查看: 10726|回复: 5
智能DNS服务器配置详解
发表于 2007-12-28 20:03:39 | 显示全部楼层 |阅读模式
智能DNS服务器配置详解
注:对于配置智能DNS,主要用途为:1、解决网通与电信问题 2、实现区域规划(不同区域访问各自最近的服务器),下面以解决网通与电信连接问题的配置。至于实现2的功能,只需稍加更改即可。
一、DNS服务器安装......................................................................................... 1
二、named.conf的配置....................................................................................... 2
三、更新根区文件:.......................................................................................... 3
四、建立启动脚本:.......................................................................................... 4
五、添加一个NS............................................................................................... 5
六、添加一个域名.............................................................................................. 5
附:获取IP地址范围方法:................................................................................. 7
一、DNS服务器安装
1、 软件列表
BIND 9.3.2
ftp://ftp.isc.org/isc/bind9/9.3.2/bind-9.3.2.tar.gz
2、 安装BIND 9
安装BIND9:
# tar zxvf bind-9.3.2.tar.gz
# cd bind-9.3.2
# ./configure
--prefix=/usr/local/named
--disable-ipv6
# make && make install
建立BIND用户:
# groupadd bind
# useradd -g bind -d /usr/local/named -s /sbin/nologin bind
创建配置文件目录:
# mkdir –p /usr/local/named/etc
# chown bind:bind /usr/local/named/etc
# chmod 700 /usr/local/named/etc
二、named.conf的配置
创建主要的配置文件:
# vi /usr/local/named/etc/named.conf
===========================named.conf=======================
acl "trust-lan" { 127.0.0.1/8; 192.168.0.0/16;};
options {
directory "/usr/local/named/etc/";
pid-file "/var/run/named/named.pid";
version "0.0.0";
datasize 40M;
allow-transfer {
"trust-lan";};
recursion yes;
allow-notify {
"trust-lan";
allow-recursion {
"trust-lan";
auth-nxdomain no;
forwarders {
202.99.160.68;
202.99.168.8;};
logging {
channel warning
{ file "/var/log/named/dns_warnings" versions 3 size 1240k;
severity warning;
print-category yes;
print-severity yes;
print-time yes;
channel general_dns
{ file "/var/log/named/dns_logs" versions 3 size 1240k;
severity info;
print-category yes;
print-severity yes;
print-time yes;
category default { warning; };
category queries { general_dns; };
zone "." {
type hint;
file "named.root";
acl "CNC" {
58.16.0.0/16;
58.17.0.0/17;
58.17.128.0/17;
58.18.0.0/16;
58.19.0.0/16;
58.20.0.0/16;
58.21.0.0/16;
注:这些根据情况输入IP地址段
view "view_cnc" {
match-clients { CNC; };
zone "." {
type hint;
file "named.root";
zone "0.0.127.IN-ADDR.ARPA" {
type master;
file "localhost.rev";
include "master/cnc.def";
view "view_any" {
match-clients { any; };
zone "." {
type hint;
file "named.root";
type master;
include "master/telecom.def";
添加完成后,保存。
三、更新根区文件:
# cd /usr/local/named/etc/
# wget ftp://ftp.internic.org/domain/named.root
创建PID和日志文件:
# mkdir /var/run/named/
# chmod 777 /var/run/named/
# chown bind:bind /var/run/named/
# mkdir /var/log/named/
# touch /var/log/named/dns_warnings
# touch /var/log/named/dns_logs
# chown bind:bind /var/log/named/*
# mkdir master
# touch master/cnc.def
# touch master/telecom.def
生成rndc-key:
# ../sbin/rndc-confgen > rndc.conf
把rndc.conf中:
# Use with the following in named.conf, adjusting the allow list as needed:
后面以的部分加到/usr/local/named/etc/named.conf中并去掉注释
运行测试:
# /usr/local/named/sbin/named -gc /usr/local/named/etc/named.conf &
状态检查:
# /usr/local/named/sbin/rndc status
四、建立启动脚本:
# vi /etc/init.d/named
============================== named.sh============================
#!/bin/bash
# named
a network name service.
# chkconfig: 545 35 75
# description: a name server
if [ `id -u` -ne 0 ]
then
echo "ERROR:For bind to port 53,must run as root."
exit 1
fi
case "$1" in
start)
if [ -x /usr/local/named/sbin/named ]; then
/usr/local/named/sbin/named -u bind -c /usr/local/named/etc/named.conf && echo . && echo 'BIND9 server started.'
fi
stop)
kill `cat /var/run/named/pid` && echo . && echo 'BIND9 server stopped.'
restart)
echo .
echo "Restart BIND9 server"
$0 stop
sleep 10
$0 start
echo "$0 start | stop | restart"
esac
===============================named.sh============================
# chmod 755 /etc/init.d/named
# chown root:root /etc/init.d/named
# chkconfig --add named
# chkconfig named on
五、添加一个NS
       在域名的管理网站上,设定NS服务器为你安装的DNS
六、添加一个域名
# cd /usr/local/named/etc/master
# mkdir cnc
# mkdir telecom
# vi cnc.def
添加
zone "daoyou.com" {
type master;
file "master/cnc/daoyou.com";
# vi telecom.def
添加
zone "daoyou.com" {
type master;
file "master/telecom/daoyou.com";
添加网通的解析,解析到的IP为61.45.55.78
#vi cnc/daoyou.com
添加
$TTL 3600
$ORIGIN daoyou.com.
