查看: 2814|回复: 1
华为路由器+华为3928上网实例
发表于 2007-7-31 16:24:43 | 显示全部楼层 |阅读模式
客户要求:
        部分VLAN可上网,部分VLAN不可以上网(均指外网),
        而且同一VLAN中部分PC可上,部分PC不能上。
        VLAN中有AD服务器做管理。
机      型:
        华为路由器(接入)+ 华为3928P-EI  +  傻瓜TP-LINK若干
        鉴于该机子的特点(部分命令不支持)及华为交换机的“特别”性-------
        划开的各个VLAN间默认是通的,而且没有命令可以关掉,
最终配置如下:
路由器配置
<Miguel>dis cu
sysname Miguel
radius scheme system
domain system
local-user admin
password cipher .]@USE=B,53Q=^Q`MAF4<1!!
service-type telnet terminal
level 3
service-type ftp
acl number 2000
rule 0 permit source 192.168.0.0 0.0.255.255
interface Aux0
async mode flow
interface Ethernet0/0
ip address *.35.40.2 255.255.255.252
nat outbound 2000
interface Ethernet0/1
ip address 192.168.1.1
interface Serial0/0
clock DTECLK1
link-protocol ppp
ip address dhcp-alloc
interface NULL0
FTP server enable
ip route-static 0.0.0.0 0.0.0.0 *.35.40.1 preference 60
ip route-static 192.168.0.0 255.255.255.0 192.168.1.2 preference 60
ip route-static 192.168.2.0 255.255.255.0 192.168.1.2 preference 60
ip route-static 192.168.3.0 255.255.255.0 192.168.1.2 preference 60
ip route-static 192.168.5.0 255.255.255.0 192.168.1.2 preference 60
ip route-static 192.168.6.0 255.255.255.0 192.168.1.2 preference 60
ip route-static 192.168.7.0 255.255.255.0 192.168.1.2 preference 60
ip route-static 192.168.8.0 255.255.255.0 192.168.1.2 preference 60
ip route-static 192.168.100.0 255.255.255.0 192.168.1.2 preference 60
user-interface con 0
user-interface aux 0
user-interface vty 0 4
authentication-mode scheme
return
交换机配置
<Sylvia>dis cu
local-server nas-ip 127.0.0.1 key huawei
domain default enable system
queue-scheduler wrr 1 2 3 4 5 9 13 15
domain system
acl number 3002
rule 0 deny ip source 192.168.0.0 0.0.0.255 destination 192.168.8.0 0.0.0.255
rule 1 deny ip source 192.168.5.0 0.0.0.255 destination 192.168.8.0 0.0.0.255
rule 2 deny ip source 192.168.6.0 0.0.0.255 destination 192.168.8.0 0.0.0.255
rule 3 deny ip source 192.168.7.0 0.0.0.255 destination 192.168.8.0 0.0.0.255
acl number 3003
rule 0 deny ip source 192.168.5.0 0.0.0.255 destination 192.168.0.0 0.0.0.255
rule 1 deny ip source 192.168.6.0 0.0.0.255 destination 192.168.0.0 0.0.0.255
rule 2 deny ip source 192.168.7.0 0.0.0.255 destination 192.168.0.0 0.0.0.255
acl number 3004
rule 0 deny ip source 192.168.6.0 0.0.0.255 destination 192.168.5.0 0.0.0.255
acl number 3005
rule 0 deny ip source 192.168.5.0 0.0.0.255 destination 192.168.7.0 0.0.0.255
rule 1 deny ip source 192.168.6.0 0.0.0.255 destination 192.168.7.0 0.0.0.255
vlan 1
vlan 2
vlan 3
vlan 4
vlan 5
vlan 6
vlan 100
vlan 200
interface Vlan-interface2
ip address 192.168.8.1 255.255.255.0
interface Vlan-interface3
ip address 192.168.0.1 255.255.255.0
interface Vlan-interface4
ip address 192.168.5.1 255.255.255.0
interface Vlan-interface5
ip address 192.168.6.1 255.255.255.0
interface Vlan-interface6
ip address 192.168.7.1 255.255.255.0
interface Vlan-interface100
ip address 192.168.100.1 255.255.255.0
interface Vlan-interface200
ip address 192.168.1.2 255.255.255.0
interface Aux1/0/0
interface Ethernet1/0/1
port access vlan 200
interface Ethernet1/0/2
port access vlan 2
packet-filter inbound ip-group 3002 rule 0
packet-filter inbound ip-group 3002 rule 1
packet-filter inbound ip-group 3002 rule 2
packet-filter inbound ip-group 3002 rule 3
packet-filter outbound ip-group 3002 rule 0
packet-filter outbound ip-group 3002 rule 1
packet-filter outbound ip-group 3002 rule 2
packet-filter outbound ip-group 3002 rule 3
interface Ethernet1/0/3
port access vlan 2
interface Ethernet1/0/4
port access vlan 2
interface Ethernet1/0/5
port access vlan 3
packet-filter inbound ip-group 3003 rule 0
packet-filter inbound ip-group 3003 rule 1
packet-filter inbound ip-group 3003 rule 2
packet-filter outbound ip-group 3003 rule 0
packet-filter outbound ip-group 3003 rule 1
packet-filter outbound ip-group 3003 rule 2
interface Ethernet1/0/6
port access vlan 3
port access vlan 3
interface Ethernet1/0/7
port access vlan 4
packet-filter inbound ip-group 3004 rule 0
packet-filter outbound ip-group 3004 rule 0
interface Ethernet1/0/8
port access vlan 4
interface Ethernet1/0/9
port access vlan 4
interface Ethernet1/0/10
port access vlan 4
interface Ethernet1/0/11
port access vlan 5
interface Ethernet1/0/12
port access vlan 5
interface Ethernet1/0/13
port access vlan 5
interface Ethernet1/0/14
port access vlan 5
interface Ethernet1/0/15
port access vlan 6
packet-filter inbound ip-group 3005 rule 0
packet-filter inbound ip-group 3005 rule 1
packet-filter outbound ip-group 3005 rule 0
packet-filter outbound ip-group 3005 rule 1
interface Ethernet1/0/16
port access vlan 6
interface Ethernet1/0/17
interface Ethernet1/0/18
interface Ethernet1/0/19
interface Ethernet1/0/20
interface Ethernet1/0/21
port access vlan 100
interface Ethernet1/0/22
interface Ethernet1/0/23
interface Ethernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
sysname Sylvia
undo irf-fabric authentication-mode
interface NULL0
ip route-static 0.0.0.0 0.0.0.0 192.168.1.1 preference 60
user-interface aux 0 7
return
发表于 2007-7-31 16:29:56 | 显示全部楼层
GMT+8, 2026-11-12 11:43 , Processed in 0.039604 second(s), 18 queries .
