查看: 3247|回复: 2
虚拟防火墙测试贴!!!!
发表于 2007-12-19 13:24:26 | 显示全部楼层 |阅读模式
虚拟防火墙测试贴!!!!庆五一!!!
虚拟防火墙(一个出口)
pix(config)#mode multiple 把防火墙从单一
模式改为支持多防火墙模式。会自动重启!
会默认一子防火墙
admin-context admin
context admin
  config-url flash:/admin.cfg
全局下新建一个子墙
context ctx1(命名子墙)
  allocate-interface Ethernet2 把接口加入到子墙ctx1
  allocate-interface Ethernet5 把接口加入到子墙ctx1
  config-url flash:/config1.cfg 命名存放配置文件
context ctx2(命名子墙)
  allocate-interface Ethernet3 把接口加入到子墙ctx2
  allocate-interface Ethernet4 把接口加入到子墙ctx2
  config-url flash:/config2.cfg 命名存放配置文件
进子防火墙
cha cont ctx1 (虚拟防火墙名)
然后在子防火墙里当普通墙正常配
sh ver
Cisco PIX Security Appliance Software Version 7.0(2) <system>
Compiled on Fri 15-Jul-05 22:55 by builders
System image file is "flash:/image.bin"
Config file at boot was "startup-config"
pixfirewall up 7 mins 37 secs
Hardware:   PIX-525, 256 MB RAM, CPU Pentium III 600 MHz
Flash E28F128J3 @ 0xfff00000, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Encryption hardware device : VAC+ (Crypto5823 revision 0x1)
0: Ext: Ethernet0           : address is 0012.daf1.5686, irq 10
1: Ext: Ethernet1           : address is 0012.daf1.5687, irq 11
2: Ext: Ethernet2           : address is 000d.88ff.b804, irq 11
3: Ext: Ethernet3           : address is 000d.88ff.b805, irq 10
4: Ext: Ethernet4           : address is 000d.88ff.b806, irq 9
5: Ext: Ethernet5           : address is 000d.88ff.b807, irq 5
Licensed features for this platform:
Maximum Physical Interfaces : 10
Maximum VLANs               : 100
Inside Hosts                : Unlimited
<--- More --->
Failover                    : Active/Active
VPN-DES                     : Enabled
VPN-3DES-AES                : Enabled
Cut-through Proxy           : Enabled
Guards                      : Enabled
URL Filtering               : Enabled
Security Contexts           : 2
GTP/GPRS                    : Disabled
VPN Peers                   : Unlimited
This platform has an Unrestricted (UR) license.
Serial Number: 808495289
Running Activation Key: 0xd60ccff6 0x66c10288 0x4708d0ce 0x2ae96ff3
Configuration has not been modified since last system restart.
pixfirewall# sh run
: Saved
PIX Version 7.0(2) <system>
interface Ethernet0
interface Ethernet0.3
vlan 3
interface Ethernet1
interface Ethernet1.4
vlan 4
interface Ethernet1.5
vlan 5
interface Ethernet1.6
vlan 6
interface Ethernet1.7
vlan 7
interface Ethernet2
shutdown
<--- More --->
interface Ethernet3
shutdown
interface Ethernet4
shutdown
interface Ethernet5
shutdown
hostname pixfirewall
ftp mode passive
pager lines 24
no failover
no asdm history enable
arp timeout 14400
console timeout 0
admin-context admin
context admin
  allocate-interface Ethernet0.3
  allocate-interface Ethernet1.4
<--- More --->
context cnc-1
  allocate-interface Ethernet1.5
  config-url flash:/admin1.cfg
context cnc-2
  allocate-interface Ethernet1.6
  config-url flash:/admin2.cfg
Cryptochecksum:2ca7023a984f7b13b7e8d439d2e31f5d
: end
pixfirewall#
pixfirewall# changeto context admin  进子防火墙
pixfirewall/admin# sh run
: Saved
PIX Version 7.0(2) <context>
names
nameif outside
security-level 0
ip address 192.168.0.10 255.255.255.0
nameif inside
security-level 100
access-list 1 extended permit icmp any any
pager lines 24
mtu outside 1500
mtu inside 1500
icmp permit any outside
icmp permit any inside
<--- More --->
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 192.168.1.0 255.255.255.0
access-group 1 in interface outside
route outside 0.0.0.0 0.0.0.0 192.168.0.100 1
timeout xlate 3:00:00
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp
telnet timeout 5
ssh timeout 5
class-map inspection_default
