。不同的产品可以根据具体情况增加其它参数,或减少不能实现的参数。
(1) Underruns: There are no data in the output queue.
( Transmit under run,与 Overrun相反,输出接口的缓存从输出队列中取以太网帧时,没有帧,是一种非常少见的硬件异常。有的交换机就没有单独的接口输出缓存,与接口输出队列是同一块缓存。)
(2) Buffer failures: Hardware does not have enough internal buffers.
( 内部缓存满,如果输出队列满,输出的以太网帧将在内部缓存中暂时存储,由于内部缓存满,导致帧丢弃。由于交换机对线速转发的数据帧发生的这种异常,认为只是到达内部缓存而没有到达出接口,是个输入帧,因此计入 Input Ignored Error,只有从CPU发出的帧,由于内部缓存满,导致帧丢弃,计入此项。)
(3) Aborts: Output abnormal frames that are discarded.
( 在半双工模式下,由于冲突检测,延迟发送超过15次的帧,被丢弃,计入此项。除其他错误之外,产品认为有必要统计的错误,例如添加前导码异常的帧,也计入此项)
(4) Deferred: The packets could not be sent out for collision under half-duplex mode.
( 半双工模式下,由于检测到载波正在被声明,当时没有发出的包,延时一次,计数加一。)
(5) Collisions: Statistic of collision detection under half-duplex mode.
( 半双工模式下,在以太网帧数据部分的前64字节进入线路前,由于检测到冲突,当时没有发出的包。)
(6) Late collisions: Statistic of collision with GE port sending packets less than 512 bytes and 10/100M port less than 64 bytes.
( 半双工模式下,在以太网帧数据部分的前64字节进入线路后,由于检测到冲突,当时没有发出的包。)
(7) Lost carrier: Statistic of losing the carrier.
( 载波丢失,一般适用于串行WAN接口,发送过程中,每丢失一个载波,此计数加一,对于交换机,通常是由于线路中断造成。)
(8) No carrier: Statistic of no carrier.
( 无载波,一般适用于串行WAN接口,当试图发送帧时,如果没有载波出现 ,此计数加一,对于交换机,通常是由于线路中断造成。)
GMT+8, 2026-11-12 12:04 , Processed in 0.031159 second(s), 18 queries .
