查看: 3684|回复: 1
Samba配置(AS4)
发表于 2007-11-2 15:06:52 | 显示全部楼层 |阅读模式
Samba是一个功能强大的软件工具,它可以让基于linux操作系统的计算机系统和基于Windows的计算机系统相互通讯
安装如下rpm包就行了
[root@FC4103 ~]# rpm -qa|grep samba
system-config-samba-1.2.31-1
samba-common-3.0.14a-2
samba-client-3.0.14a-2
samba-3.0.14a-2
[root@FC4103 ~]#
修改smb.conf,找到"encrypt passwords = yes"和"smb passwd file = /etc/samba/smbpasswd"这两行,把前面的“;”去掉,运行smbpasswd -a root,设置samba里root用户的密码,以后要修改运行smbpasswd root即可(第一次要用-a选项),启动smbd和nmbd进程(直接#smbd,#smbd或者service smb start)
1.linux连接到windows的共享目录
[root@FC103 ~]# smbclient //192.168.18.55/test -U administrator
Password:         #输入adminstrator的密码
Domain=[35-LIUKM] OS=[Windows Server 2003 3790] Server=[Windows Server 2003 5.2]
smb: \> ls
  .                                   D        0  Tue Apr  4 01:35:20 2006
  ..                                  D        0  Tue Apr  4 01:35:20 2006
  test.txt                            A       11  Tue Apr  4 01:37:06 2006
                39985 blocks of size 524288. 6255 blocks available
smb: \> more test.txt
getting file \test.txt of size 11 as /tmp/smbmore.hh3gLe (0.4 kb/s) (average 0.4 kb/s)
Just a test
smb: \> ?
?              altname        archive        blocksize      cancel
case_sensitive cd             chmod          chown          del
dir            du             exit           get            getfacl
hardlink       help           history        lcd            link
lowercase      ls             mask           md             mget
mkdir          more           mput           newer          open
print          printmode      prompt         put            pwd
q              queue          quit           rd             recurse
reget          rename         reput          rm             rmdir
setmode        stat           symlink        tar            tarmode
translate      vuid           logon          listconnect    showconnect
smb: \>
2.windows连接linux共享
在/etc/samba/smb.conf中加入如下内容
guest ok = yes
map to guest = Bad User
map to guest = bad password
guest account= nobody
如果不加guest account=nobody,默认也是nobody登陆的!这个可以根据具体情况选择用特定的帐户,主要是结合权限!
设定一个public目录,运行\\192.168.200.103就可以打开public的,再设定一个需要输入用户名和密码才可以登陆的目录如rootdir,另设定一个用户登陆进去后可以看到自己的家目录的
[public]
   comment = Public Stuff
   path = /km/
   public = yes
   read only = yes
   write list = @staff
[rootdir]
   comment = root's Service
   path = /root/
   valid users = root
   public = no
   writable = yes
   printable = no
[homes]
   comment = Home Directories
   browseable = no
   writable = yes
 楼主| 发表于 2007-11-2 15:08:40 | 显示全部楼层
samba配置文件实例
# /etc/smb.conf
# SAMBA主配置文件
# 配置文件的骨架,根据你的需求选择其中的参数。
# 测试通过的系统: Solaris系统和 Linux各个发布版本
# RedHat 6.0, 7.0 和 7.1
# Solaris 7
# Slackware 7.x
# Mandrake 6.1, 7.0 和 8.1
# SuSe 7.2
# 这个文件按照SAMBA规范来开发的,可以参见smb.conf(5)手册。
# OBS: 更改本文件以后,使用"testparm"命令来测试。
#======================== Global Options =======================#
# 总配置
[global]
# workgroup = NT-Domain-Name o Workgroup-Name,比如: THEDOMAIN
# PDC域
workgroup = THEDOMAIN
# 在其他的机器中声明的本机器的名称
netbios name = SMBServer
# 这个声明会出现在Windows的“网络邻居”中
server string = Samba Server de este lugar
# 这一行由于安全的原因很关键,只许在局域网中特定的计算机的连接。
# 在这个例子中,是192.168.8.0(C级网络)的网络
# 和“环路”(loopback)的接口是可以连接的。
# 更多的细节,请阅读smb.conf man手册。
# 比如:只有从规定开始的ip以后的地址才能共享资源。
# 192.168.8 和 127 (以后的注释)
; hosts allow = 192.168.8. 127.