@ IN SOA ns.daoyou.com. root.ns.daoyou.com.(
2005121013 ;Serial
3600 ; Refresh ( seconds )
900 ; Retry ( seconds )
68400 ; Expire ( seconds )
15 );Minimum TTL for Zone ( seconds )
@ IN NS ns.daoyou.com.
@ IN A 61.45.55.78
www IN A 61.45.55.78
;end
添加电信的解析,解析到的IP为210.75.1.178
#vi telecom/daoyou.com
添加
$TTL 3600
$ORIGIN daoyou.com.
2005121013 ;Serial
@ IN A 210.75.1.178
www IN A 210.75.1.178
;end
#/usr/local/named/sbin/rndc reload
OK,到此你的DNS服务器就算是跑起来了。试一下分别用网通和电信的线路ping一下吧.
附:获取IP地址范围方法: 1、
利用shell程序获取IP地址段
#!/bin/sh
FILE=/root/study/apnic/ip_apnic
rm -f $FILE
wget http://ftp.apnic.net/apnic/stats/apnic/delegated-apnic-latest -O $FILE
grep 'apnic|CN|ipv4|' $FILE | cut -f 4,5 -d'|'|sed -e 's/|/ /g' | while read ip cnt
do
echo $ipcnt
mask=$(cat << EOF | bc | tail -1
pow=32;
define log2(x) {
if (x<=1) return (pow);
pow--;
return(log2(x/2));
log2($cnt)
EOF)
echo $ip/$mask>> cn.net
NETNAME=`whois $ip@whois.apnic.net | sed -e '/./{H;$!d;}' -e 'x;/netnum/!d' |grep ^netname | sed -e 's/.*:
\(.*\)/\1/g' | sed -e 's/-.*//g'`
case $NETNAME in
CNC)
echo $ip/$mask >> CNCGROUP
CHINANET|CNCGROUP)
echo $ip/$mask >> $NETNAME
CHINANET|CNCGROUP)
CHINATELECOM)
echo $ip/$mask >> CHINANET
echo $ip/$mask >> OTHER
esac
done
2、
可以利用网上的资料,下面是最新的信息,然后利awk行成地址段即可。
wget http://218.66.103.230/vpn_route/cnc.new 新的网通路由表
wget http://218.66.103.230/vpn_route/chinanet.new 新的电信路由表
 楼主| 发表于 2007-12-30 08:06:23 | 显示全部楼层
网通
add 203.212.0.0 mask 255.255.240.0 default metric default if default
add 61.180.128.0 mask 255.255.128.0 default metric default if default
add 211.154.192.0 mask 255.255.192.0 default metric default if default
add 203.175.192.0 mask 255.255.192.0 default metric default if default
add 61.232.0.0 mask 255.248.0.0 default metric default if default
add 222.163.128.0 mask 255.255.128.0 default metric default if default
add 222.163.64.0 mask 255.255.192.0 default metric default if default
add 222.163.32.0 mask 255.255.224.0 default metric default if default
add 222.163.0.0 mask 255.255.224.0 default metric default if default
add 222.162.0.0 mask 255.255.0.0 default metric default if default
add 221.213.0.0 mask 255.255.0.0 default metric default if default
add 221.207.0.0 mask 255.255.0.0 default metric default if default
add 221.206.0.0 mask 255.255.0.0 default metric default if default
add 221.204.0.0 mask 255.254.0.0 default metric default if default
add 221.199.64.0 mask 255.255.192.0 default metric default if default
add 221.199.48.0 mask 255.255.240.0 default metric default if default
add 221.195.0.0 mask 255.255.0.0 default metric default if default
add 221.194.0.0 mask 255.255.0.0 default metric default if default
add 221.13.128.0 mask 255.255.128.0 default metric default if default
add 221.13.96.0 mask 255.255.224.0 default metric default if default
add 221.13.64.0 mask 255.255.224.0 default metric default if default
add 221.7.128.0 mask 255.255.128.0 default metric default if default
add 221.7.96.0 mask 255.255.224.0 default metric default if default
add 221.7.64.0 mask 255.255.224.0 default metric default if default
add 221.7.32.0 mask 255.255.224.0 default metric default if default
add 221.5.0.0 mask 255.255.128.0 default metric default if default
add 221.3.128.0 mask 255.255.128.0 default metric default if default
add 221.3.0.0 mask 255.255.128.0 default metric default if default
add 221.2.0.0 mask 255.255.0.0 default metric default if default
add 218.106.0.0 mask 255.254.0.0 default metric default if default
add 218.105.0.0 mask 255.255.0.0 default metric default if default
add 218.27.0.0 mask 255.255.0.0 default metric default if default
add 218.26.0.0 mask 255.255.0.0 default metric default if default
add 218.10.0.0 mask 255.255.0.0 default metric default if default
add 210.82.0.0 mask 255.254.0.0 default metric default if default
add 210.53.128.0 mask 255.255.128.0 default metric default if default
add 210.53.0.0 mask 255.255.128.0 default metric default if default
add 210.52.128.0 mask 255.255.128.0 default metric default if default
add 210.51.0.0 mask 255.255.0.0 default metric default if default
add 210.21.0.0 mask 255.255.0.0 default metric default if default
add 210.15.96.0 mask 255.255.224.0 default metric default if default
add 210.15.32.0 mask 255.255.224.0 default metric default if default
add 210.13.128.0 mask 255.255.128.0 default metric default if default
add 203.93.192.0 mask 255.255.192.0 default metric default if default
add 202.102.232.0 mask 255.255.248.0 default metric default if default
add 202.99.240.0 mask 255.255.240.0 default metric default if default
add 202.99.232.0 mask 255.255.248.0 default metric default if default
add 202.99.224.0 mask 255.255.248.0 default metric default if default
add 202.99.208.0 mask 255.255.240.0 default metric default if default
add 202.99.176.0 mask 255.255.240.0 default metric default if default
add 202.99.168.0 mask 255.255.248.0 default metric default if default
add 202.99.160.0 mask 255.255.248.0 default metric default if default
add 202.99.96.0 mask 255.255.248.0 default metric default if default
add 202.98.8.0 mask 255.255.248.0 default metric default if default
