查看: 3662|回复: 6
CISCO4507R路由交换机做策略路由
发表于 2007-10-1 21:00:33 | 显示全部楼层 |阅读模式
CISCO4507R路由交换机做策略路由,由于4507R原先的IOS映象文件不支持基于源地址的策略路由,后经过在CISCO网站上查找版本说明,升级IOS文件,CISCO4507R连接到两个ISP(internet和ISP2),下接两个小BRAS,BRAS中配置了不同ISP的IP地址段,4507R基于源地址做策略路由。
 楼主| 发表于 2007-10-1 21:00:44 | 显示全部楼层
CISCO4507R路由交换机做策略路由,由于4507R原先的IOS映象文件不支持基于源地址的策略路由,后经过在CISCO网站上查找版本说明,升级IOS文件,CISCO4507R连接到两个ISP(internet和ISP2),下接两个小BRAS,BRAS中配置了不同ISP的IP地址段,4507R基于源地址做策略路由。4507R具体配置如下。
4507#sh run
Building configuration...
Current configuration : 2104 bytes
version 12.1
no service pad
service timestamps log uptime
service password-encryption
service compress-config
hostname 4507
boot system flash bootflash:cat4000-i5s-mz.121-20.EW.bin
boot system flash bootflash:cat4000-is-mz.121-12c.EW1.bin
enable password 7 06571E20561C1E0A1D
ip subnet-zero
redundancy
mode rpr
main-cpu
auto-sync standard
interface GigabitEthernet1/1
description to Internet
no switchport
ip address 222.112.123.110 255.255.255.252
interface GigabitEthernet1/2
interface GigabitEthernet3/1
description to bras1
no switchport
ip address 162.153.123.113 255.255.255.252
ip policy route-map isp2
speed nonegotiate
interface GigabitEthernet3/2
description to bras2
no switchport
ip address 162.153.123.117 255.255.255.252
speed nonegotiate
interface GigabitEthernet3/3
interface GigabitEthernet3/4
interface GigabitEthernet3/5
interface GigabitEthernet3/6
interface GigabitEthernet4/1
description to isp2
no switchport
ip address 211.211.44.254 255.255.255.252
speed nonegotiate
interface GigabitEthernet4/2
interface GigabitEthernet4/3
interface GigabitEthernet4/4
interface GigabitEthernet4/5
interface GigabitEthernet4/6
interface Vlan1
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 222.112.123.109
ip route 211.211.218.0 255.255.252.0 162.153.123.113
ip route 211.211.232.0 255.255.254.0 162.153.123.117
ip route 222.122.16.0 255.255.252.0 162.153.123.113
ip route 221.122.20.0 255.255.252.0 162.153.123.117
no ip http server
access-list 10 permit 211.211.218.0 0.0.3.255
access-list 10 permit 211.211.232.0 0.0.1.255
route-map edu permit 10
match ip address 10
set ip next-hop 211.211.44.253
line con 0
stopbits 1
line vty 0 4
exec-timeout 3 0
login
line vty 5 15
exec-timeout 3 0
password 7 03554A0A1C5D365F56
login
end
 楼主| 发表于 2007-10-1 21:10:11 | 显示全部楼层
 一、路由映射表,是将复杂IF……THEN逻辑应用于路由器,可用于控制重分发以实现基于策略的路由选择,还用于控制NAT以实现BGP策略。路由映射表有如下特征:
  * 包含一系列match语句的指定条件,
  * 使用set语句对符合条件的分组和路由进行相应修改措施,
  * 同一名称的路由映射表的一组语句构成一个映射表,
  * 映射表中每条语句都有一个序列号因此可单独编程,检查匹配条件时从小序列号开始,找到匹配条件后查找就立即结束,
  * 路由映射表可使用标准IP访问列表或扩展列表,可指定源地址、目标地址、应用程序、协议类型、TOS、优先级条件,
  * 仅当语句标记为permit且分组满足match 条件时才执行SET命令,如果是deny时不进行策略选择而动态路由选择,否则放弃,以常规方式根据目标地址转发它,
  * 一条MATCH语句可包含多个条件,这些条件是OR关系,至少满足一个条件时才算匹配,一个路由映射表也可以有多条match语句,多条MATCH语句的关第是AND,
  * 路由映射表没有match语句时,意会所有条件都可以满足都可匹配;而没有set语句时,则不做任何措施。映射表最后隐匿了deny all语句,不匹配条件时按常规转发但不会丢弃分组,在SET语句加空接口时可丢弃分组,
  * 基于策略的路由选择只影响被配置的路由——下一跳等路径,但不会影响目的地。
  二、基于策略的路由选择,有如下特点;
  * 根据来源选择连接,
  * 通过对边界路由设置IP报头优先级及TOS,级组可提供QoS来确定传输数据流的先后顺序,
  * 节省费用,动态负载均衡。
  但配置基于策略的路由选择时也要仔细考虑:必须提供备用路径防止基于策略的路由选择失效,实施策略时要查看分组源地址占用CPU周期,还有是要额外配置且可能影响其他数据流。
 楼主| 发表于 2007-10-1 21:10:24 | 显示全部楼层
三、配置基于策略的路由选择:
  1,router(config)#route-map map-tag permit/deny sequence-number
  router(config)#access-list 11 permit 140.0.0.0 0.0.255.255
  2,router(config-route-map)#match ip address access-list-number1/name1……[access-list-number2/name2]
  route(config-route-map)#match length min max
  route(config-route-map)#match interface
  route(config-route-map)#match ip next-hop
  route(config-route-map)#match metric
  route(config-route-map)#match route-type
  3, route(config-route-map)#set default interface type number [……type number ]
  指定默认出站接口列表
  route(config-route-map)#set interface type number [……type number ]
  指定出站接口列表
  route(config-route-map)#set ip default next-hop ip-address [……ip-address]
  指定默认下一跳地址
  route(config-route-map)#set ip next hop ip-address [……ip-address]
  指定下一跳地址
  route(config-route-map)#set ip precedence value
  指定IP报头优先级
  route(config-route-map)#set ip tos type-of-service
  route(config-route-map)#set level level-1/level-1-2/level-2/stub-area/backbone
  在ISIS或OSPF中指定导入到哪一级路由
  route(config-route-map)#set metric
  设定度量值供目标路由协议使用
  route(config-route-map)#set metric-type internal/extrnal/type-1/type-2
  设定度量值类型供目标路由协议使用
  4,router(config)#interface s0
  router(config-if)#ip policy route-map map-tag
  创建好映射表后必须将其用于接口才会发挥作用
  router(config-if)#ip local policy route-map map-tag
  基于策略的路由选择应用于当前路由生成分组
  router(config-if)#ip route-cache policy
  CISCO的IOS11.2以后支持手工配置快速交换方式默认是关闭的
发表于 2007-10-17 16:59:20 | 显示全部楼层
不错不错,很好啊...
发表于 2008-8-22 09:25:53 | 显示全部楼层
注意,策略路由的匹配原则是一旦匹配成功,就不向下继续匹配!
GMT+8, 2026-11-12 11:41 , Processed in 0.047988 second(s), 18 queries .
