查看: 2|回复: 1
标普500指数正逼近历史上仅两次跌破的水平
发表于 半小时前 | 显示全部楼层 |阅读模式
The S&P 500 Is Pulling Into a Level That Has Only Broken Twice
This is not financial advice. I’m sharing my own research and opinions so you can learn. Do your own homework before you put money into anything.
The short version
The S&P 500 just dropped 8.6% in a single week, and it’s now pulling into the strongest support I have in my entire system: the monthly Smart Money Band.
Price has pulled back into this band 20 times. It bounced 18 of them. The only two times it broke were 2000 and 2008.
So I see two possible outcomes from here. Either this is one of the best long-term buying zones we get, or the band breaks and tells us to step aside before something much worse. In 2008, listening to that signal would have cost you around 7% to 8% and saved you from a 47% drop.
I’m still bullish. My worst case is another 4% to 5% lower, down to around $660 on SPY, before a long-term bottom. And if the monthly turns red, I’ll change my mind and get defensive.
1. The strongest support in my system
The monthly Smart Money Band is the strongest support we have in my system. And most importantly, it’s the strongest support we have for the S&P 500.
Quick explanation if you’re new here. The band is a zone on the monthly chart that tracks where long-term fair value sits. When the long-term trend is healthy, the band is green and pullbacks into it tend to get bought. When the trend breaks, the band closes red. Because it’s built on monthly candles, it moves slowly and price doesn’t reach it very often.
How often? In the history of SPY, the S&P 500 ETF that went live in 1993, price has pulled back into this support only 20 times. It bounced 18 of those 20 times.
Only two times since the ETF went live have we actually broken that support. 2000 and 2008.
Now, by all means, this does not mean price needs to bounce. It can most certainly break. So let’s look at those two breaks closely, because they teach you more than the 18 bounces do.
2. The first break: 2008
Back in December 2007, price pulled back into the middle of the monthly band.
[CHART: SPY monthly, December 2007 pullback into the band through the 2008 breakdown]
It didn’t bounce. Price continued to sell off another 4.5% and then compressed inside that range for close to 200 days. If we had taken a long position there, we would have ended up losing about 6.5% over a six-month period. Not fun, but you live through it.
Then the monthly Smart Money Band closed red.
From that point, price went on to sell off over 47% within 210 days.
Think about what that means. The worst case scenario for us, trading only the S&P 500, was a 7% to 8% move down. Taking that small loss and stepping aside would have saved you from more than 47% of downside while the rest of the market was capitulating for 210 days.
Following the band, you would have sat out of the position and saved yourself a massive headache.
3. The second break: 2000
The same situation played out in 2000.
In October 2000, price pulled to the bottom of the band and continued to plunge 15% in 160 days. There was a small relief rally in the market, and then price continued to sell off another 40% over a 700-day period.
This was the dot-com bubble popping, and it was the rougher of the two. The first leg down was bigger than anything we saw before the exit in 2008.
So here’s how I sum up the two breaks. In most of these cases the worst case scenario is a continued 5% to 7% sell-off over about a three-month period, and then a complete exit before pure capitulation. You take a small hit, and you’re on the sidelines for the part that actually wrecks people.
4. The times it bounced
Now let’s look at the other 18.
Going back to August 1998, price bounces from the bottom of the band nearly 37% within 126 days.
In October 1999, price bounces out of the middle of the band nearly 20% in 77 days.
You can see it through all of these instances. Price normally bounces somewhere between the middle and the low end of the band, and it makes a V-shaped recovery within about a six-month period.
2020 is worth its own mention, because it looks like a break and it wasn’t one. Price did trade under the band, by about 15% to 16% at the worst point. But the band never closed red, and price fully recovered before it could.
That’s the lesson I take from all 20. The only thing that stops long-term investors from buying up the dip at this level is a true financial crisis or a bubble popping. Every other time, price bounces.
5. Where we are now and my plan
The S&P 500 closed near 6,910 on Friday, November 20. That was a 3.7% drop on the day and 8.6% on the week, and it leaves the index about 11.6% below its record close from early October. The headlines blame a hawkish Fed, a sell-off in AI stocks, and worries about global growth.
That’s the noise. On my chart, what matters is that price is now moving into the monthly Smart Money Band.
If you know my Anatomy of a Cycle, every cycle moves through four stages: Ignition, Momentum, Shift and Reset. This is what Reset looks like on the biggest timeframe I trade. Price comes back to the deepest discount, and that’s where the next cycle gets set up.
This article is not to say we can’t enter another financial crisis. Of course we could. But we are pulling into what I consider one of the biggest generational buying opportunities for long-term investors.