add 202.97.240.0 mask 255.255.240.0 default metric default if default
add 202.97.224.0 mask 255.255.248.0 default metric default if default
add 202.96.72.0 mask 255.255.248.0 default metric default if default
add 125.40.0.0 mask 255.248.0.0 default metric default if default
add 125.36.0.0 mask 255.252.0.0 default metric default if default
add 125.35.128.0 mask 255.255.128.0 default metric default if default
add 125.35.0.0 mask 255.255.128.0 default metric default if default
add 125.34.0.0 mask 255.255.0.0 default metric default if default
add 125.33.0.0 mask 255.255.0.0 default metric default if default
add 125.32.0.0 mask 255.255.0.0 default metric default if default
add 124.92.0.0 mask 255.252.0.0 default metric default if default
add 124.89.0.0 mask 255.255.128.0 default metric default if default
add 124.88.0.0 mask 255.255.0.0 default metric default if default
add 124.64.0.0 mask 255.254.0.0 default metric default if default
add 61.163.0.0 mask 255.255.0.0 default metric default if default
add 61.158.128.0 mask 255.255.128.0 default metric default if default
add 61.138.64.0 mask 255.255.192.0 default metric default if default
add 61.136.64.0 mask 255.255.192.0 default metric default if default
add 61.134.192.0 mask 255.255.192.0 default metric default if default
add 61.55.0.0 mask 255.255.0.0 default metric default if default
add 61.54.0.0 mask 255.255.0.0 default metric default if default
add 60.218.0.0 mask 255.254.0.0 default metric default if default
add 60.31.0.0 mask 255.255.0.0 default metric default if default
add 60.30.0.0 mask 255.255.0.0 default metric default if default
add 60.24.0.0 mask 255.248.0.0 default metric default if default
add 60.11.0.0 mask 255.255.0.0 default metric default if default
add 60.10.0.0 mask 255.255.0.0 default metric default if default
add 58.248.0.0 mask 255.248.0.0 default metric default if default
add 58.246.0.0 mask 255.254.0.0 default metric default if default
add 58.244.0.0 mask 255.254.0.0 default metric default if default
add 58.242.0.0 mask 255.254.0.0 default metric default if default
add 58.240.0.0 mask 255.254.0.0 default metric default if default
add 58.21.0.0 mask 255.255.0.0 default metric default if default
add 58.20.0.0 mask 255.255.0.0 default metric default if default
add 58.19.0.0 mask 255.255.0.0 default metric default if default
add 58.18.0.0 mask 255.255.0.0 default metric default if default
add 58.17.128.0 mask 255.255.128.0 default metric default if default
add 58.17.0.0 mask 255.255.128.0 default metric default if default
add 222.136.0.0 mask 255.248.0.0 default metric default if default
add 202.130.224.0 mask 255.255.224.0 default metric default if default
add 221.5.128.0 mask 255.255.128.0 default metric default if default
add 211.153.0.0 mask 255.255.0.0 default metric default if default
add 222.153.0.0 mask 255.255.128.0 default metric default if default
add 60.220.0.0 mask 255.252.0.0 default metric default if default
add 222.132.0.0 mask 255.252.0.0 default metric default if default
add 61.52.0.0 mask 255.254.0.0 default metric default if default
add 61.189.0.0 mask 255.255.128.0 default metric default if default
add 61.182.0.0 mask 255.255.0.0 default metric default if default
add 61.181.0.0 mask 255.255.0.0 default metric default if default
add 61.179.0.0 mask 255.255.0.0 default metric default if default
add 61.176.0.0 mask 255.255.0.0 default metric default if default
add 61.168.0.0 mask 255.255.0.0 default metric default if default
add 61.167.0.0 mask 255.255.0.0 default metric default if default
add 61.162.0.0 mask 255.255.0.0 default metric default if default
add 61.161.128.0 mask 255.255.128.0 default metric default if default
add 61.161.0.0 mask 255.255.192.0 default metric default if default
add 61.159.0.0 mask 255.255.192.0 default metric default if default
add 61.156.0.0 mask 255.255.0.0 default metric default if default
add 61.148.0.0 mask 255.254.0.0 default metric default if default
add 61.139.128.0 mask 255.255.192.0 default metric default if default
add 61.138.128.0 mask 255.255.192.0 default metric default if default
add 61.138.0.0 mask 255.255.192.0 default metric default if default
add 61.137.128.0 mask 255.255.128.0 default metric default if default
add 61.135.0.0 mask 255.255.0.0 default metric default if default
add 61.134.96.0 mask 255.255.224.0 default metric default if default
add 61.134.128.0 mask 255.255.192.0 default metric default if default
add 61.133.0.0 mask 255.255.128.0 default metric default if default
add 60.8.0.0 mask 255.254.0.0 default metric default if default
add 60.16.0.0 mask 255.248.0.0 default metric default if default
add 60.14.0.0 mask 255.254.0.0 default metric default if default
add 60.13.128.0 mask 255.255.128.0 default metric default if default
add 60.13.0.0 mask 255.255.192.0 default metric default if default
add 60.12.0.0 mask 255.255.0.0 default metric default if default
add 58.22.0.0 mask 255.254.0.0 default metric default if default
add 58.16.0.0 mask 255.255.0.0 default metric default if default
