查看: 2346|回复: 1
Cisco.com已放出ASA5580 Datasheet
发表于 2008-1-22 06:26:43 | 显示全部楼层 |阅读模式
Cisco ASA 5580-20
Cisco ASA 5580-40
Users/Nodes
Unlimited
Unlimited
Firewall Throughput
Up to 5 Gbps (Real-world), 6.5 Gbps (1400 byte), 10 Gbps (Jumbo frame)
Up to 10 Gbps (Real-world), 14 Gbps (1400 byte), 20 Gbps (Jumbo frame)
3DES/AES VPN Throughput
1 Gbps
1 Gbps
IPsec VPN Peers
10,000
10,000
SSL VPN Peers*
2/10,000
2/10,000
Concurrent Sessions
1,000,000
2,000,000
New Sessions/Second
90,000
150,000
Packets/Second (64 byte)
2,500,000
4,000,000
Integrated Network Ports
2 Gigabit Ethernet management
Interface Expansion Cards
• 4 Port 10/100/1000, RJ45
• 4 Port Gigabit Ethernet fiber, SR, LC
• 2 Port 10Gigabit Ethernet fiber, SR, LC
Virtual Interfaces
100 (250**)
100 (250**)
Security Contexts*
2/50
2/50
High Availability
Active/Active and Active/Standby
Redundant Power
Supported, second power supply optional
Interface Expansion
6 interface expansion card slots
USB 2.0 Ports
Serial Ports
1 RJ-45, console
1 RJ-45, console
Rack-Mountable
Yes, rails included
Yes, rails included
Technical Specifications
Memory
8 GB
12 GB
Minimum system flash
1 GB
1 GB
System bus
Multibus architecture
Environmental Operating Ranges
Operating temperature
50 to 95°F (10 to 35°C)
Relative humidity
10 to 90 percent noncondensing
Altitude
Designed and tested for: 0 to 10,000 ft (3050 m). Agency Approved for: 2000 m
Noise
55 dBa max
Nonoperating
Temperature
-22 to 140°F (-30 to 60°C)
Relative humidity
5 to 95 percent noncondensing
Altitude
0 to 30,000 ft (9144 m)
Power
Input (per power supply)
Range line voltage
100 to 240 VAC
Normal line voltage
100 to 240 VAC
Current
12A
Frequency
50/60 Hz
Output
Steady state
800W
Maximum peak
800W
Maximum heat dissipation
4070 BTU/hr
Physical Specifications
Form factor
4 RU, 19-in. rack-mountable
Dimensions (h x w x d)
6.94 x 19 x 26.5 in. (17.6 x 48.3 x 67.3 cm)
Weight (with single power supply)
66 lb (29.9 kg)
Regulatory and Standards
Safety
UL 60950, CSA C22.2 No. 60950, EN 60950 IEC 60950, AS/NZS60950
Electromagnetic compatibility (EMC)
CE marking, FCC Part 15 Class A, AS/NZS CISPR22 Class A, VCCI Class A, EN55022 Class A, CISPR22 Class A, EN61000-3-2, EN61000-3-3
详见http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/product_data_sheet0900aecd802930c5.html
 楼主| 发表于 2008-2-1 08:00:17 | 显示全部楼层
Cisco Pushes Firewall and VPN Performance to New Heights With New Adaptive Security Appliances
Tuesday January 22, 8:00 am ET
Top-of-the-Line Cisco ASA 5580 Series Delivers Data Center-Class Performance With Firewall and SSL/IPSec VPN Capabilities in a Single Platform SAN JOSE, CA--(MARKET WIRE)--Jan 22, 2008 -- To address enterprises' insatiable appetite for high performance and scalable network security, Cisco® (NasdaqGS:CSCO - News) today announced the availability of the Cisco ASA 5580 Series Adaptive Security Appliances, the company's highest-performing security appliance offering. The new Cisco ASA 5580 is a super-high-performance security platform equally well suited for deployment as a highly scalable firewall with up to 20 gigabits per second (Gbps) of throughput, as well as a 10,000 user remote-access concentrator for Secure Sockets Layer (SSL) and IP Security (IPsec)-based virtual private networks (VPN).
GMT+8, 2026-11-12 12:04 , Processed in 0.041640 second(s), 18 queries .