So here’s my plan.
Best case, this is the bottom and price bounces drastically from here.
Worst case, the S&P 500 continues to capitulate another 4% to 5%, down to around $660 on SPY, before finding a long-term bottom. If that happens, we’re going to get a ridiculous long-term opportunity on a lot of A+ stocks.
6. The case against, stated fairly
I don’t want anyone reading this and thinking it’s a sure thing. So here’s what a skeptic would say, and where I think they have a point.
Twenty pullbacks is a small sample. 18 out of 20 sounds like 90%, but with numbers that small, one or two more failures would change the picture a lot.
The two failures were also the two worst markets of the last 30 years. So when this level fails, it fails big. That’s exactly why the exit matters more to me than the entry.
The exit isn’t free either. In 2008 it cost about 7% to 8%. In 2000 the first leg down was 15%. And because this is a monthly signal, it’s slow. You don’t get your answer in a day or a week.
Then there’s 2020. Price traded 15% to 16% under the band before recovering. Sitting through that takes a strong stomach, even if the band never closed red.
And last, every crisis looks like a normal correction at the start. Nobody rings a bell.
I accept all of that. It’s why I don’t just buy and hope. I have a level that tells me I’m wrong.
What I want you to remember
The monthly Smart Money Band is the strongest support in my system, and the strongest support for the S&P 500.
Price has pulled into it 20 times and bounced 18 times.
The only two breaks were 2000 and 2008. A bubble and a financial crisis.
In 2008, following the band would have cost about 7% to 8% and kept you out of a 47% drop.
My worst case from here is another 4% to 5% down, to around $660 on SPY.
If the monthly closes red, I expect a real crisis and I change my stance.
As always, I will remain objective. I will continue to trade the levels that are in front of me, and if the monthly BX turns red, I will pivot and anticipate a true financial crisis.
Get access to this, and all of our indicators as a Private Academy member.
Use the code “SMARTMONEY” for 50% off your first month
https://capitalist-academy1.teachable.com/p/private-membership-group
 楼主| 发表于 半小时前 | 显示全部楼层
标普500指数正回落至一个仅被突破过两次的水平
。这不是投资建议。我只是分享我自己的研究和观点,供大家学习。在投资任何项目之前,请务必做好自己的功课。
简而言之,
标普500指数在一周内下跌了8.6%,现在正回落至我整个交易系统中最为强劲的支撑位:月度智能资金带。
价格曾20次回落至该区间,其中18次反弹。仅有的两次跌破该区间分别是在2000年和2008年。
因此,我认为接下来有两种可能的结果。要么这是我们遇到的最佳长期买入区域之一,要么该区间被突破,提醒我们在更糟糕的情况发生之前离场观望。在2008年,如果当时听从了该信号,你大概会损失7%到8%的资金,但可以避免47%的跌幅。