add 222.160.0.0 mask 255.252.0.0 default metric default if default
add 222.128.0.0 mask 255.252.0.0 default metric default if default
add 221.8.0.0 mask 255.254.0.0 default metric default if default
add 221.7.0.0 mask 255.255.224.0 default metric default if default
add 221.6.0.0 mask 255.255.0.0 default metric default if default
add 221.4.0.0 mask 255.255.0.0 default metric default if default
add 221.216.0.0 mask 255.248.0.0 default metric default if default
add 221.200.0.0 mask 255.252.0.0 default metric default if default
add 221.199.192.0 mask 255.255.240.0 default metric default if default
add 221.199.128.0 mask 255.255.192.0 default metric default if default
add 221.199.0.0 mask 255.255.128.0 default metric default if default
add 221.198.0.0 mask 255.255.0.0 default metric default if default
add 221.196.0.0 mask 255.254.0.0 default metric default if default
add 221.192.0.0 mask 255.252.0.0 default metric default if default
add 221.13.0.0 mask 255.255.192.0 default metric default if default
add 221.12.128.0 mask 255.255.192.0 default metric default if default
add 221.12.0.0 mask 255.255.128.0 default metric default if default
add 221.11.0.0 mask 255.255.0.0 default metric default if default
add 221.10.0.0 mask 255.255.0.0 default metric default if default
add 221.0.0.0 mask 255.254.0.0 default metric default if default
add 220.248.0.0 mask 255.252.0.0 default metric default if default
add 219.245.64.0 mask 255.255.192.0 default metric default if default
add 219.159.0.0 mask 255.255.192.0 default metric default if default
add 219.158.128.0 mask 255.255.128.0 default metric default if default
add 219.158.0.0 mask 255.255.240.0 default metric default if default
add 219.156.0.0 mask 255.254.0.0 default metric default if default
add 219.154.0.0 mask 255.254.0.0 default metric default if default
add 218.8.0.0 mask 255.254.0.0 default metric default if default
add 218.7.0.0 mask 255.255.0.0 default metric default if default
add 218.68.0.0 mask 255.254.0.0 default metric default if default
add 218.67.128.0 mask 255.255.128.0 default metric default if default
add 218.60.0.0 mask 255.254.0.0 default metric default if default
add 218.56.0.0 mask 255.252.0.0 default metric default if default
add 218.24.0.0 mask 255.254.0.0 default metric default if default
add 218.21.128.0 mask 255.255.128.0 default metric default if default
add 218.12.0.0 mask 255.255.0.0 default metric default if default
add 218.104.0.0 mask 255.248.0.0 default metric default if default
add 211.148.192.0 mask 255.255.224.0 default metric default if default
add 210.74.96.0 mask 255.255.224.0 default metric default if default
add 210.74.128.0 mask 255.255.224.0 default metric default if default
add 210.15.128.0 mask 255.255.192.0 default metric default if default
add 210.15.0.0 mask 255.255.128.0 default metric default if default
add 210.14.192.0 mask 255.255.192.0 default metric default if default
add 202.99.64.0 mask 255.255.192.0 default metric default if default
add 202.99.128.0 mask 255.255.192.0 default metric default if default
add 202.98.0.0 mask 255.255.224.0 default metric default if default
add 202.97.192.0 mask 255.255.192.0 default metric default if default
add 202.97.128.0 mask 255.255.224.0 default metric default if default
add 202.96.64.0 mask 255.255.224.0 default metric default if default
add 202.96.0.0 mask 255.255.192.0 default metric default if default
add 202.111.128.0 mask 255.255.224.0 default metric default if default
add 202.110.0.0 mask 255.255.192.0 default metric default if default
add 202.108.0.0 mask 255.255.0.0 default metric default if default
add 202.107.0.0 mask 255.255.128.0 default metric default if default
add 202.106.0.0 mask 255.255.0.0 default metric default if default
add 202.102.224.0 mask 255.255.224.0 default metric default if default
add 202.102.128.0 mask 255.255.192.0 default metric default if default
add 218.28.0.0 mask 255.254.0.0 default metric default if default
add 221.214.0.0 mask 255.254.0.0 default metric default if default
add 60.28.32.0 mask 255.255.255.128 default metric default if default
add 61.136.62.0 mask 255.255.254.0 default metric default if default
add 61.48.0.0 mask 255.252.0.0 default metric default if default
add 221.7.196.0 mask 255.255.254.0 default metric default if default
add 60.0.0.0 mask 255.240.0.0 default metric default if default
add 218.11.0.0 mask 255.255.0.0 default metric default if default
add 210.22.0.0 mask 255.255.0.0 default metric default if default
add 58.100.0.0 mask 255.254.0.0 default metric default if default
add 219.82.0.0 mask 255.255.0.0 default metric default if default
add 218.97.235.0 mask 255.255.255.0 default metric default if default
add 218.97.236.0 mask 255.255.252.0 default metric default if default
add 221.136.0.0 mask 255.255.0.0 default metric default if default
add 124.90.0.0 mask 255.254.0.0 default metric default if default
add 211.160.0.0 mask 255.255.0.0 default metric default if default
add 218.244.32.0 mask 255.255.224.0 default metric default if default
add 124.128.0.0 mask 255.248.0.0 default metric default if default
