查看: 2354|回复: 0
交换机配置:三层核心+防火墙 IP重定向问题
发表于 2007-6-28 05:58:13 | 显示全部楼层 |阅读模式
三层的出口连接防火墙的内口
     三层核心交换机最好别用VLAN1连接防火墙内口。可能会因为IP 重定向问题导致内网访问外网速度奇慢!!
具体事例及解决办法如下:
某企业网核心为4506,接入基本为2950系列。核心有一块X 4548 GB&nbs p;-RJ业务板,其中48口上联到防火墙,其他下联到客户端。客户端网关指向核心交换机,上网速度奇慢。指向防火墙则速度正常,防火墙地址为172.16.1.1 核心配置如下:
core_switch#show run
Building configuration...
Current configuration : 6061 bytes
version 12.1
no service pad
service timestamps log uptime
service compress-config
hostname core_switch
enable secret 5 $1$21p4$rcisbziyY7iFWx0w7jm6d.
enable password kindy
vtp mode transparent
ip subnet-zero
vlan 2
name vlan2
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet2/1
description To ZXC
switchport trunk encapsulation dot1q
switchport mode trunk
interface GigabitEthernet2/2
description To HYS-310
interface GigabitEthernet2/3
description To HYS-303
interface GigabitEthernet2/4
description To PGZ
interface GigabitEthernet2/5
description To WLZ
interface GigabitEthernet2/6
interface GigabitEthernet3/1
description To BACK_24
interface GigabitEthernet3/2
interface GigabitEthernet3/3
interface GigabitEthernet3/4
interface GigabitEthernet3/5
interface GigabitEthernet3/6
interface GigabitEthernet4/1
interface GigabitEthernet4/47
interface GigabitEthernet4/48
interface Vlan1
ip address 172.16.1.121 255.255.255.0
interface Vlan2
ip address 172.16.2.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.1.1
no ip http server
line con 0
password ******
login
stopbits 1
line vty 0 4
password ******
login
end
因为上面的配置是把防火墙的内口直接接如了三层核心的VLAN1内,所以出现访问外网速度奇慢的现象。。
解决办法如下:
1、关闭VLAN 1的重定向功能
int vlan 1
no ip redirects
2、将防火墙的内网线接如核心的其他VLAN
GMT+8, 2026-11-12 11:31 , Processed in 0.032153 second(s), 18 queries .
