查看: 3370|回复: 3
新版华为2403交换机的配置方法
发表于 2008-1-9 13:55:49 | 显示全部楼层 |阅读模式
在[Quidway]下粘贴以下文本就行了。
vlan 1576
interface Ethernet0/1
port access vlan 1576
quit
vlan 1577
interface Ethernet0/2
port access vlan 1577
quit
vlan 1578
interface Ethernet0/3
port access vlan 1578
quit
vlan 1579
interface Ethernet0/4
port access vlan 1579
quit
vlan 1580
interface Ethernet0/5
port access vlan 1580
quit
vlan 1581
interface Ethernet0/6
port access vlan 1581
quit
vlan 1582
interface Ethernet0/7
port access vlan 1582
quit
vlan 1583
interface Ethernet0/8
port access vlan 1583
quit
vlan 1584
interface Ethernet0/9
port access vlan 1584
vlan 1585
interface Ethernet0/10
port access vlan 1585
quit
vlan 1586
interface Ethernet0/11
port access vlan 1586
quit
vlan 1587
interface Ethernet0/12
port access vlan 1587
quit
vlan 1588
interface Ethernet0/13
port access vlan 1588
quit
vlan 1589
interface Ethernet0/14
port access vlan 1589
quit
vlan 1590
interface Ethernet0/15
port access vlan 1590
quit
vlan 1591
interface Ethernet0/16
port access vlan 1591
quit
vlan 1592
interface Ethernet0/17
port access vlan 1592
quit
vlan 1593
interface Ethernet0/18
port access vlan 1593
quit
vlan 1594
interface Ethernet0/19
port access vlan 1594
quit
vlan 1595
interface Ethernet0/20
port access vlan 1595
quit
vlan 1596
interface Ethernet0/21
port access vlan 1596
quit
vlan 1597
interface Ethernet0/22
port access vlan 1597
quit
vlan 1598
interface Ethernet0/23
port access vlan 1598
quit
vlan 1599
interface Ethernet0/24
port access vlan 1599
quit
#########有光口的配置方法#########
<Quidway>sys
[Quidway]interface Etherner1/1
[Quidway-Ethernet1/1]port link-type trunk
[Quidway-Ethernet1/1]port trunk permit vlan all
[Quidway-Ethernet1/1]quit
[Quidway]quit
<Quidway>save
存盘后就可以了。
#########没有光口的配置方法########
<Quidway>sys
[Quidway]interface Etherner0/25
[Quidway]quit
<Quidway>save
存盘后就可以了。
[Quidway]undo vlan 333   册除端口
[Quidway]display interface eth 1/1  察看端口的状态
<Quidway>reboot    重启交换机
 楼主| 发表于 2008-1-9 13:56:18 | 显示全部楼层
如果满配24百兆端口和背后一个光模块端口的话,将下列文件在2403的控制台上的config模式下粘贴到主机
如果不是满配作相应调整
有光口的话粘贴完****后的文本再粘贴
interface ethernet 1/1
switchport mode trunk
switchport trunk native vlan 4000
switchport trunk allowed vlan all
exit
没有光口的话上行插在25口的话 粘贴完****后的文本再粘贴
in eth 0/25
exit
Quidway(config)#vlan enable
vlan 1384
switchport ethernet 0/1
exit
vlan 1385
switchport ethernet 0/2
exit
vlan 1386
switchport ethernet 0/3
exit
vlan 1387
switchport ethernet 0/4
exit
vlan 1388
switchport ethernet 0/5
exit
vlan 1389
switchport ethernet 0/6
exit
vlan 1390
switchport ethernet 0/7
exit
vlan 1391
switchport ethernet 0/8
exit
vlan 1392
switchport ethernet 0/9
exit
vlan 1393
switchport ethernet 0/10
exit
vlan 1394
switchport ethernet 0/11
exit
vlan 1395
switchport ethernet 0/12
exit
vlan 1396
switchport ethernet 0/13
exit