add 218.98.0.0 mask 255.255.0.0 default metric default if default
add 202.165.208.0 mask 255.255.240.0 default metric default if default
add 60.63.0.0 mask 255.255.0.0 default metric default if default
add 222.248.0.0 mask 255.255.0.0 default metric default if default
add 125.208.0.0 mask 255.255.224.0 default metric default if default
add 202.110.119.0 mask 255.255.255.0 default metric default if default
add 124.161.0.0 mask 255.255.0.0 default metric default if default
add 124.164.0.0 mask 255.252.0.0 default metric default if default
add 121.30.0.0 mask 255.255.0.0 default metric default if default
add 124.163.0.0 mask 255.255.0.0 default metric default if default
add 222.125.0.0 mask 255.255.0.0 default metric default if default
add 218.62.0.0 mask 255.255.128.0 default metric default if default
add 221.14.0.0 mask 255.254.0.0 default metric default if default
add 211.162.95.0 mask 255.255.255.128 default metric default if default
add 121.24.0.0 mask 255.252.0.0 default metric default if default
add 61.136.0.0 mask 255.255.192.0 default metric default if default
add 221.208.0.0 mask 255.248.0.0 default metric default if default
add 60.208.0.0 mask 255.240.0.0 default metric default if default
add 202.97.160.0 mask 255.255.224.0 default metric default if default
add 124.160.0.0 mask 255.255.0.0 default metric default if default
add 121.16.0.0 mask 255.248.0.0 default metric default if default
add 220.252.0.0 mask 255.255.0.0 default metric default if default
add 202.99.22.0 mask 255.255.255.0 default metric default if default
add 202.38.164.0 mask 255.255.252.0 default metric default if default
add 121.31.0.0 mask 255.255.0.0 default metric default if default
add 211.158.0.0 mask 255.255.0.0 default metric default if default
add 122.96.0.0 mask 255.254.0.0 default metric default if default
REMOVE_GATEWAY
 楼主| 发表于 2007-12-30 08:06:50 | 显示全部楼层
电信
add 58.32.0.0 mask 255.248.0.0 default metric default if default
add 58.40.0.0 mask 255.254.0.0 default metric default if default
add 58.42.0.0 mask 255.255.0.0 default metric default if default
add 58.43.0.0 mask 255.255.0.0 default metric default if default
add 58.44.0.0 mask 255.252.0.0 default metric default if default
add 58.48.0.0 mask 255.248.0.0 default metric default if default
add 58.56.0.0 mask 255.254.0.0 default metric default if default
add 58.58.0.0 mask 255.255.0.0 default metric default if default
add 58.59.0.0 mask 255.255.128.0 default metric default if default
add 58.59.128.0 mask 255.255.128.0 default metric default if default
add 58.60.0.0 mask 255.252.0.0 default metric default if default
add 59.32.0.0 mask 255.245.0.0 default metric default if default
add 59.40.0.0 mask 255.254.0.0 default metric default if default
add 59.42.0.0 mask 255.255.0.0 default metric default if default
add 59.44.0.0 mask 255.252.0.0 default metric default if default
add 59.48.0.0 mask 255.255.0.0 default metric default if default
add 59.49.0.0 mask 255.255.128.0 default metric default if default
add 59.49.128.0 mask 255.255.128.0 default metric default if default
add 59.50.0.0 mask 255.255.0.0 default metric default if default
add 59.51.0.0 mask 255.255.128.0 default metric default if default
add 59.51.128.0 mask 255.255.128.0 default metric default if default
add 59.52.0.0 mask 255.252.0.0 default metric default if default
add 59.56.0.0 mask 255.248.0.0 default metric default if default
add 59.60.0.0 mask 255.254.0.0 default metric default if default
add 59.62.0.0 mask 255.254.0.0 default metric default if default
add 60.160.0.0 mask 255.254.0.0 default metric default if default
add 60.162.0.0 mask 255.254.0.0 default metric default if default
add 60.164.0.0 mask 255.254.0.0 default metric default if default
add 60.166.0.0 mask 255.254.0.0 default metric default if default
add 60.168.0.0 mask 255.248.0.0 default metric default if default
add 61.133.128.0 mask 255.255.128.0 default metric default if default
add 61.134.0.0 mask 255.255.192.0 default metric default if default
add 61.134.64.0 mask 255.255.224.0 default metric default if default
add 61.136.128.0 mask 255.255.128.0 default metric default if default
add 61.137.0.0 mask 255.255.128.0 default metric default if default
add 61.138.192.0 mask 255.255.192.0 default metric default if default
add 61.139.0.0 mask 255.255.128.0 default metric default if default
add 61.139.192.0 mask 255.255.192.0 default metric default if default
add 61.140.0.0 mask 255.252.0.0 default metric default if default
add 61.144.0.0 mask 255.252.0.0 default metric default if default
add 61.152.0.0 mask 255.252.0.0 default metric default if default
add 61.157.0.0 mask 255.255.0.0 default metric default if default
add 61.159.64.0 mask 255.255.192.0 default metric default if default
add 61.159.128.0 mask 255.255.128.0 default metric default if default
add 61.160.0.0 mask 255.255.0.0 default metric default if default
add 61.161.64.0 mask 255.255.192.0 default metric default if default
add 61.164.0.0 mask 255.254.0.0 default metric default if default
add 61.166.0.0 mask 255.255.0.0 default metric default if default
