查看: 2704|回复: 1
ASA5500系列密码恢复
发表于 2008-1-20 07:23:13 | 显示全部楼层 |阅读模式
ASA5500系列密码恢复
在ASA启动过程中按 CTRL+BREAK键后,进入:
rommon #0> confreg
Current Configuration Register: 0x00000001
Configuration Summary:
boot default image from Flash
Do you wish to change this configuration? y/n [n]: n
rommon #1> confreg 0x41
Update Config Register (0x41) in NVRAM...
rommon #2> boot
Launching BootLoader...
Boot configuration file contains 1 entry.
Loading disk0:/ASA_7.0.bin... Booting...
Ignoring startup configuration as instructed by configuration register.
hostname> enable
Password:
hostname# configure terminal
hostname(config)# copy startup-config running-config
Destination filename [running-config]?
Cryptochecksum(unchanged): 7708b94c e0e3f0d5 c94dde05 594fbee9
892 bytes copied in 6.300 secs (148 bytes/sec)
hostname(config)# enable password NewPassword
hostname(config)# config-register 0x1
hostname#copy run start
到次为止密码恢复完成.
发表于 2008-1-21 15:14:11 | 显示全部楼层
比PIX的密码恢复简单,PIX密码恢复还要去官方下载一个软件到PIX里。
ASA的密码恢复跟路由器差不多了。
GMT+8, 2026-11-12 12:04 , Processed in 0.045560 second(s), 18 queries .
