查看: 2746|回复: 6
2403H-EI pvlan功能实现典型案例
发表于 2008-1-6 16:15:00 | 显示全部楼层 |阅读模式
网描述:
PC-------------------2403H-EI---------------SECPATH100N----------------------ADSL猫----------------INTERNET
功能实现:
2403H-EI下挂的1到24口的PC实现两两隔离,都通过25口上行上公网.
2403H-EI 配置
[Quidway]qu
<Quidway>dir
Directory of flash:/
-rwxrwxrwx   1 noone    nogroup   2737939  Apr 02 2000 00:17:58   2403.app
-rwxrwxrwx   1 noone    nogroup         8  Apr 01 2000 23:55:18   snmpboots
-rwxrwxrwx   1 noone    nogroup      3674  Apr 02 2000 00:33:05   vrpcfg.txt
-rwxrwxrwx   1 noone    nogroup    445224  Apr 02 2000 00:01:14   wnm2.2.2-0003.zip   用于WEB网管,若不能WEB网管,检查此目录下是否有此文件.
3381248 bytes total (190464 bytes free)
<Quidway>dis ver
Huawei Versatile Routing Platform Software
VRP (R) Software, Version 3.10, RELEASE 0017
Copyright (c) 2000-2004 HUAWEI TECH CO., LTD.
uptime is 0 week,0 day,0 hour,58 minutes
32M    bytes SDRAM
4096K   bytes Flash Memory
Config Register points to FLASH
Hardware Version is VER.D
Bootrom Version is 109
[Subslot 0] 25 FE        Hardware Version is VER.D
<Quidway>dis cu
sysname Quidway
radius scheme system
server-type huawei
primary authentication 127.0.0.1 1645
primary accounting 127.0.0.1 1646
user-name-format without-domain
domain system
radius-scheme system
Access-limit disable
state active
vlan-assignment-mode integer
idle-cut disable
self-service-url disable
messenger time disable
domain default enable system
local-server nas-ip 127.0.0.1 key huawei
local-user telnet                         交换机的telnet和web网管时的用户名和密码
 楼主| 发表于 2008-1-6 16:15:12 | 显示全部楼层
passWord simple telnet
service-type telnet level 3
vlan range 1-511
queue-scheduler wrr 1 2 4 8
vlan 1
vlan 2
vlan 3
vlan 4
vlan 5
vlan 6
vlan 7
vlan 8
vlan 9
vlan 10
vlan 11
vlan 12
vlan 13
vlan 14
vlan 15
vlan 16
vlan 17
vlan 18
vlan 19
vlan 20
vlan 21
vlan 22
vlan 23
vlan 24
vlan 100
vlan 500
interface Vlan-interface1
ip address 192.168.1.100 255.255.255.0               交换机的管理地址
interface Aux0/0
interface Ethernet0/1
port link-type hybrid
port hybrid vlan 1 100 untagged
interface Ethernet0/2
port hybrid vlan 2 100 untagged
port hybrid pvid vlan 2
interface Ethernet0/3
port hybrid vlan 3 100 untagged
port hybrid pvid vlan 3
interface Ethernet0/4
port hybrid vlan 4 100 untagged
port hybrid pvid vlan 4
interface Ethernet0/5
port hybrid vlan 5 100 untagged
port hybrid pvid vlan 5
interface Ethernet0/6
port hybrid vlan 6 100 untagged
port hybrid pvid vlan 6
interface Ethernet0/7
port hybrid vlan 7 100 untagged
port hybrid pvid vlan 7
interface Ethernet0/8
port hybrid vlan 8 100 untagged
port hybrid pvid vlan 8
interface Ethernet0/9
port hybrid vlan 9 100 untagged
port hybrid pvid vlan 9
interface Ethernet0/10
port hybrid vlan 10 100 untagged
 楼主| 发表于 2008-1-6 16:15:28 | 显示全部楼层
port hybrid pvid vlan 10
interface Ethernet0/11
port hybrid vlan 11 100 untagged
port hybrid pvid vlan 11
interface Ethernet0/12
port hybrid vlan 12 100 untagged
