查看: 2165|回复: 0
企业的ASA配置
发表于 2007-12-24 19:00:54 | 显示全部楼层 |阅读模式
企业的ASA配置
某企业ASA配置,共3台。供大家参考学习。 谢谢。
ASA5520A=======
ASA-5520-A# sh run
: Saved
ASA Version 7.2(2)
hostname ASA-5520-A
domain-name default.domain.invalid
enable password 2KFQnbNIdI.2KYOU encrypted
names
dns-guard
interface GigabitEthernet0/0
description Connect to F5:1.5
nameif outside
security-level 0
ip address 192.168.*.* 255.255.255.128 standby 192.168.*.*
interface GigabitEthernet0/1
description Connect to Catalyst3750G
nameif inside
security-level 100
ip address 10.252.*.* 255.255.0.0 standby 10.252.*.*
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
description LAN/STATE Failover Interface
interface Management0/0
nameif management
security-level 100
no ip address
management-only
boot system disk0:/asa722-k8.bin
ftp mode passive
dns server-group DefaultDNS
access-list acl_out extended permit tcp any host 10.252.*.* eq 81
access-list acl_out extended permit tcp any host 10.252.*.* eq https
access-list acl_out extended permit tcp any host 10.252.*.* eq www
access-list acl_out extended permit tcp any host 10.252.*.* eq smtp
access-list acl_out extended permit tcp any host 10.252.*.* eq pop3
access-list acl_out extended permit tcp any host 10.252.*.* range ftp-data ftp
access-list acl_out extended permit tcp any host 10.252.*.* eq 5900
access-list acl_out extended permit tcp any host 10.252.*.* eq 7001
access-list acl_out extended permit tcp any host 10.252.*.* eq 7070
access-list acl_out extended permit icmp any any
access-list ATAEDA_splitTunnelAcl standard permit 10.252.*.* 255.255.0.0
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
ip local pool ippool 10.1.*.*-10.1.*.* mask 255.255.255.0
failover
failover lan unit primary
failover lan interface failover GigabitEthernet0/3
failover polltime unit 1 holdtime 3
failover link failover GigabitEthernet0/3
failover interface ip failover 192.168.*.* 255.255.255.252 standby 192.168.*.*
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
access-group acl_out in interface outside
route outside 0.0.0.0 0.0.0.0 192.168.*.* 1
timeout xlate 3:00:00
group-policy ATAEDA internal
group-policy ATAEDA attributes
vpn-tunnel-protocol IPSec
split-tunnel-network-list value ATAEDA_splitTunnelAcl
username *** password 44CIL/eskQBRuFH0 encrypted privilege 0
username **** attributes
vpn-group-policy ATAEDA
username cisco password 3USUcOPFUiMCO4Jk encrypted privilege 15
http server enable
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group ATAEDA type ipsec-ra
tunnel-group ATAEDA general-attributes
address-pool ippool
default-group-policy ATAEDA
tunnel-group ATAEDA ipsec-attributes
pre-shared-key *
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
  inspect icmp error
ssl encryption des-sha1 rc4-md5
prompt hostname context
Cryptochecksum:77ca19c2b37b4e5bff152990205163f2
: end
ASA-5520-A#
====ASA-5520-A-2
ASA-5520-A# sh run
: Saved
ASA Version 7.2(2)
hostname ASA-5520-A
names
dns-guard
nameif outside
security-level 0
nameif inside
security-level 100
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
no ip address
management-only
ftp mode passive
access-list acl_out extended permit tcp any host 10.252.** eq 81
access-list acl_out extended permit tcp any host 10.252.** eq https
access-list acl_out extended permit tcp any host 10.252.** eq www
access-list acl_out extended permit tcp any host 10.252.** eq smtp
access-list acl_out extended permit tcp any host 10.252.** eq pop3
access-list acl_out extended permit tcp any host 10.252.** range ftp-data ftp
access-list acl_out extended permit tcp any host 10.252.** eq 5900
access-list acl_out extended permit tcp any host 10.252.** eq 7001
access-list acl_out extended permit tcp any host 10.252.** eq 7070
access-list ATAEDA_splitTunnelAcl standard permit 10.252.** 255.255.0.0
pager lines 24
mtu outside 1500
mtu inside 1500
mtu management 1500
ip local pool ippool 10.1.**-10.1.** mask 255.255.255.0
failover
failover lan unit secondary
failover interface ip failover 192.168.** 255.255.255.252 standby 192.168.**
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 192.168.** 1
username **** password 44CIL/eskQBRuFH0 encrypted privilege 0
username *** attributes
http server enable
encryption 3des
hash sha
group 2
lifetime 86400
address-pool ippool
pre-shared-key *
telnet timeout 5
ssh timeout 5
console timeout 0
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
  inspect icmp error
Cryptochecksum:aa59061b40f19d8bf05392e669e3c7e0
: end
ASA-5520-A#
=====ASA5520B
ASA-5520-B# sh run
: Saved
ASA Version 7.2(2)
hostname ASA-5520-B
names
nameif outside
security-level 0
ip address 10.252.** 255.255.0.0 standby 10.252.**
description Connect to Catalyst4006
nameif inside
security-level 100
ip address 10.9.** 255.255.0.0 standby 10.9.**
shutdown
no nameif
no security-level
no ip address
shutdown
shutdown
no nameif
no security-level
no ip address
ftp mode passive
access-list acl_out extended permit tcp host 10.252.** host 10.252.** gt 2046
access-list acl_out extended permit tcp host 10.252.** host 10.252.** eq 7001
access-list acl_out extended permit tcp host 10.252.** host 10.252.** range ftp-data ftp
pager lines 24
mtu outside 1500
mtu inside 1500
failover
failover polltime interface 3 holdtime 15
arp timeout 14400
static (inside,outside) 10.252.** 10.9.** netmask 255.255.255.255
route outside 0.0.0.0 0.0.0.0 10.252.0.*
route inside 10.1.** 255.255.0.0 10.9.* 1
telnet timeout 5
ssh timeout 5
console timeout 0
parameters
  message-length maximum 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
Cryptochecksum:b76e1aac96addd3be5ca643ee457c15e
: end
ASA-5520-B#
GMT+8, 2026-11-12 11:54 , Processed in 0.034370 second(s), 18 queries .
