查看: 2385|回复: 0
ASA配置笔记
发表于 2007-12-19 13:29:32 | 显示全部楼层 |阅读模式
ASA配置笔记
Cisco新的防火墙ASA系列已经面市了,将逐步取代PIX防火墙,网上关于ASA配置资料很少,现把我积累的ASA配置技术编写一个文档,供大家参考。
1.    常用技巧....................................................................................... 1
2.    故障倒换....................................................................................... 1
3.    配置telnet、ssh及http管理............................................................ 3
4.    vpn常用管理命令.......................................................................... 3
5.    配置访问权限................................................................................ 3
6.    配置sitetosite之VPN...................................................................... 4
7.    webvpn配置(ssl vpn)................................................................. 4
8.    远程拨入VPN................................................................................ 5
9.    日志服务器配置............................................................................. 6
10.    Snmp网管配置............................................................................. 7
11.    ACS配置...................................................................................... 7
12.    AAA配置..................................................................................... 7
13.    升级IOS...................................................................................... 8
14.    疑难杂症...................................................................................... 8
1.       常用技巧
Sh ru ntp查看与ntp有关的
Sh ru crypto 查看与vpn有关的
Sh ru | inc crypto 只是关健字过滤而已
2.       故障倒换
failover
failover lan unit primary
failover lan interface testint Ethernet0/3
failover link testint Ethernet0/3
failover mac address Ethernet0/1 0018.1900.5000 0018.1900.5001
failover mac address Ethernet0/0 0018.1900.4000 0018.1900.4001
failover mac address Ethernet0/2 0018.1900.6000 0018.1900.6001
failover mac address Management0/0 0018.1900.7000 0018.1900.7001
failover interface ip testint 10.3.3.1 255.255.255.0 standby 10.3.3.2
注:最好配置虚拟MAC地址
sh failover显示配置信息
write standby写入到备用的防火墙中
failover命令集如下:
configure mode commands/options:
  interface         Configure the IP address and mask to be used for failover
                    and/or stateful update information
  interface-policy  Set the policy for failover due to interface failures
  key               Configure the failover shared secret or key
  lan               Specify the unit as primary or secondary or configure the
                    interface and vlan to be used for failover communication
  link              Configure the interface and vlan to be used as a link for
  mac               Specify the virtual mac address for a physical interface
  polltime          Configure failover poll interval
  replication       Enable HTTP (port 80) connection replication
  timeout           Specify the failover reconnect timeout value for
                    asymmetrically routed sessions
sh failover 命令集如下:
  history     Show failover switching history
  interface   Show failover command interface information
  state       Show failover internal state information
  statistics  Show failover command interface statistics information
  |           Output modifiers
  <cr>
username jiang password Csmep3VzvPQPCbkx encrypted privilege 15
aaa authentication enable console LOCAL
aaa authentication telnet console LOCAL
aaa authentication ssh console LOCAL
aaa authorization command LOCAL
http 192.168.40.0 255.255.255.0 management
ssh 192.168.40.0 255.255.255.0 inside
4.       vpn常用管理命令
sh vpn-sessiondb full l2l 显示site to site 之vpn通道情况
sh ipsec stats 显示ipsec通道情况
sh vpn-sessiondb summary 显示vpn汇总信息
sh vpn-sessiondb detail l2l 显示ipsec详细信息