port hybrid pvid vlan 12
interface Ethernet0/13
port hybrid vlan 13 100 untagged
port hybrid pvid vlan 13
interface Ethernet0/14
port hybrid vlan 14 100 untagged
port hybrid pvid vlan 14
interface Ethernet0/15
port hybrid vlan 15 100 untagged
port hybrid pvid vlan 15
interface Ethernet0/16
port hybrid vlan 16 100 untagged
port hybrid pvid vlan 16
interface Ethernet0/17
port hybrid vlan 17 100 untagged
port hybrid pvid vlan 17
interface Ethernet0/18
port hybrid vlan 18 100 untagged
port hybrid pvid vlan 18
interface Ethernet0/19
port hybrid vlan 19 100 untagged
port hybrid pvid vlan 19
interface Ethernet0/20
port hybrid vlan 20 100 untagged
port hybrid pvid vlan 20
interface Ethernet0/21
port hybrid vlan 21 100 untagged
port hybrid pvid vlan 21
interface Ethernet0/22
port hybrid vlan 22 100 untagged
port hybrid pvid vlan 22
interface Ethernet0/23
port hybrid vlan 23 100 untagged
port hybrid pvid vlan 23
interface Ethernet0/24
port hybrid vlan 24 100 untagged
port hybrid pvid vlan 24
interface Ethernet0/25                         此端口用于上行,其它端口接PC,实现端口的两两隔离
port hybrid vlan 1 to 24 100 untagged
port hybrid pvid vlan 100
 楼主| 发表于 2008-1-6 16:15:46 | 显示全部楼层
interface NULL0
user-interface aux 0
user-interface vty 0 4
authentication-mode scheme
return
<Quidway>
QQRead.com 推出数据恢复指南教程 数据恢复指南教程 数据恢复故障解析 常用数据恢复方案 硬盘数据恢复教程 数据保护方法 数据恢复软件 专业数据恢复服务指南
secpath100N配置
dis ver
Copyright Notice:
All rights reserved (Mar 23 2005).
Without the owner's prior written consent, no decompiling
nor reverse-engineering shall be allowed.
Huawei-3Com Versatile Routing Platform Software
VRP(R) software, Version 3.30, Release 0004
Copyright (c) 2000-2004 Huawei Tech. Co.,Ltd. All rights reserved.
Quidway SecPath 100N uptime is 0 week, 0 day, 0 hour, 13 minutes
  Router type: SecPath 100N
  CPU type: Mips IDT RC32438 266MHz
  128M bytes DDR SDRAM Memory
  8M bytes Flash Memory
  Pcb      Version:3.0
  Logic    Version:1.0
  BootROM  Version:1.01
  [SLOT 0] 2FE      (Hardware)1.0, (Driver)1.0, (Cpld)1.0
[Quidway]dis cu
sysname Quidway
local-user telnet
local-user telnet service-type telnet
local-user telnet level 3
dialer-rule 1 ip permit
interface Aux0
async mode flow
link-protocol ppp
interface Dialer1
link-protocol ppp
ppp pap local-user 123 password simple 123
mtu 1450
tcp mss 1024
ip address ppp-negotiate
dialer user quidway
dialer-group 1
dialer bundle 1
nat outbound 2000
interface Ethernet0/0
pppoe-client dial-bundle-number 1
tcp mss 1024
ip address 192.168.1.254 255.255.255.0
firewall packet-filter 3000 inbound
interface NULL0
acl number 2000
rule 0 permit source 192.168.1.0 0.0.0.255
rule 1 deny
acl number 3000
rule 0 deny tcp destination-port eq 135
rule 1 deny udp destination-port eq 135
rule 2 deny udp destination-port eq netbios-ns
rule 3 deny udp destination-port eq netbios-dgm
 楼主| 发表于 2008-1-6 16:15:59 | 显示全部楼层
rule 4 deny tcp destination-port eq 139
rule 5 deny tcp destination-port eq 445