policy-map global_policy
class inspection_default
  inspect ftp
<--- More --->
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
Cryptochecksum:94b0359659f181071f35aed50efda86f
: end
pixfirewall/admin# exit
pixfirewall#
pixfirewall#  changeto context cnc-1
pixfirewall/cnc-1# sh run
: Saved
names
nameif outside
security-level 0
ip address 192.168.0.11 255.255.255.0
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
hostname cnc-1
pager lines 24
mtu outside 1500
mtu inside 1500
<--- More --->
arp timeout 14400
nat (inside) 1 0.0.0.0 0.0.0.0
telnet timeout 5
ssh timeout 5
  inspect ftp
<--- More --->
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
Cryptochecksum:1ae33c23b0bca81a0714bc6668207811
: end
pixfirewall/cnc-1# exit
pixfirewall#
pixfirewall# changeto context cnc-2 进子防火墙
pixfirewall/cnc-2# sh run
: Saved
names
nameif outside
security-level 0
ip address 192.168.0.13 255.255.255.0
nameif inside
security-level 100
ip address 192.168.6.1 255.255.255.0
hostname cnc-2
pager lines 24
mtu outside 1500
mtu inside 1500
<--- More --->
arp timeout 14400
telnet timeout 5
ssh timeout 5
  inspect ftp
<--- More --->
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
Cryptochecksum:66e1eba6f57fd5db9fea45987ad44959
: end
pixfirewall/cnc-2#
 楼主| 发表于 2007-12-19 13:24:52 | 显示全部楼层
虚拟防火墙(多个出口)
sh ver
pixfirewall up 9 mins 51 secs
Maximum VLANs               : 100
<--- More --->
VPN-DES                     : Enabled
Guards                      : Enabled
GTP/GPRS                    : Disabled
pixfirewall# sh run
: Saved
interface Ethernet0
interface Ethernet1
interface Ethernet2
interface Ethernet3
interface Ethernet4
interface Ethernet5
ftp mode passive
pager lines 24
no failover
arp timeout 14400
console timeout 0
<--- More --->
admin-context admin
context admin
context cnc-1
  config-url flash:/cnc-1.cfg
context cnc-2
  config-url flash:/cnc-2.cfg
Cryptochecksum:1785a918b6c389976708b6f933687826
: end
pixfirewall#
: Saved
names
interface Ethernet0
nameif outside
security-level 0
interface Ethernet1
nameif inside
security-level 100
hostname admin
pager lines 24
mtu outside 1500
mtu inside 1500
monitor-interface outside
monitor-interface inside
<--- More --->
arp timeout 14400
telnet timeout 5
ssh timeout 5
<--- More --->
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
Cryptochecksum:0fa292be4bf97aadf52da496b3c521d4
: end
pixfirewall/admin#
pixfirewall#
pixfirewall#  changeto context cnc-1 进子防火墙
: Saved
names
interface Ethernet2
nameif outside
security-level 0
interface Ethernet3
nameif inside
security-level 100
ip address 192.168.3.1 255.255.255.0
hostname cnc-1
pager lines 24
mtu outside 1500
mtu inside 1500
<--- More --->
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 192.168.2.100 1
telnet timeout 5
ssh timeout 5
<--- More --->
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
Cryptochecksum:037ff73f3db30dbbc964c48c536c0816
: end
pixfriewall#
: Saved
names
interface Ethernet4
nameif outside
security-level 0
ip address 192.168.4.1 255.255.255.0
interface Ethernet5
nameif inside
security-level 100
ip address 192.168.5.1 255.255.255.0
hostname cnc-2
pager lines 24
mtu outside 1500
mtu inside 1500
<--- More --->
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 192.168.4.100 1
telnet timeout 5
ssh timeout 5
<--- More --->
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
Cryptochecksum:738597503a14f95ceb5a1efed1ddb8cf
: end
pixfirewall/cnc-2#
发表于 2008-11-12 18:44:30 | 显示全部楼层
怎么解决
怎么解决怎么解决怎么解决怎么解决怎么解决怎么解决怎么解决
GMT+8, 2026-11-12 11:43 , Processed in 0.049091 second(s), 18 queries .
