查看: 1817|回复: 0
ASA SSL VPN成功配置
发表于 2008-1-30 19:33:52 | 显示全部楼层 |阅读模式
ASA SSL VPN成功配置
下面是ASA SSL VPN的配置案例!
interface Ethernet0/0
nameif outside
security-level 0
ip address 198.1.1.1 255.255.255.0
interface Ethernet0/1
nameif inside
security-level 100
ip address 172.30.1.97 255.255.255.0
ip local pool ssl-user 192.168.12.1-192.168.12.254
access-list go-vpn extended permit ip 172.30.1.0 255.255.255.0 192.168.12.0 255.255.255.0
global (outside) 1 interface
nat (inside) 0 access-list go-vpn
nat (inside) 1 172.30.1.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 198.1.1.2 1
username wanglinlin password kc0imQBKBLfYhNFb encrypted
group-policy mysslvpn-group-policy internal
group-policy mysslvpn-group-policy attributes
vpn-tunnel-protocol webvpn
webvpn
  svc enable
tunnel-group mysslvpn-group type webvpn
tunnel-group mysslvpn-group general-attributes
address-pool ssl-user
default-group-policy mysslvpn-group-policy
tunnel-group mysslvpn-group webvpn-attributes
group-alias mysslvpn enable
webvpn
enable outside
svc image disk0:/sslclient-win-1.1.1.164.pkg 1
svc enable
tunnel-group-list enable
GMT+8, 2026-11-12 12:04 , Processed in 0.028180 second(s), 18 queries .