rule 6 deny tcp destination-port eq 539
rule 7 deny udp destination-port eq 593
rule 8 deny tcp destination-port eq 593
rule 9 deny udp destination-port eq 1434
rule 10 deny tcp destination-port eq 9996
rule 11 deny tcp destination-port eq 5554
rule 12 deny udp destination-port eq 9996
rule 13 deny udp destination-port eq 5554
rule 14 deny tcp destination-port eq 137
rule 15 deny udp destination-port eq 1025
rule 16 deny tcp destination-port eq 9995
rule 17 deny udp destination-port eq 9995
rule 18 deny udp destination-port eq 1068
rule 19 deny udp destination-port eq 1023
rule 20 deny udp destination-port eq tFTP
rule 21 deny udp destination-port eq netbios-ssn
rule 22 deny udp destination-port eq 445
rule 23 deny udp destination-port eq 539
rule 24 deny tcp destination-port eq 4444
rule 25 deny tcp destination-port eq 138
rule 26 deny tcp destination-port eq 1025
rule 27 deny tcp destination-port eq 1068
rule 28 deny tcp destination-port eq 1023
ip route-static 0.0.0.0 0.0.0.0 Dialer 1 preference 60
user-interface con 0
authentication-mode local
return
[Quidway]
 楼主| 发表于 2008-1-6 16:17:24 | 显示全部楼层
全线速的二层交换: 9.6Gbps的总线带宽为交换机所有的端口提供二层线速交换能力,保证所有端口无阻塞的进行报文转发。 完备的安全智能控制策略: S2000-EI系列交换机支持802.1x认证,还可以做认证Server,在用户接入网络时完成必要的身份认证,同时动态的配置VLAN,有效的控制用户访问网络资源。 该系列具备端口限速功能,可以64Kbps的精细粒度进行端口带宽分配,控制用户的接入速率,防止恶意侵占网络带宽。 交换机提供512个802.1Q VLAN,支持MAC地址和端口绑定、广播风暴抑制和端口锁定功能,还可以对属于同一个802.1Q VLAN的端口之间设置隔离或互通。 高可靠性: S2000-EI交换机不仅支持STP/RSTP生成树协议,还可以提供基于多VLAN的生成树MSTP,极大提高了链路的冗余备份,提高容错能力,保证网络的稳定运行。 低功耗静音设计: S2000-EI交换机具备低功耗和工作环境温度适应强的特点,采用无风扇设计,彻底免除噪音,还具有免机械风扇维护和更好的防尘效果。 灵活的扩展能力和远程维护: S2016-EI/S2403H-EI提供百兆光/电扩展能力,允许交换机通过光纤或铜缆上联网络。 通过FTP、TFTP实现设备的远程升级,支持HGMP集群管理系统和故障诊断,实现了设备的集中管理和维护。 丰富的管理方式: S2000-EI交换机支持SNMP V1/V2/V3,可以接受Open View等通用网管平台以及Quidview&reg;、iManager&reg; 网管系统配置和管理。支持CLI命令行,Web网管,TELNET,HGMP集群管理等多种方式,便于设备维护。
 楼主| 发表于 2008-1-6 16:19:14 | 显示全部楼层
组网描述:
功能实现:
2403H-EI下挂的1到24口的PC实现两两隔离,都通过25口上行上公网.PAN>
2403H-EI 配置
[Quidway]qu
<Quidway>dir
<Quidway>dis ver
32M    bytes SDRAM
<Quidway>dis cu
sysname Quidway
server-type huawei
domain system
access-limit disable
state active
idle-cut disable
password simple telnet
vlan range 1-511
vlan 1
vlan 2
vlan 3
vlan 4
vlan 5
vlan 6
vlan 7
vlan 8
vlan 9
vlan 10
vlan 11
vlan 12
vlan 13
vlan 14
vlan 15
vlan 16
vlan 17
vlan 18
vlan 19
vlan 20
vlan 21
vlan 22
vlan 23
vlan 24
vlan 100
vlan 500
interface Aux0/0
interface NULL0
return
<Quidway>
secpath100N配置
dis ver
Copyright Notice:
  Pcb      Version:3.0
  Logic    Version:1.0
[Quidway]dis cu
sysname Quidway
local-user telnet
interface Aux0
async mode flow
link-protocol ppp
interface Dialer1
link-protocol ppp
mtu 1450
tcp mss 1024
dialer user quidway
dialer-group 1
dialer bundle 1
nat outbound 2000
tcp mss 1024
interface NULL0
acl number 2000
rule 1 deny
acl number 3000
rule 20 deny udp destination-port eq tftp
return
[Quidway]
GMT+8, 2026-11-12 11:54 , Processed in 0.035959 second(s), 18 queries .