vlan 1397
switchport ethernet 0/14
exit
vlan 1398
switchport ethernet 0/15
exit
vlan 1399
switchport ethernet 0/16
exit
vlan 1400
switchport ethernet 0/17
exit
vlan 1401
switchport ethernet 0/18
exit
vlan 1409
switchport ethernet 0/19
exit
vlan 1410
switchport ethernet 0/20
exit
vlan 1411
switchport ethernet 0/21
exit
vlan 1412
switchport ethernet 0/22
exit
vlan 1413
switchport ethernet 0/23
exit
vlan 1414
switchport ethernet 0/24
exit
 楼主| 发表于 2008-1-9 13:56:47 | 显示全部楼层
端口line-rate inboand/out
报文速率限制级别取值为1~127。如果速率限制级别取值在1~28范围内,则速率限制的粒度为64Kbps,这种情况下,当设置的级别为N,则端口上限制的速率大小为N*64K;如果速率限制级别取值在29~127范围内,则速率限制的粒度为1Mbps,这种情况下,当设置的级别为N,则端口上限制的速率大小为(N-27)*1Mbps。
 楼主| 发表于 2008-1-9 13:57:10 | 显示全部楼层
SSH第1章  命令行接口
1.1  命令行接口
Quidway系列以太网交换机向用户提供一系列配置命令以及命令行接口,方便用户配置和管理以太网交换机。命令行接口有如下特性:
l              通过Console口进行本地配置。
l              通过以太网端口利用Telnet或SSH进行本地或远程登录配置。
l              配置命令分级保护,确保未授权用户无法侵入以太网交换机。
l              用户可以随时键入以获得在线帮助。
l              提供网络测试命令,如Tracert、Ping等,迅速诊断网络是否正常。
l              提供种类丰富、内容详尽的调试信息,帮助诊断网络故障。
l              用Telnet命令直接登录并管理其它以太网交换机。
l              提供FTP服务,方便用户上载、下载文件。
l              提供类似Doskey的功能,可以执行某条历史命令。
l              命令行解释器对关键字采取不完全匹配的搜索方法,用户只需键入无冲突关键字即可解释。
1.2  命令行视图
Quidway系列以太网交换机的命令行采用分级保护方式,防止未授权用户的非法侵入。
命令行划分为参观级、监控级、配置级、管理级4个级别,简介如下:
l              参观级:该级别包含的命令有网络诊断工具命令(ping、tracert)、用户界面的语言模式切换命令(language-mode)以及telnet命令等,该级别命令不允许进行配置文件保存的操作。
l              监控级:用于系统维护、业务故障诊断等,包括display、debugging命令,该级别命令不允许进行配置文件保存的操作。
l              配置级:业务配置命令,包括路由、各个网络层次的命令,这些用于向用户提供直接网络服务。
l              管理级:关系到系统基本运行,系统支撑模块的命令,这些命令对业务提供支撑作用,包括文件系统、FTP、TFTP、XModem下载、用户管理命令、级别设置命令等。
同时对登录用户也划分为4个级别,分别与命令级别相对应,即不同级别的用户登录后,只能使用等于或低于自己级别的命令。
为了防止未授权用户的非法侵入,用户在使用super [ level ]命令从低级别切换到高级别时,要进行用户身份验证,即需要输入切换口令(如果用户已经使用命令super password [ level level ] { simple | cipher } password设置了切换口令)。为了保密,用户在屏幕上看不到所键入的口令,如果三次以内输入正确的口令,则切换到高级别用户,否则保持原用户级别不变。
各命令行视图是针对不同的配置要求实现的,它们之间有联系又有区别,比如,与以太网交换机建立连接即进入用户视图,它只完成查看运行状态和统计信息的简单功能,再键入system-view进入系统视图,在系统视图下,可以键入不同的命令进入相应的视图。
命令行提供如下视图:
l              用户视图
l              系统视图
l              以太网端口视图
l              VLAN视图
l              VLAN接口视图
l              本地用户视图
l              用户界面视图
l              FTP Client视图
l              集群视图
l              公共密钥视图
l              公共密钥编辑视图
l              基本ACL视图
l              RADIUS服务器组视图
l              ISP域视图
各命令视图的功能特性、进入各视图的命令等细则如表3-1所示。
表1-1 命令视图功能特性列表
视图
功能
提示符
进入命令
退出命令
用户视图
查看交换机的简单运行状态和统计信息
与交换机建立连接即进入
quit断开与交换机连接
系统视图
配置系统参数
[Quidway]
在用户视图下键入system-view
quit或return返回用户视图
以太网端口视图
配置以太网端口参数
[Quidway-Ethernet0/1]
百兆以太网端口视图
在系统视图下键入:interface ethernet 0/1
quit返回系统视图
VLAN视图
配置VLAN参数
[Quidway-Vlan1]
在系统视图下键入vlan 1
quit返回系统视图
VLAN接口视图
配置VLAN和VLAN汇聚对应的IP接口参数
[Quidway-Vlan-interface1]
在系统视图下键入:interface vlan-interface 1
quit返回系统视图
本地用户视图
