查看: 1977|回复: 0
一个华为设备防病毒 ACL 配置
发表于 2008-1-9 14:02:27 | 显示全部楼层 |阅读模式
一个华为设备防病毒 ACL 配置
创建acl
acl number 100
禁ping
rule  deny icmp source any destination any
用于控制Blaster蠕虫的传播
rule  deny udp source any destination any destination-port eq 69
rule  deny tcp source any destination any destination-port eq 4444
用于控制冲击波病毒的扫描和攻击
rule  deny tcp source any destination any destination-port eq 135
rule  deny udp source any destination any destination-port eq 135
rule  deny udp source any destination any destination-port eq netbios-ns
rule  deny udp source any destination any destination-port eq netbios-dgm
rule  deny tcp source any destination any destination-port eq 139
rule  deny udp source any destination any destination-port eq 139
rule  deny tcp source any destination any destination-port eq 445
rule  deny udp source any destination any destination-port eq 445
rule  deny udp source any destination any destination-port eq 593
rule  deny tcp source any destination any destination-port eq 593
用于控制振荡波的扫描和攻击
rule  deny tcp source any destination any destination-port eq 5554
rule  deny tcp source any destination any destination-port eq 9995
rule  deny tcp source any destination any destination-port eq 9996
用于控制 Worm_MSBlast.A 蠕虫的传播
rule  deny udp source any destination any destination-port eq 1434
下面的不出名的病毒端口号  (可以不作)
rule  deny tcp source any destination any destination-port eq 1068
rule  deny tcp source any destination any destination-port eq 5800
rule  deny tcp source any destination any destination-port eq 5900
rule  deny tcp source any destination any destination-port eq 10080
rule  deny tcp source any destination any destination-port eq 455
rule  deny udp source any destination any destination-port eq 455
rule  deny tcp source any destination any destination-port eq 3208
rule  deny tcp source any destination any destination-port eq 1871
rule  deny tcp source any destination any destination-port eq 4510
rule  deny udp source any destination any destination-port eq 4334
rule  deny tcp source any destination any destination-port eq 4331
rule  deny tcp source any destination any destination-port eq 4557
然后下发配置
packet-filter ip-group 100
目的:针对目前网上出现的问题,对目的是端口号为1434的UDP报文进行过滤的配置方法,详细和复杂的配置请看配置手册。
NE80的配置:
NE80(config)#rule-map r1 udp any any eq 1434
//r1为role-map的名字,udp 为关键字,any any 所有源、目的IP,eq为等于,1434为udp端口号
NE80(config)#acl a1 r1 deny
//a1为acl的名字,r1为要绑定的rule-map的名字,
NE80(config-if-Ethernet1/0/0)#access-group acl a1
//在1/0/0接口上绑定acl,acl为关键字,a1为acl的名字
NE16的配置:
NE16-4(config)#firewall enable all
//首先启动防火墙
NE16-4(config)#access-list 101 deny udp any any eq 1434
//deny为禁止的关键字,针对udp报文,any any 为所有源、目的IP,eq为等于, 1434为udp端口号
NE16-4(config-if-Ethernet2/2/0)#ip access-group 101 in
//在接口上启用access-list,in表示进来的报文,也可以用out表示出去的报文
中低端路由器的配置
[Router]firewall enable
[Router]acl 101
[Router-acl-101]rule deny udp source any destion any destination-port eq 1434
[Router-Ethernet0]firewall packet-filter 101 inbound
6506产品的配置:
旧命令行配置如下:
6506(config)#acl extended aaa deny protocol udp any any eq 1434
6506(config-if-Ethernet5/0/1)#access-group  aaa
国际化新命令行配置如下:
[Quidway]acl number 100
[Quidway-acl-adv-100]rule deny udp source any destination any destination-port eq 1434
[Quidway-acl-adv-100]quit
[Quidway]interface ethernet  5/0/1
[Quidway-Ethernet5/0/1]packet-filter inbound ip-group 100 not-care-for-interface
5516产品的配置:
旧命令行配置如下:
5516(config)#rule-map  l3 aaa protocol-type udp ingress any egress any eq 1434
5516(config)#flow-action fff deny
5516(config)#acl bbb aaa fff
5516(config)#access-group  bbb
国际化新命令行配置如下:
[Quidway]acl num 100
[Quidway]packet-filter ip-group 100
3526产品的配置:
旧命令行配置如下:
rule-map l3 r1 0.0.0.0 0.0.0.0 1.1.0.0 255.255.0.0 eq 1434
flow-action f1 deny
acl acl1 r1 f1
access-group acl1
国际化新命令配置如下:
acl number 100
rule 0 deny udp source 0.0.0.0 0 source-port eq 1434 destination 1.1.0.0 0
packet-filter ip-group 101 rule 0
注:3526产品只能配置外网对内网的过滤规则,其中1.1.0.0 255.255.0.0是内网的地址段。
8016产品的配置:
旧命令行配置如下:
8016(config)#rule-map intervlan aaa udp  any  any   eq 1434
8016(config)#acl bbb aaa deny
8016(config)#access-group acl bbb vlan 10 port all
国际化新命令行配置如下:
8016(config)#eacl bbb aaa deny
8016(config)#access-group eacl bbb vlan 10 port all
GMT+8, 2026-11-12 12:04 , Processed in 0.029866 second(s), 18 queries .