add 61.169.0.0 mask 255.255.0.0 default metric default if default
add 61.170.0.0 mask 255.254.0.0 default metric default if default
add 61.172.0.0 mask 255.252.0.0 default metric default if default
add 61.177.0.0 mask 255.255.0.0 default metric default if default
add 61.178.0.0 mask 255.255.0.0 default metric default if default
add 61.180.0.0 mask 255.255.128.0 default metric default if default
add 61.183.0.0 mask 255.255.0.0 default metric default if default
add 61.184.0.0 mask 255.252.0.0 default metric default if default
add 61.188.0.0 mask 255.255.0.0 default metric default if default
add 61.189.128.0 mask 255.255.128.0 default metric default if default
add 61.190.0.0 mask 255.254.0.0 default metric default if default
add 124.72.0.0 mask 255.255.0.0 default metric default if default
add 124.73.0.0 mask 255.255.0.0 default metric default if default
add 124.74.0.0 mask 255.254.0.0 default metric default if default
add 124.76.0.0 mask 255.252.0.0 default metric default if default
add 124.112.0.0 mask 255.254.0.0 default metric default if default
add 125.64.0.0 mask 255.248.0.0 default metric default if default
add 125.72.0.0 mask 255.255.0.0 default metric default if default
add 125.73.0.0 mask 255.255.0.0 default metric default if default
add 125.74.0.0 mask 255.254.0.0 default metric default if default
add 125.76.0.0 mask 255.255.0.0 default metric default if default
add 125.77.0.0 mask 255.255.0.0 default metric default if default
add 125.78.0.0 mask 255.254.0.0 default metric default if default
add 125.80.0.0 mask 255.248.0.0 default metric default if default
add 125.88.0.0 mask 255.248.0.0 default metric default if default
add 125.104.0.0 mask 255.248.0.0 default metric default if default
add 202.96.96.0 mask 255.255.248.0 default metric default if default
add 202.96.104.0 mask 255.255.248.0 default metric default if default
add 202.96.112.0 mask 255.255.240.0 default metric default if default
add 202.96.128.0 mask 255.255.248.0 default metric default if default
add 202.96.136.0 mask 255.255.248.0 default metric default if default
add 202.96.144.0 mask 255.255.240.0 default metric default if default
add 202.96.160.0 mask 255.255.248.0 default metric default if default
add 202.96.168.0 mask 255.255.248.0 default metric default if default
add 202.96.176.0 mask 255.255.240.0 default metric default if default
add 202.97.0.0 mask 255.255.248.0 default metric default if default
add 202.97.8.0 mask 255.255.248.0 default metric default if default
add 202.97.16.0 mask 255.255.240.0 default metric default if default
add 202.97.32.0 mask 255.255.224.0 default metric default if default
add 202.97.64.0 mask 255.255.224.0 default metric default if default
add 202.97.96.0 mask 255.255.240.0 default metric default if default
add 202.97.112.0 mask 255.255.240.0 default metric default if default
add 202.98.32.0 mask 255.255.248.0 default metric default if default
add 202.98.48.0 mask 255.255.240.0 default metric default if default
add 202.98.64.0 mask 255.255.224.0 default metric default if default
add 202.98.96.0 mask 255.255.248.0 default metric default if default
add 202.98.128.0 mask 255.255.224.0 default metric default if default
add 202.98.160.0 mask 255.255.248.0 default metric default if default
add 202.98.168.0 mask 255.255.248.0 default metric default if default
add 202.98.192.0 mask 255.255.248.0 default metric default if default
add 202.98.200.0 mask 255.255.248.0 default metric default if default
add 202.98.208.0 mask 255.255.240.0 default metric default if default
add 202.98.224.0 mask 255.255.248.0 default metric default if default
add 202.98.232.0 mask 255.255.248.0 default metric default if default
add 202.98.240.0 mask 255.255.240.0 default metric default if default
add 202.99.192.0 mask 255.255.248.0 default metric default if default
add 202.100.96.0 mask 255.255.248.0 default metric default if default
add 202.100.104.0 mask 255.255.248.0 default metric default if default
add 202.100.112.0 mask 255.255.240.0 default metric default if default
add 202.100.136.0 mask 255.255.248.0 default metric default if default
add 202.100.160.0 mask 255.255.248.0 default metric default if default
add 202.100.168.0 mask 255.255.248.0 default metric default if default
add 202.100.176.0 mask 255.255.240.0 default metric default if default
add 202.100.192.0 mask 255.255.248.0 default metric default if default
add 202.100.208.0 mask 255.255.240.0 default metric default if default
add 202.100.224.0 mask 255.255.224.0 default metric default if default
add 202.101.0.0 mask 255.255.192.0 default metric default if default
add 202.101.64.0 mask 255.255.224.0 default metric default if default
add 202.101.96.0 mask 255.255.224.0 default metric default if default
add 202.101.128.0 mask 255.255.192.0 default metric default if default
add 202.101.224.0 mask 255.255.248.0 default metric default if default
add 202.102.32.0 mask 255.255.224.0 default metric default if default
add 202.102.64.0 mask 255.255.192.0 default metric default if default
add 202.103.0.0 mask 255.255.248.0 default metric default if default
