查看: 4081|回复: 3
Nvidia $NVDA和联发科正在合作开发基于 3nm Arm 的$ARM AI PC 芯片
发表于 2024-10-10 09:20:50 | 显示全部楼层 |阅读模式
Nvidia $NVDA and MediaTek are reportedly collaborating on a 3nm Arm-based $ARM AI PC chip, and is rumored to be ready for tape-out this month to prepare for mass production by the second half of next year.
$AMD $QCOM $INTC
据报道,Nvidia $NVDA和联发科正在合作开发基于 3nm Arm 的$ARM AI PC 芯片,据传将于本月准备好流片,为明年下半年量产做准备。
Jensen gave some hints before and it's happening it seems.
GPU & ARM based CPU
詹森之前曾给出过一些暗示,而且看起来正在发生。
基于 GPU 和 ARM 的 CPU
 楼主| 发表于 2024-10-10 09:21:27 | 显示全部楼层
GPU & ARM based CPU
基于 GPU 和 ARM 的 CPU
 楼主| 发表于 2024-10-10 09:23:05 | 显示全部楼层
The collaboration between $NVDA and MediaTek on a 3nm Arm-based $ARM AI PC chip is a game-changer. If the tape-out happens this month, we could see it hit mass production by next year, potentially shaking up the competitive landscape for $AMD, $QCOM, and $INTC. This could be a major shift in the AI PC market.
由
翻译自 英语
$NVDA与联发科在基于 3nm Arm 的$ARM AI PC 芯片上的合作将改变游戏规则。如果本月完成流片,我们可以看到它在明年实现量产,这可能会撼动$AMD 、 $QCOM和$INTC的竞争格局。这可能是 AI PC 市场的重大转变。
 楼主| 发表于 2024-10-10 13:15:46 | 显示全部楼层
network 发表于 2024-10-10 09:23
The collaboration between $NVDA and MediaTek on a 3nm Arm-based $ARM AI PC chip is a game-changer. I ...
交易选举:美国大选与标普500指数走势对比。纳斯达克100指数有望很快填补20,398点的缺口。一旦出现这种情况,它将形成一个较低的高点和双顶形态。
1)在过去四次总统大选中,市场往往在大选日前后(+/-3天)下跌;
2)之后,大选结果公布后,市场通常会出现V型反弹;
3)除了2008-2009年周期外,大选前该低点标志着底部。
Trading Elections: U.S. Elections vs. S&P 500 Trend. The NASDAQ 100 is expected to fill the gap at 20,398 soon. Once this occurs, it will form a lower high and a Double Top pattern.
(1) In the last four presidential elections, the market tended to drop around Election Day (+/- 3 days);
(2) afterward, it typically made a V-shaped recovery once the Election results were announced.
上次编辑上午1:18 · 2024年10月10日
1万
29
11
GMT+8, 2026-10-12 21:57 , Processed in 0.035051 second(s), 18 queries .
