查看: 2076|回复: 0
这是XX科研设计院ASA5520防火墙用上了全部功能.
发表于 2007-12-19 12:57:27 | 显示全部楼层 |阅读模式
这是XX科研机构ASA5520防火墙用上了全部功能.
这是XX科研机构ASA5520防火墙应用LAN-LAN (动太IP地址)-ipsecvpn-sslvpn-AAA(windows AD
认证)
ASA Version 7.2(2)
hostname CD-ASA5520
domain-name default.domain.invalid
enable password iMsyYaAobonWHTAx encrypted
names
dns-guard
interface GigabitEthernet0/0
duplex full
nameif inside
security-level 100
interface GigabitEthernet0/1
nameif outside
security-level 0
ip address *.*.*122 255.255.255.0
interface GigabitEthernet0/2
nameif dmz
security-level 50
ip address 192.168.2.1 255.255.255.0
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
ftp mode passive
clock timezone CST 8
dns server-group DefaultDNS
same-security-traffic permit intra-interface
access-list outside_permit extended permit udp any interface outside eq 16000
access-list outside_permit extended permit udp any interface outside eq 60000
access-list outside_permit extended permit udp any interface outside eq 6669
access-list outside_permit extended permit tcp any interface outside eq 5452
access-list outside_permit extended permit icmp any any
access-list inside_nat0_outbound extended permit ip 192.168.200.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.200.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.16.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 10.10.10.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.200.0 255.255.255.0 192.168.16.0 255.255.255.0
access-list 100 extended permit ip 192.168.1.0 255.255.255.0 192.168.16.0 255.255.255.0
access-list 100 extended permit ip 192.168.200.0 255.255.255.0 192.168.16.0 255.255.255.0
access-list 100 extended permit ip 10.10.10.0 255.255.255.0 192.168.16.0 255.255.255.0
access-list splittunnel standard permit 192.168.1.0 255.255.255.0
access-list splittunnel standard permit 192.168.16.0 255.255.255.0
pager lines 24
logging enable
logging asdm warnings
logging host inside 192.168.1.129 format emblem
logging permit-hostdown
logging class sys asdm alerts
logging class vpn asdm alerts
mtu inside 1500
mtu outside 1500
mtu dmz 1500
ip local pool vpnclient 192.168.200.1-192.168.200.200 mask 255.255.255.0
ip local pool ssl-user 10.10.10.1-10.10.10.50
no failover
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
static (dmz,outside) udp interface 16000 192.168.2.2 16000 netmask 255.255.255.255
static (dmz,outside) udp interface 60000 192.168.2.2 60000 netmask 255.255.255.255
static (dmz,outside) udp interface 6669 192.168.2.2 6669 netmask 255.255.255.255
static (dmz,outside) tcp interface 5452 192.168.2.2 5452 netmask 255.255.255.255
access-group outside_permit in interface outside
route outside 0.0.0.0 0.0.0.0 *.*.*126 1
timeout xlate 3:00:00
aaa-server vpn protocol radius
aaa-server vpn host 192.168.1.129
timeout 30
key cisco123
group-policy mysslvpn-group-policy internal
group-policy mysslvpn-group-policy attributes
vpn-tunnel-protocol webvpn
webvpn
  svc enable
group-policy vpnclient internal
group-policy vpnclient attributes
wins-server value 192.168.1.10
dns-server value 192.168.1.10 61.139.2.69
vpn-idle-timeout none
vpn-session-timeout none
vpn-tunnel-protocol IPSec
default-domain value cisco.com
group-policy l2lvpn internal
group-policy l2lvpn attributes
vpn-simultaneous-logins 3
username test password LTfBjYjCrzZdSji0Nod2kw== nt-encrypted privilege 5
username test attributes
vpn-group-policy mysslvpn-group-policy
username skychen password 7fFvYcEbvJWTIWTB encrypted privilege 15
username cisco password jyV7i27DkE6FyekU encrypted privilege 15
username hwxian password dpY21DedfTLBOIdw encrypted privilege 15
http server enable 8080
http 0.0.0.0 0.0.0.0 inside
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
crypto dynamic-map vpn_dyn_map 10 set transform-set ESP-DES-MD5
crypto map outside_map 10 ipsec-isakmp dynamic vpn_dyn_map
crypto map outside_map 10 match address 100
crypto isakmp enable outside
crypto isakmp policy 20
authentication pre-share
encryption des
hash md5
group 2
lifetime 86400
crypto isakmp policy 65535
encryption des
hash md5
group 2
lifetime 86400
crypto isakmp nat-traversal  20
tunnel-group DefaultL2LGroup general-attributes
default-group-policy l2lvpn
tunnel-group DefaultL2LGroup ipsec-attributes
pre-shared-key *
tunnel-group vpnclient type ipsec-ra
tunnel-group vpnclient general-attributes
address-pool vpnclient
authentication-server-group vpn
authentication-server-group (inside) vpn
default-group-policy vpnclient
tunnel-group vpnclient ipsec-attributes
pre-shared-key *
tunnel-group mysslvpn-group type webvpn
tunnel-group mysslvpn-group general-attributes
address-pool ssl-user
tunnel-group mysslvpn-group webvpn-attributes
group-alias group2 enable
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 60
console timeout 0
dhcp-client update dns server both
dhcpd dns 61.139.2.69 202.98.96.68
dhcpd address 192.168.1.10-192.168.1.254 inside
dhcpd enable inside
class-map inspection_default
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
policy-map type inspect dns migrated_dns_map_1
parameters
webvpn
enable outside
svc image disk0:/sslclient-win-1.1.3.173.pkg 1
svc enable
tunnel-group-list enable
prompt hostname context
Cryptochecksum:2018b3083a53e1cfb5ce32713f0d0784
: end
CD-ASA5520#
GMT+8, 2026-11-12 11:54 , Processed in 0.032572 second(s), 18 queries .