sh vpn-sessiondb detail svc 查看ssl client信息
sh vpn-sessiondb detail webvpn 查看webvpn信息
sh vpn-sessiondb detail full l2l 相当于linux下的ipsec whack –status 如果没有建立连接,则表示ipsec通道还没有建立起来。
5.       配置访问权限
可以建立对象组,设定不同的权限,如:
    object-group network testgroup
           description test
           network-object 192.168.100.34 255.255.255.255
       access-list inside_access_in line 2 extended permit ip object-group all any
6.       配置sitetosite之VPN
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map outside_map 20 match address outside_cryptomap_20_1
crypto map outside_map 20 set pfs
crypto map outside_map 20 set peer 218.16.105.48
crypto map outside_map 20 set transform-set ESP-3DES-SHA
isakmp identity address
isakmp enable outside
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
tunnel-group 218.16.105.48 type ipsec-l2l
tunnel-group 218.16.105.48 ipsec-attributes
pre-shared-key *
peer-id-validate nocheck
tunnel-group-map enable rules
注:打打PFS并设定以IP地址作为peer名,一个接口只能有一个加密图
webvpn
enable outside
character-encoding gb2312
csd image disk0:/securedesktop-asa-3.1.1.16.pkg
svc image disk0:/sslclient-win-1.1.0.154.pkg 1
svc enable
customization customization1
  title text TEST WebVPN system
  title style background-color:white;color: rgb(51,153,0);border-bottom:5px groo
ve #669999;font-size:larger;vertical-align:middle;text-align:left;font-weight:bold
tunnel-group-list enable
注:也可通过ASDM图形界面进行配置
登录后,可访问内部资源,如下例:(客户端首先要安装Java插件jre-1_5_0-windows-i586.exe,并打开浏览器的ActiveX)
1) https://sslvpn.test.com.cn 输入用户名和密码
2) 出现工具条
3) 在Enter Web Address内输入192.168.40.8即可访问内部网站
4)在browse network输入192.168.40.8即可访问共享文件
5)点击application access,即可查看端口转发设置,如使用putty访问本机的2023端口,则即可通过ssh登录192.168.40.8
8.       远程拨入VPN
相关的ASA配置命令如下:
access-list inside_access_in extended permit ip object-group remotegroup any
access-list inside_access_in extended permit icmp object-group remotegroup any
access-list remotevpn_splitTunnelAcl standard permit 192.168.100.0 255.255.255.0
access-list vpnclient_splitTunnelAcl standard permit 192.168.100.0 255.255.255.0
ip local pool dialuserIP 192.168.101.1-192.168.101.254 mask 255.255.255.0
group-policy remotevpn attributes
dns-server value 202.96.128.68 192.168.40.16
default-domain value test.com.cn
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 20 set reverse-route
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
tunnel-group remotevpn type ipsec-ra
tunnel-group remotevpn general-attributes
address-pool dialuserIP
default-group-policy remotevpn
tunnel-group remotevpn ipsec-attributes
pre-shared-key *
客户端设置如下:
9.       日志服务器配置
logging enable
logging timestamp
logging emblem
logging trap informational
logging asdm warnings
logging host inside 192.168.40.115 format emblem
logging permit-hostdown
vpn-simultaneous-logins 3
10.  Snmp网管配置
snmp-server host inside 192.168.40.47 community testsnmp
snmp-server location DG-GTEST
snmp-server contact jiangdaoyou:6162
snmp-server community testsnmp
注:指定主机后,192.168.40.47才可能进行管理
11.  ACS配置
    安装后管理:http://ip:2002 通过ACS可以进行授权、认证等等很多功能
       因内容太多,暂省略
12.  AAA配置
Aaa服务器配置:
aaa-server radius_dg host dc03.xxxx.com
key dfdfdfdf146**U
authentication-port 1812
accounting-port 1813
radius-common-pw dfdfdfdf146**U
对于拨入vpn的配置
tunnel-group vg_testerp general-attributes
address-pool ciscovpnuser
authentication-server-group radius_dg
default-group-policy vg_testerp
13.  升级IOS
copy tftp://192.168.40.180/asa/asa721-k8.bin disk0:/asa721-k8.bin
boot system disk0:/asa721-k8.bin (多个Image时使用)
14.  疑难杂症
1)        在远程子网不能ping通过对方的网关,如在无锡格兰不能ping 192.168.40.251
输入命令:management-access inside (通过ASDM不能设置这一项)
2)        NAT有时不能快速启作
GMT+8, 2026-11-12 11:54 , Processed in 0.038771 second(s), 18 queries .