配置本地用户参数
[Quidway-luser-user1]
在系统视图下键入:local-user user1
quit返回系统视图
用户界面视图
配置用户界面参数
[Quidway-ui0]
在系统视图下键入user-interface 0
quit返回系统视图
FTP Client视图
配置FTP Client参数
[ftp]
在用户视图下键入ftp
quit返回用户视图
集群视图
配置集群参数
[Quidway-cluster]
在系统视图下键入cluster
quit返回系统视图
公共密钥视图
配置SSH用户的RSA公共密钥
[Quidway-rsa-public-key]
在系统视图下键入rsa peer-public-key quidway003
quit返回系统视图
公共密钥编辑视图
编辑SSH用户的RSA公共密钥
[Quidway-rsa-key-code]
在公共密钥视图下键入public-key-code begin
quit返回系统视图
基本ACL视图
定义基本ACL的子规则
[Quidway-acl- basic-2000]
在系统视图下键入acl number 2000
quit返回系统视图
RADIUS服务器组视图
配置Radius协议参数
[Quidway-radius-1]
在系统视图下键入radius scheme 1
quit返回系统视图
ISP域视图
配置ISP域的相关属性
[Quidway-isp-huawei163.net]
在系统视图下键入domain huawei163.net
quit返回系统视图
1.3  命令行特性
1.3.1  命令行在线帮助
命令行接口提供如下几种在线帮助:
l              完全帮助
l              部分帮助
通过上述各种在线帮助能够获取到帮助信息,分别描述如下:
(1)        在任一视图下,键入获取该视图下所有的命令及其简单描述。
User view commands:
  language-mode Specify the language environment
  ping          Ping function
  quit          Exit from current command view
  super         Privilege specified user priority level
  telnet        Establish one TELNET connection
  tracert       Trace route function
(2)        键入一命令,后接以空格分隔的,如果该位置为关键字,则列出全部关键字及其简单描述。
language-mode ?
  chinese  Chinese environment
  english  English environment
(3)        键入一命令,后接以空格分隔的,如果该位置为参数,则列出有关的参数描述。
[Quidway] garp timer leaveall ?
  INTEGER  Value of timer in centiseconds
                     (LeaveAllTime > (LeaveTime [On all ports]))
                     Time must be multiple of 5 centiseconds
[Quidway] garp timer leaveall 300 ?
表示该位置无参数,在紧接着的下一个命令行该命令被复述,直接键入回车即可执行。
(4)        键入一字符串,其后紧接,列出以该字符串开头的所有命令。
p?
ping
(5)        键入一命令,后接一字符串紧接,列出命令以该字符串开头的所有关键字。
display ver?
  version
(6)        键入命令的某个关键字的前几个字母,按下键,如果以输入字母开头的关键字唯一,则可以显示出完整的关键字。
(7)        以上帮助信息,均可通过执行language-mode命令切换为中文显示。
1.3.2  命令行显示特性
命令行接口提供了如下的显示特性:
l              为方便用户,提示信息和帮助信息可以用中英文两种语言显示。
l              在一次显示信息超过一屏时,提供了暂停功能,这时用户可以有三种选择,如表3-2所示。
表1-2 显示功能表
按键或命令
功能
暂停显示时键入
停止显示和命令执行
暂停显示时键入空格键
继续显示下一屏信息
暂停显示时键入回车键
继续显示下一行信息
1.3.3  命令行历史命令
命令行接口提供类似Doskey功能,将用户键入的历史命令自动保存,用户可以随时调用命令行接口保存的历史命令,并重复执行。命令行接口为每个用户缺省保存10条历史命令。操作如表3-3所示。
表1-3 访问历史命令
操作
按键
结果
显示历史命令
display history-command
显示用户输入的历史命令
访问上一条历史命令
上光标键↑或
如果还有更早的历史命令,则取出上一条历史命令
访问下一条历史命令
下光标键↓或
如果还有更晚的历史命令,则取出下一条历史命令
&  说明:
用光标键对历史命令进行访问,在Windows 3.X的Terminal和Telnet下都是有效的,但对于Windows 9X超级终端,↑、↓光标键会无效,这是由于Windows 9X的超级终端对这两个键作了不同解释所致,这时可以用组合键Ctrl+P>和来代替↑、↓光标键达到同样目的。
1.3.4  命令行错误信息
所有用户键入的命令,如果通过语法检查,则正确执行,否则向用户报告错误信息,常见错误信息参见表3-4。
表1-4 命令行常见错误信息表
英文错误信息
错误原因
Unrecognized command
没有查找到命令
没有查找到关键字
参数类型错
参数值越界
Incomplete command
输入命令不完整
Too many parameters
输入参数太多
Ambiguous command
输入参数不明确
1.3.5  命令行编辑特性
命令行接口提供了基本的命令编辑功能,支持多行编辑,每条命令的最大长度为256个字符,如表3-5所示。
GMT+8, 2026-11-12 12:03 , Processed in 0.041276 second(s), 18 queries .