# 如果你想自动载入一个打印机的清单,这样就不必一个一个手动录入,可以使用:
; load printers = yes
# 覆盖printcap的路径是可能的。
; printcap name = /etc/printcap
# 在SystemV系统中 printcap对lpstat名称属性一定允许
# 自动地从SystemV(这么个词!:-))的spool系统中取得打印机列表。
; printcap name = lpstat
# 如果打印机系统是非标准的,就需要指定是什么打印系统。
# 现在支持的打印系统有:
# bsd, sysv, plp, lprng, aix, hpux, qnx
; printing = bsd
# 如果你需要一个guest帐户,你不要注释掉下面这行。
# 你一定么加入这条到/etc/passwd里,否则这个用户无“人”可用。
; guest account = pcguest
# 下面这条就是使得每台计算机都有一个不同的log文件,
# 通过这个文件和SAMBA服务器相连。
log file = /var/log/samba/log.%m
# 设置log文件长度的限制(单位 Kb)。
max log size = 50
# 阅读security_level.txt for得到更多的细节
# 指定验证密码的方式
# 用户级的安全策略=每个用户都有自己的密码 (SAMBA密码)
security = user
# 如果使用服务器级的安全策略,验证过程在另一个机器上进行。
# 只有在使用服务器级的安全策略时,才使用值"password server"
# 密码服务器等于【认证服务器地址】。
; password server = <NT-Server-Name>
# 如果你想使用加密的密码,请阅读Samba文档中的ENCRYPTION.TXT,
# Win95.txt和WinNT.txt。
# 你只有清楚的了解这个属性的足够多的信息才能使用它。
# 信息:Win95,Win98和 WinNT 可以发送加密的密码。
# 使用下列的行来定制你的配置。
# 在网络中的每个计算机,%m 取代了自身netbios的名字。
; include = /usr/local/samba/lib/smb.conf.%m
# 在你会发现文档和一些流行的“提示”会告诉你下面的选项可以得到更好的性能。
# 试试!
# 阅读speed.txt和手册来知道更多的细节。
socket options = TCP_NODELAY
# Samba 可以配置多种的网络接口。
# 如果你使用多种网络接口,你一定要在下面列出来。
# 阅读手册来知道更多的细节。
; interfaces = 192.168.8.2/24 192.168.12.2/24
# Browser 控制选项:
# 如果你不想让samba做为网络中的主browser, 设置"local master = no"。
local master = yes
# 在OS 水平上,本服务器当选主browser优先权的设置。
# 一般地,缺省值可能就可以了。
; os level = 33
# 域主机指定Samba成为域中主Browser。
# 这样允许Samba运行域控制器和在不同的TCP/IP子网中能被“看成”一台机器。
# 如果你使用了 Windows NT/2000域控制器,你就不应该使用它。
domain master = yes
# 更高级的域主在启动中使得Samba成为一个局域的Browser,
# 这使得它有更多的机会(选举成为域主)。
# 如果我们有2个以上的服务器,级别高的服务器会更受“欢迎”,
# 客户机会在一个列表中搜寻到一台服务器的。
preferred master = yes
# 只有你使用NT/2000 服务器在以一个主域控制器(PDC)在运行,你才能使用下条。
; domain controller = <NT-Domain-Controller-SMBName>
# 如果你想把SAMBA当成Windows 9x/Me 工作站的“域登陆服务器”,你要使用下条。
domain logons = yes
# 如果你使用了“域登陆”,你一定要使用一个登陆脚本,
# 在Windows网络中的每台机器或者每个用户。
# 每个工作站的特定登陆批处理是
; logon script = %m.bat
# 每个用户的特定登陆批处理是
; logon script = %U.bat
# 那里存放零星的profiles文件 (只对Win95和 WinNT有效)
# %L 取代这个服务器的NetBIOS名字, %U 取代用户名
# 如果你使用它,一定不要注释掉下面的Profiles共享
; logon path = \\%L\Profiles\%U
# Windows互联网解析服务器:
# WINS支持 — 告知NMBD使能它的WINS 服务器。
# WINS协议 把机器名转换成IP地址,
# 它象TCP/IP中DNS那样工作。
; wins support = yes
# WINS服务器-告知Samba的NMBD部件成为WINS的一个客户。
# SAMBA服务器可以成为其中的一个:WINS 服务器或 WINS客户机,
# 但是不可以同时2者皆是。
# 这里WINS IP服务器一定要指定。
; wins server = 192.168.8.1
# WINS代理-告知Samba回应那些没有WINS能力的客户的名字解析的请求,
# 这个情况只有在网络中至少有一台WINS服务器时才有效。
# 缺省是不。
; wins proxy = yes
# DNS代理-告知Samba是否解析NetBIOS名字
# 版本1.9.17 内建的缺省是“是”, 从版本1.9.18 变成了“否”
# 这里我们可以告知SAMBA名字解析使用DNS或者不。
# dns proxy = yes
# dns proxy = no (name resolution will be made by using the file lmhosts )
# 如果登陆的驱动盘没有被指定,Z:单元会自动登陆的。
logon drive = P:
# 当一个登陆出现时,这个脚本被执行: /etc/samba/netlogon/SAMBA.BAT
# 并且使用"netuse"来登陆磁盘单元
logon script = SAMBA.BAT
#====================== Share Definitions ========================#
# 每个用户的私人目录
# 单位 P:
[homes]
browseable = no
writable = yes
readonly = no
force create mode = 0700
create mode = 0700
force directory mode = 0700
directory mode = 700
# 临时文件目录
# 单位 T:
[tmp]
comment = Tempora Files
path = /tmp
readonly = no
public = yes
writable = yes
force create mode = 0777
create mode = 0777
force directory mode = 0777
# 服务器的CD-ROM
# 单位 L:
[cdrom]
comment = CD-ROM
path = /mnt/cdrom
public = yes
writable = no
# 组,根据/home/grp.name_group来的
# /home/user/group 是 /home/grp.name_group一个链接
# grp.name_group 使用权限770
# 单位 G:
[group]
comment = Directory of Group
path = /home/%u/group
writable = yes
readonly = no
force create mode = 0770
create mode = 0770
force directory mode = 0770
# 这个单元存放应用软件,安装软件,专用软件等。
# /net 和 /net/install的权限是 755, 比如这里, root是它的拥有者
# 单位 N:
[net]
comment = Directory Net
path = /net
writable = yes
readonly = no
force create mode = 0750
create mode = 0750
force directory mode = 0750
[netlogon]
comment = Logon Services in the Network
path = /etc/samba/netlogon
guest ok = yes
writable = no
locking = no
public = no
browseable = yes
share modes = no
GMT+8, 2026-10-18 17:38 , Processed in 0.038234 second(s), 18 queries .