add 202.103.8.0 mask 255.255.248.0 default metric default if default
add 202.103.16.0 mask 255.255.240.0 default metric default if default
add 202.103.32.0 mask 255.255.224.0 default metric default if default
add 202.103.96.0 mask 255.255.248.0 default metric default if default
add 202.103.192.0 mask 255.255.224.0 default metric default if default
add 202.103.224.0 mask 255.255.248.0 default metric default if default
add 202.104.0.0 mask 255.254.0.0 default metric default if default
add 202.107.128.0 mask 255.255.128.0 default metric default if default
add 202.109.0.0 mask 255.255.0.0 default metric default if default
add 202.110.128.0 mask 255.255.192.0 default metric default if default
add 202.111.0.0 mask 255.255.128.0 default metric default if default
add 218.4.0.0 mask 255.254.0.0 default metric default if default
add 218.6.0.0 mask 255.255.0.0 default metric default if default
add 218.20.0.0 mask 255.255.0.0 default metric default if default
add 218.21.0.0 mask 255.255.128.0 default metric default if default
add 218.22.0.0 mask 255.254.0.0 default metric default if default
add 218.62.128.0 mask 255.255.128.0 default metric default if default
add 218.63.0.0 mask 255.255.0.0 default metric default if default
add 218.64.0.0 mask 255.254.0.0 default metric default if default
add 218.66.0.0 mask 255.255.0.0 default metric default if default
add 218.67.0.0 mask 255.255.128.0 default metric default if default
add 218.72.0.0 mask 255.248.0.0 default metric default if default
add 219.144.0.0 mask 255.248.0.0 default metric default if default
add 219.152.0.0 mask 255.254.0.0 default metric default if default
add 219.159.64.0 mask 255.255.192.0 default metric default if default
add 219.159.128.0 mask 255.255.128.0 default metric default if default
add 221.224.0.0 mask 255.248.0.0 default metric default if default
add 221.232.0.0 mask 255.252.0.0 default metric default if default
add 221.236.0.0 mask 255.254.0.0 default metric default if default
add 221.238.0.0 mask 255.255.0.0 default metric default if default
add 221.239.0.0 mask 255.255.128.0 default metric default if default
add 221.239.128.0 mask 255.255.128.0 default metric default if default
add 222.80.0.0 mask 255.254.0.0 default metric default if default
add 222.82.0.0 mask 255.255.0.0 default metric default if default
add 222.83.0.0 mask 255.255.128.0 default metric default if default
add 222.83.128.0 mask 255.255.128.0 default metric default if default
add 222.84.0.0 mask 255.255.0.0 default metric default if default
add 222.85.0.0 mask 255.255.128.0 default metric default if default
add 222.85.128.0 mask 255.255.128.0 default metric default if default
add 222.86.0.0 mask 255.254.0.0 default metric default if default
add 222.88.0.0 mask 255.254.0.0 default metric default if default
add 222.90.0.0 mask 255.254.0.0 default metric default if default
add 222.92.0.0 mask 255.252.0.0 default metric default if default
add 222.168.0.0 mask 255.254.0.0 default metric default if default
add 222.172.0.0 mask 255.255.128.0 default metric default if default
add 222.172.128.0 mask 255.255.128.0 default metric default if default
add 222.173.0.0 mask 255.255.0.0 default metric default if default
add 222.174.0.0 mask 255.254.0.0 default metric default if default
add 222.176.0.0 mask 255.248.0.0 default metric default if default
add 222.184.0.0 mask 255.248.0.0 default metric default if default
add 222.208.0.0 mask 255.248.0.0 default metric default if default
add 222.218.0.0 mask 255.255.0.0 default metric default if default
add 222.219.0.0 mask 255.255.0.0 default metric default if default
add 222.220.0.0 mask 255.254.0.0 default metric default if default
add 222.222.0.0 mask 255.254.0.0 default metric default if default
add 222.240.0.0 mask 255.248.0.0 default metric default if default
add 61.131.0.0 mask 255.255.0.0 default metric default if default
add 218.13.0.0 mask 255.255.0.0 default metric default if default
add 218.14.0.0 mask 255.255.0.0 default metric default if default
add 218.15.0.0 mask 255.255.0.0 default metric default if default
add 218.16.0.0 mask 255.255.0.0 default metric default if default
add 218.17.0.0 mask 255.255.0.0 default metric default if default
add 218.18.0.0 mask 255.255.0.0 default metric default if default
add 218.2.0.0 mask 255.255.0.0 default metric default if default
add 218.3.0.0 mask 255.255.0.0 default metric default if default
add 218.4.0.0 mask 255.255.0.0 default metric default if default
add 219.128.0.0 mask 255.240.0.0 default metric default if default
add 222.64.0.0 mask 255.240.0.0 default metric default if default
add 218.80.0.0 mask 255.255.0.0 default metric default if default
add 218.81.0.0 mask 255.255.0.0 default metric default if default
add 218.82.0.0 mask 255.255.0.0 default metric default if default
add 218.83.0.0 mask 255.255.0.0 default metric default if default
add 218.88.0.0 mask 255.254.0.0 default metric default if default
add 60.191.129.0 mask 255.255.255.0 default metric default if default
add 222.170.0.0 mask 255.254.0.0 default metric default if default