我仍然看好标普500指数。我最坏的预期是SPY价格再下跌4%到5%,跌至660美元左右,然后才会触底反弹。如果月线收盘价变为红色,我会改变策略,转为防御型。1
. 我系统中的最强支撑位
:月线智能资金带是我系统中最强的支撑位。更重要的是,它也是标普500指数最强的支撑位。
如果您是新手,这里简单解释一下。智能资金带是月线图上的一个区域,它追踪的是长期合理价值所在。当长期趋势健康时,智能资金带为绿色,价格回调至该区域时往往会被买盘买入。当趋势被打破时,智能资金带收盘价变为红色。由于它是基于月线K线构建的,因此移动缓慢,价格很少触及该区域。
那么,究竟有多频繁呢?自1993年SPY(标普500指数ETF)成立以来,价格回调至该支撑位仅20次。其中18次都成功反弹。
自该ETF上线以来,我们只跌破过两次支撑位,分别是2000年和2008年。
当然,这并不意味着价格一定会反弹,它完全有可能跌破支撑位。所以,让我们仔细分析这两次跌破,因为它们比之前的18次反弹更有启发意义。2
. 第一次跌破:2008年。
2007年12月,价格回落至月线区间的中部。
[图表:SPY月线,2007年12月回落至区间,直至2008年跌破]
价格并未反弹,而是继续下跌4.5%,并在该区间内盘整了近200天。如果我们当时做多,六个月内将损失约6.5%。这当然不好受,但总算熬过去了。
之后,月线智能资金通道收跌。
从那时起,价格在210天内下跌超过47%。
想想这意味着什么。如果我们只交易标普500指数,最糟糕的情况是下跌7%到8%。如果当时止损离场,就能避免超过47%的损失,而其他市场却在长达210天的崩盘中遭受重创。遵循
区间震荡,你就能避免巨大的损失。3
. 第二次突破:2000年
同样的情况在2000年再次上演。
2000年10月,价格跌至区间底部,并在160天内暴跌15%。市场出现了一波小幅反弹,但随后价格又在700天内下跌了40%。
这就是互联网泡沫破裂,也是两次突破中更为惨烈的一次。第一波下跌的幅度超过了2008年退出市场之前的任何一次。
这就是我对这两次突破的总结。在大多数情况下,最糟糕的情况是价格在三个月左右的时间内持续下跌 5% 到 7%,然后在彻底崩盘之前完全退出。你只会遭受小幅损失,而真正造成市场崩盘的阶段,你却能置身事外。4
. 反弹的时机
现在我们来看看其他 18 个例子。
回顾 1998 年 8 月,价格从区间底部反弹,在 126 天内涨幅接近 37%。1999
年 10 月,价格从区间中部反弹,在 77 天内涨幅接近 20%。
从所有这些例子中都可以看出,价格通常会在区间中部和底部之间反弹,并在大约六个月内形成 V 形复苏。2020
年的情况值得一提,因为它看起来像是一次突破,但实际上并非如此。价格确实一度跌破区间,在最糟糕的时候跌幅约为 15% 到 16%。但该区间从未收于红色区域,价格在收于红色区域之前就已完全恢复。
这就是我从这20个周期中吸取的教训。唯一能阻止长期投资者在这个价位逢低买入的,只有真正的金融危机或泡沫破裂。其他情况下,价格都会反弹。5
. 现状及我的计划
11月20日星期五,标普500指数收于6910点附近。当日下跌3.7%,本周下跌8.6%,较10月初创下的历史收盘纪录下跌约11.6%。媒体头条将下跌归咎于美联储的鹰派立场、人工智能股票的抛售以及对全球经济增长的担忧。
这些都是噪音。在我的图表中,重要的是价格目前正在进入月度“智慧资金带”。
如果你了解我的“周期剖析”,每个周期都会经历四个阶段:启动、动能、转变和重置。这就是我交易的最大时间框架内的重置阶段。价格回落到最低折扣水平,下一个周期就此开始。
这篇文章并非否认我们可能再次陷入金融危机。当然,危机随时可能发生。但我认为,我们正迎来一代人以来最大的长期投资者买入良机之一。
因此,我的计划是这样的:
最好的情况是,目前已触底,价格将从此大幅反弹;
最坏的情况是,标普500指数继续下跌4%至5%,SPY指数跌至660美元左右,之后才会找到长期底部。如果这种情况发生,我们将迎来大量优质股票的绝佳长期买入机会。6
. 反对意见(客观陈述):
我不希望任何人读完这篇文章后认为我的计划万无一失。以下是怀疑论者的观点,以及我认为他们有道理的地方。20
次回调的样本量很小。20次中有18次成功,听起来像是90%,但样本量如此之小,再出现一两次失败就会彻底改变结果。而且,
这两次失败的回调恰好也是过去30年中最糟糕的两次市场行情。所以,一旦这个价位失效,就会出现大幅度的下跌。正因如此,对我来说,退出比入场更重要。
退出也并非没有代价。2008年,退出成本约为7%到8%。2000年,第一波下跌幅度高达15%。而且,由于这是一个月度信号,所以反应比较缓慢。你不可能在一天或一周内就得到答案。
再看看2020年。价格在反弹前一度跌破该区间15%到16%。即使该区间最终没有收于红色区域,熬过这段时期也需要强大的心理承受能力。
最后,每次危机在初期看起来都像正常的回调。没有人会敲响警钟。
我接受这一切。这就是为什么我不会盲目买入并寄希望于运气。我有一个价位可以告诉我,我的判断是否错误。
我希望你记住的是,
月度智能资金区间是我系统中支撑位最强的,也是标普500指数支撑位最强的。
价格已经20次触及该区间,并有18次反弹。
仅有的两次突破分别发生在2000年和2008年,一次是泡沫,一次是金融危机。
2008年,如果跟随波段走势,大约会损失7%到8%的收益,但可以避免47%的跌幅。
我最坏的预期是SPY再下跌4%到5%,跌至660美元左右。
如果月线收盘下跌,我预计会出现真正的危机,届时我会改变策略。
一如既往,我会保持客观。我会继续在当前价位进行交易,如果月线BX指标转为下跌,我会调整策略,预判真正的金融危机。
加入Private Academy会员,即可获取此信息以及我们所有的指标。
使用优惠码“SMARTMONEY”即可享受首月5折优惠。https
GMT+8, 2026-11-23 12:48 , Processed in 0.026939 second(s), 18 queries .