add 58.208.0.0 mask 255.240.0.0 default metric default if default
add 211.159.0.0 mask 255.255.128.0 default metric default if default
add 222.175.0.0 mask 255.255.0.0 default metric default if default
add 202.103.128.0 mask 255.255.192.0 default metric default if default
add 202.103.64.0 mask 255.255.192.0 default metric default if default
add 218.31.0.0 mask 255.255.0.0 default metric default if default
add 61.132.0.0 mask 255.255.128.0 default metric default if default
add 61.151.0.0 mask 255.255.0.0 default metric default if default
add 60.176.0.0 mask 255.240.0.0 default metric default if default
add 203.130.32.0 mask 255.255.224.0 default metric default if default
add 211.155.228.0 mask 255.255.255.0 default metric default if default
add 218.90.0.0 mask 255.255.0.0 default metric default if default
add 218.91.0.0 mask 255.255.0.0 default metric default if default
add 218.92.0.0 mask 255.255.0.0 default metric default if default
add 218.93.0.0 mask 255.255.0.0 default metric default if default
add 218.94.0.0 mask 255.255.0.0 default metric default if default
add 211.147.224.0 mask 255.255.224.0 default metric default if default
add 218.85.0.0 mask 255.255.0.0 default metric default if default
add 218.86.0.0 mask 255.255.128.0 default metric default if default
add 218.30.0.0 mask 255.255.0.0 default metric default if default
add 218.1.0.0 mask 255.255.0.0 default metric default if default
add 220.231.128.0 mask 255.255.128.0 default metric default if default
add 211.155.224.0 mask 255.255.240.0 default metric default if default
add 211.152.32.0 mask 255.255.224.0 default metric default if default
add 220.160.0.0 mask 255.224.0.0 default metric default if default
add 210.73.154.0 mask 255.255.255.0 default metric default if default
add 202.75.208.0 mask 255.255.240.0 default metric default if default
add 61.132.244.0 mask 255.255.255.0 default metric default if default
add 202.102.0.0 mask 255.255.128.0 default metric default if default
add 219.148.128.0 mask 255.255.224.0 default metric default if default
add 219.148.0.0 mask 255.255.128.0 default metric default if default
add 218.21.64.0 mask 255.255.192.0 default metric default if default
add 222.216.0.0 mask 255.252.0.0 default metric default if default
add 219.150.112.0 mask 255.255.240.0 default metric default if default
add 219.150.128.0 mask 255.255.128.0 default metric default if default
add 61.130.11.96 mask 255.255.255.224 default metric default if default
add 220.189.200.0 mask 255.255.252.0 default metric default if default
add 60.190.220.0 mask 255.255.255.224 default metric default if default
add 60.190.28.96 mask 255.255.255.224 default metric default if default
add 202.96.192.0 mask 255.255.192.0 default metric default if default
add 203.110.160.0 mask 255.255.224.0 default metric default if default
add 218.201.192.0 mask 255.255.192.0 default metric default if default
add 202.102.210.128 mask 255.255.255.128 default metric default if default
add 61.130.8.0 mask 255.255.255.0 default metric default if default
add 218.95.0.0 mask 255.255.0.0 default metric default if default
add 61.150.100.0 mask 255.255.255.0 default metric default if default
add 61.147.0.0 mask 255.255.0.0 default metric default if default
add 218.249.20.0 mask 255.255.255.0 default metric default if default
add 121.32.0.0 mask 255.252.0.0 default metric default if default
add 202.100.85.0 mask 255.255.255.0 default metric default if default
add 60.191.160.0 mask 255.255.224.0 default metric default if default
add 219.151.128.0 mask 255.255.128.0 default metric default if default
add 60.190.222.0 mask 255.255.255.0 default metric default if default
add 60.190.81.128 mask 255.255.255.128 default metric default if default
add 218.70.0.0 mask 255.255.0.0 default metric default if default
add 61.128.0.0 mask 255.254.0.0 default metric default if default
add 219.234.0.0 mask 255.255.224.0 default metric default if default
add 218.246.34.0 mask 255.255.255.0 default metric default if default
add 220.163.0.0 mask 255.253.0.0 default metric default if default
add 203.88.192.0 mask 255.255.224.0 default metric default if default
add 222.76.0.0 mask 255.124.0.0 default metric default if default
add 221.228.0.0 mask 255.252.0.0 default metric default if default
add 218.246.64.0 mask 255.255.240.0 default metric default if default
add 58.66.0.0 mask 255.128.0.0 default metric default if default
add 203.80.144.0 mask 255.255.240.0 default metric default if default
add 220.189.206.16 mask 255.255.255.252 default metric default if default
add 202.100.0.0 mask 255.255.224.0 default metric default if default
add 58.66.0.0 mask 255.254.0.0 default metric default if default
add 202.102.197.0 mask 255.255.254.0 default metric default if default
add 202.102.202.128 mask 255.255.255.128 default metric default if default
REMOVE_GATEWAY
 楼主| 发表于 2007-12-30 08:07:58 | 显示全部楼层
尽快搞出来
 楼主| 发表于 2008-1-1 04:18:01 | 显示全部楼层
发表于 2009-2-26 22:39:45 | 显示全部楼层
此贴已阅!顶一下吧
好久没来,论坛感觉好静啊!!!  ~~~~
美图秀秀免费杀毒软件瑞星杀毒软件极品五笔wps office
GMT+8, 2026-10-18 17:39 , Processed in 0.053488 second(s), 18 queries .
